3rd gen 4runner sensor codes issue.
Discussion in '3rd Gen 4Runners (1996-2002)' started by kaoticbliss66, Dec 4, 2022.
  1. Dec 4, 2022 at 11:28 PM
    kaoticbliss66
    kaoticbliss66 [OP] New Member
    Jamie
    2000 Limited 4 runner
    Replaced engine with my 1997 limited
    I have a 3rd gen 2000 limited 4runner with a 97 limited engine in it, 3.4L.
    I backed a trailer up to my boyfriend's mom's driveway just fine. Unloaded the trailer and went to move my truck but it wouldn't start. It cranks over like it wants to. Checked my codes and had a P0335 (crankshaft position sensor bank 1). Changed the sensor cleared the code and now I have even more codes.
    P0115 (Engine coolant temperature sensor)
    P0100 (MAF sensor)
    P0340 (camshaft sensor a)
    P0773 (TCM transmission shift solenoid sensor)
    Surely they couldn't of all gone out at the same time, right? If it helps any, it did start raining but my hood wasn't open so I'm not sure if that really matters much. Could my ECM be bad or shorting out maybe? All I know is I can't afford to replace all these sensors right now. Any advice is welcome!
  2. Dec 5, 2022 at 12:23 PM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    Could be you got water in the ECU. It's a problem they have. Sometimes, if the trim around the windshield gets rust under it, rain water can run down inside the cab, getting into the ECU. Is the carpet wet on the passenger side? Even slightly damp? If so, you might want to get into the kick panel on the passenger side, pull the ECU out and let it dry. Put it into some rice, whatever is your preferred method of drying electronics. Make certain the plugs to it are nice and dry, too. A quick shot of electronics cleaner to each pin works very well, or just leave them off the ECU while you dry it. They'll air dry eventually. A day or so would do the trick.
    Once you're sure the ECU is good and dry, take the covers of it, and look for burn marks, burned components, lifted runs, and so forth. Any sign of stuff like that, you're probably going to need to replace it.
    Unless, of course, you're a retired electronics tech that can repair those kind of troubles :D
    There may be other troubles, and this may not be your trouble at all. It's just my opinion as to what your trouble MAY be. Worth a look, though.
    I wish you the very best.
    Pat☺
    kaoticbliss66[OP] likes this.
  3. Dec 6, 2022 at 7:20 AM
    https://www.youtube.com/watch?v=5-t69mMpazg
    Sounds like definitely something going on. It may be power issues to the ECU or the ECU itself.
    I would reset all codes again and see what comes back. If it's a bunch of random stuff again, I'd look at the ECU and the wiring to it.
  4. Dec 6, 2022 at 10:40 AM
    kaoticbliss66
    Jamie
    I'll check it out today. I cleared the codes once already but 2of them wouldn't clear.
  5. Dec 6, 2022 at 11:08 AM
    kaoticbliss66
    Jamie
    So I noticed that my fuel pump doesn't kick on when I turn the key. Could it be bad and in turn cause the error codes as a fluke....or is it not turning on because the ECU probably? I don't want to drop the tank and do the fuel pump if it's not needed. I'm not somewhere I'm able to have a decent tooling area out of the way.
  6. Dec 6, 2022 at 12:39 PM
    PhantomTweak
    Patrick
    OREGON
    Could well be the COR.
    Have you tried jumping the Fp and B+ terminals in the test jack undr the hood? Does it come on when you do? If it does, it could be the COR or the MAF. open the vane in the MAF, and seee if the pump comes on. If it does, definitely be the COR.
    COR is about $65.00, and very easy to replace. Again, it's possible that it was getting water in it. Or, it may just have gotten old and failed. They do that.
    Good luck!
    Pat☺
  7. Dec 6, 2022 at 1:44 PM
    COR = Circuit Open Relay
    MAF = Mass Air Flow
    Had to google COR...very rarely see that.
