3rd Gen Cabin Temperature Control Has A Mind Of Its Own
Discussion in '3rd Gen 4Runners (1996-2002)' started by thay8888, Feb 11, 2020.
  1. Feb 11, 2020 at 8:34 AM
    thay8888
    thay8888 [OP] New Member
    First the symptoms:
    · While AC is on, cabin heater damper control goes hot on its own, I have to turn to hot, then back to cool to make the damper stay on cool.
    · Front door locks will only fully cycle 2 to 3 times before they start getting weak. Hence, I can not program my new key fobs. Static DC volts is 11.2 but at battery is 12+.
    · I think the back window operates slowly, also may be a voltage problem.
    Has anyone out there in Toyota land had voltage drop issues or have seen these issues above.
  2. Feb 11, 2020 at 8:56 AM
    I would start pulling fuses until that voltage pops back up.
    Edit: Test your voltage after the battery cables but before the fuse panel.
    I would bet you have bad battery cable(s).
  3. Feb 11, 2020 at 12:39 PM
    thay8888
    Will do, thanks
