33s on 2013 limited?
Discussion in '5th Gen 4Runners (2010-2024)' started by 2013limited4runner, Dec 31, 2020.
  1. Dec 31, 2020 at 8:15 PM
    2013limited4runner
    2013limited4runner [OP] New Member
    Is anyone running a 285/70r17 on a 17x9 wheel with a -12 offset on a 2010-2013 limited 4Runner with 2 inch lift? Will it work without a lot of body modifications?
  2. Dec 31, 2020 at 8:30 PM
    Agent_Outside
    Built 2011 T4R Limited
    That’s a very specific question but for what it’s worth I have a 2011 Limited on 255/80/17 Ridge Grapplers (33.3”) on TuRD Pro wheels with a 2”ish lift front and rear with JBA upper control arms and durobumps. I unbolted the front of the fender liners and pulled them forward a bit before bolting them back in and I heated up and beat up the front mud flaps a bit.
  3. Dec 31, 2020 at 8:37 PM
    2013limited4runner
    Thanks for the help. I’m a little concerned since the 285/70r17 is a bit wider it would have more of a chance to rub.
  4. Jan 2, 2021 at 2:29 AM
    MI-FL off roader
    Brett
    Merritt Island, FL
    03' SR5 Sport - 12' Limited
    First incarnation of my 2012 LE 5 years ago.
    2.5" lift/Total Chaos UCAs w SCS F5s 8.5" -10mm offset w Cooper ATPs 285/70/17s.
    I did the Front fender liner mod that Agent_Outside spoke of and just removed the mud flaps. It only rubbed in extreme situations offroad and if I was backing up hard in full lock. Also, aftermarket UCAs allow a competent alignment tech to move your caster forward to help with rubbing in the rear of the fender well. When I switched to a MT tire of the same size, they rubbed a little more in the rear of the fender well, so I had my tech move the caster forward a little more. By then I had my aftermarket front bumper so that gave him a little more space in the front to work with because the plastic bumper was gone and the fender liner was cut to fit the new profile.
