3rd gen Bilstein shock length issue
Discussion in '3rd Gen 4Runners (1996-2002)' started by leftyloosy, Jul 22, 2022.
  1. Jul 22, 2022 at 11:18 AM
    leftyloosy
    leftyloosy [OP] New Member
    Wes
    4Runner 4WD SR5
    Not necessary
    I recently purchased a set of Bilstein shocks for my 2001 4Runner 4WD SR5 with no modifications. When I had everything apart, The new Bilsteins are longer than the originals by 1 & 1/2" inches. Not sure if that is due to a longer travel of bilstein or whatever. Has anybody ever dealt with this?
  2. Jul 22, 2022 at 11:45 AM
    Malinois38
    Malinois38 New Member
    Pa
    2002 SR5
    Following…
  3. Jul 22, 2022 at 12:05 PM
    Longer how?
    Is the body longer?
    Is the shaft longer?
  4. Jul 22, 2022 at 3:49 PM
    leftyloosy
    Wes
    4Runner 4WD SR5
    Not necessary
    I have attached pictures to my original message. The body is right but the shaft is longer
  5. Jul 22, 2022 at 4:10 PM
    If you push both all the way in...still a different height?
    Unless the 3rd gen suspension, when bottoming out, has less room that the minimum height of the shock, it should be no issue.
  6. Jul 22, 2022 at 4:56 PM
    leftyloosy
    Wes
    4Runner 4WD SR5
    Not necessary
    Excellent idea! They are both the same height when pushed in. The new one was a struggle, the old one was like pushing through soft butter.
    Many Thanks
  7. Jul 22, 2022 at 5:04 PM
    Well now you know you have a few more inches of travel if you ever want to lift your suspension a little.
  8. Jul 23, 2022 at 7:47 AM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    Your old shocks have completely lost all dampening abilities and are in a 'collapsed' configuration.
    Safe to say you were a good 15 years past due on replacing your shocks; non-serviceable shocks should be replaced every 5 years or 50k miles.
  9. Jul 23, 2022 at 8:43 AM
    I disagree.
    Shocks, struts typically last well past 5 years and it's a waste of money to replace them that early. Shocks\Struts going past 15 years is not unheard of. 20 is probably pushing it for most cars but I have cars with 30 year old shocks that are still holding up. I also have cars where they started failing after 10. But 5? That's barely their half life.
    My original shocks front and back were 20 years old when I replaced them with TOYOTA OEM shocks. When I compared them, they had no discernible difference in dampening. I felt bad that I was probably throwing away good shocks, but it was time as the car is my daily driver.
  10. Jul 23, 2022 at 9:28 AM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    Seals can only last so long before they leak whether they're oil or gas charged, and although a shock isn't physically 'broken', they've surely lost their ability to dampen as well as they used to.
    If we're talking oil-filled shocks, that oil over time breaks down...just like the oil in your engine or other lubricants used throughout your vehicle. If they're gas charged, they'll leak over time just the way tires need refilling every so often...even if it isn't for months.
    But like you said, you disagree.
  11. Jul 24, 2022 at 1:26 AM
    I got like 17 years out of my factory shocks they were not even leaking or anything, I just figured I would do it for something to do. Rides great about the same.
  12. Jul 24, 2022 at 10:52 AM
    leftyloosy
    Wes
    4Runner 4WD SR5
    Not necessary
    Thanks for the great points. I bought the 4Runner a couple of years ago and bought the shocks a while back. Sure glad I found my round tuit
