3 ton jack stand
Discussion in '5th Gen 4Runners (2010-2024)' started by linkfeeney, Mar 17, 2021.
  1. Mar 17, 2021 at 6:00 AM
    linkfeeney
    linkfeeney [OP] New Member
    Hi,
    you guys use 3 ton jack stand on the 4runner?
    I just got a set of sunex 3-ton stand. Now I got me thinking when I start to lift the 4runner on one side and let it rest on the1 stand while I go and jack the other side... it would be too much weight/stress for the 1 side in the meantime?
  2. Mar 17, 2021 at 2:12 PM
    grizzlypath
    grizzlypath New Member
    2020 ORP-KDSS
    To answer your questoin, no, it should be fine. Although, if you have enough room where you're jacking I'd recommend just jacking from the front subframe, put stands under the front frame rails, then jack from the rear differential and throw the stands under the rear axle (or frame depending on what you're doing). Easier imo!
    A&P and linkfeeney[OP] like this.
  3. Mar 17, 2021 at 2:32 PM
    linkfeeney
    ok thank you
  4. Mar 17, 2021 at 2:55 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Why are you lifting one side at a time?
    Are you lifting with a floor jack or bottle jack?
    It's a matter of safety and you didn't give us enough information to be completely accurate with advice.
  5. Mar 17, 2021 at 3:39 PM
    Dillusion New Member
    KYle
    I jack the whole front up throw stands under both sides and call it a day.
    I'm not sure either why you are doing one side at a time. If using the bottle jack I'd suggest investing in a good jack for regular maintenance.
  6. Mar 17, 2021 at 4:44 PM
    linkfeeney
    hey sorry... you know I didn't think about jacking it up from the front of the car. I am planning to do the oil change on it soon 1st time on the 4runner. I was thinking jack it one side like I used to to do changing a tire of a car. I have a 09 tacoma and the clearance high enough to do it. I looked at the manual on manual jacking it up, but now I am thinking, it doesn't seem right.
  7. Mar 18, 2021 at 6:02 AM
    grizzlypath
    2020 ORP-KDSS
    Good call, I just assumed OP was using a big floor jack!
  8. Mar 18, 2021 at 8:14 AM
    MAXIM
    MAXIM New Member
    3 ton will hold fine but best suited for smaller cars (sedans). If you want to be absolutely safe get 6 ton stands since those are cheap and will give you enough elevation.
  9. Mar 18, 2021 at 10:15 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    When buying a jack or stands you could literally be trusting them with your life. For the extra short money you will spend best to way overbuy the weight range you should need.
  10. Mar 18, 2021 at 3:46 PM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
