33x12.5 X-Comps on 5th Gen
Discussion in '5th Gen Builds (2010-2024)' started by Dannyv116, Jan 6, 2021.
  1. Jan 6, 2021 at 12:57 PM
    Dannyv116
    Dannyv116 [OP] New Member
    Danny
    Hello I am looking to put some 33x12.5r20 xcomps on my limited rims for my 2013 limited runner. I have seen it done before with the 4th generations: heres a picture of a 5th gen with 33's.
    lindenwood-albums-lindenwood-picture4411_34cf4f619e9cc4b8a33d6d4c07a066c86b9aeb14.jpg
    looks like a lot of trimming is required for the rear, and the front.
    Just wanted a second opinion on what kind of lift would be best:
    Heres my goal:
    This but on a 5th gen. What kind of lift/spacers do yall recommend?
    I want them to be as stuffed as possible without rubbing 24/7. If it rubs on full rotation thats fine. Lmk what yall think
  2. Jan 6, 2021 at 1:01 PM
    Mtbpsych
    Mtbpsych New Member
    Stuffed as possible? Put them with no lift and trim accordingly. I don’t think I’ve ever seen anyone want their 33’s stuffed as possible..
    there’s a search button up top, right corner. Plenty of feedback here, just gotta do some work!
    Thatbassguy and Dannyv116[OP] like this.
  3. Jan 6, 2021 at 1:17 PM
    Dannyv116
    Danny
    @Mtbpsych thanks, I looked at a couple different forums and no one has the limited rims matched with 33x12.5's. Theres no way theyll fit without a lift. As for spacers it looks like 1.75 or 2 space is needed to fit. When I say stuffed I want them to be flushhhh.. like this
  4. Jan 6, 2021 at 1:18 PM
    Dannyv116
    Danny
    Thinking I can get away with a 2" level and spacers, but idk
  5. Jan 6, 2021 at 1:25 PM
    Mtbpsych
    Mtbpsych New Member
    OEM 20” wheel has +12mm offset with about 4.6 backspace. You shouldn’t stick outside the fender well with 285’s on those wheels, not sure how close you’ll be to the upper control arm though. Maybe someone else can chime in, but there’s lots of info on t4r.org as well. The 2014+ limited has a huge front bumper, but 2010-2013 is the same across trims so I don’t think you’ll need to do much on the front bumper besides fender liner mod.
  6. Jan 6, 2021 at 1:51 PM
    You don't really need a lift to fit 33's as much as getting the caster as high as possible and some trimming, fender liner modification, possibly a body mount chop.
    I don't think you'll need to do anything in back.
    Mtbpsych and SlvrSlug like this.
  7. Jan 8, 2021 at 1:05 AM
    2013limited4runner
    2013limited4runner New Member
    I am putting 285/70/17 on my 2013 limited very soon. These tires are 32.7 inches by 11.2 inch so not really as wide. I do have the thought country 2 inch xreas spacer lift and my wheels are 17x9 with a -12 offset vs the stock limited wheels that are 20x7.5 with a +15 offset I’m pretty sure. I know that the tire I’m putting on will require me to do a modification to the front bumper however it is very easy and simple to do.( just unscrewing and moving 2 bolts)
