285/70 R17
Discussion in 'Wheels & Tires' started by cereb6, Jun 24, 2022.
  1. Jun 24, 2022 at 3:39 PM
    cereb6
    cereb6 [OP] New Member
    Chris
    2021 4Runner SR5 Premium.
    None.
    I have seen so many conflicting answers when it comes to this tire size. I have a 2021 SR5 with a 2 in lift. Other than minor trimming, will I be able to run a 285/70 without having to do a BMC? I don't want to have to do a BMC. Can someone please tell me a definite answer? I have had two different tire shop owners in my hometown tell me two different answers as well. I have stock TRD rims.
  2. Jun 24, 2022 at 3:51 PM
    Mtbpsych
    Mtbpsych New Member
    There is so definite answer. Trial and error, either commit or play it safe and get 275’s. With that said, having a wheel that is close to 0 offset and isn’t wider than 8in should probably work.
  3. Jun 24, 2022 at 4:44 PM
    ESCT4R
    ESCT4R New Member
    2022 TRD ORP
    Exactly.
    Some get by with just a lift and others have to get a BMC. Only way to tell is by getting them installed lol. Kind of sucks, but it is what it is. Mine needed a BMC in order to fit them. Are you thinking KO2's?
  4. Jun 24, 2022 at 5:02 PM
    cereb6
    Chris
    None.
    I will probably take this advice. Thanks bud.
    Mtbpsych[QUOTED] likes this.
  5. Jun 24, 2022 at 5:04 PM
    cereb6
    Chris
    None.
    I have heard they have balancing problems for 4runners. I was thinking either Falken Wildpeak M/T or Toyo Open Country AT 3's
    7385 likes this.
  6. Jun 24, 2022 at 6:16 PM
    Stoney Ranger
    Stoney Ranger New Member
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-Fr/R Bpr-Winch-Stickers-ALF
    I have Falken Wildepeak 275's on the SR5 snowflake wheels. 2" lift with a winch and bumper, skids and sliders. Sits about 1" higher than stock. Off-roading during a full lock turn and the suspension compresses, the right front rubs a tiny bit. Same in reverse backing into the driveway. Full lock and roll over that 'lil bump, it just barely touches.
    The balancing issues were/are with the Falkens WP's. I have had zero issues. Tires have 20,000 miles. I recommend them 100%
    If the KO2's have issues, this is the 1st I have read about it.
    cereb6[OP] likes this.
  7. Jun 24, 2022 at 6:55 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Personal opinion is 275's aren't worth it. 275's are barely bigger than the stock 265's, so if you're ditching 265's to go up one size it's not a very good bang for buck.
    Doing some fenderwell massaging isn't a bad thing. BMC, fender liner adjustment, trimming mudflaps isn't going to hurt anything. It's better to do it than not regardless of tire size.
    I've been running 285's for almost 11 years on a Tacoma and 4Runner and haven't done much more than mudflap trimming. A lot of it depends on tire offset/backspace to what kind of modification you're in for. Stealth Custom Series wheels does a great job of putting the tire exactly where you need it for minimal modification.
    Ironguy and Thatbassguy like this.
  8. Jun 24, 2022 at 7:46 PM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    I have a -12mm offset wheel, 2 inch lift up front (supposedly. Not sure now with the added weight to the truck). I am running 285/75/17 and they have some rubbing backing up at full lock out when I hit hills a bit faster than slow and the front of the 4runner goes down it will rub a little. However, I really like them. I previously had Toyo OC AT3’s and they were an awesome tire in most every condition. I changed to mud terrain tires and they are more noisy but they look beefy and do really well off-road.
    disclosure: I do have a BmC and had to get rid of the front mudd flaps and some trimming. But that is about it at this point.
    White Walker and cereb6[OP] like this.
  9. Jun 30, 2022 at 1:30 PM
    cereb6
    Chris
    None.
    Man, I am just leery when it comes to the BMC. That is one mod that I can not do myself. 275 does limit what type of tire and brand you can get but I would rather be able to run my new tires without having to worry about rubbing on the frame or upper control arms. I plan on running the stock TRD rims so I am thinking that these rims will be ok with just fenderwell trimming and eliminating mudflaps.
  10. Jun 30, 2022 at 2:14 PM
    singalls
    singalls New Member
    Stephen
    Northern California
    2022 TRD Off-Road Premium
    If you had a reputable 4x4 shop nearby... I would think a BMC and fender adjustment would be an easy no-brainer for them if you really want to go up to 285s.
  11. Jun 30, 2022 at 2:27 PM
    cereb6
    Chris
    None.
    It shouldn't be but I do live in Mississippi. LOL. I guess I need to do some calling around.
  12. Jun 30, 2022 at 3:19 PM
    ESCT4R
    ESCT4R New Member
    2022 TRD ORP
    I've been fortunate to not have any issues with KO2's. I had them on my '18 and currently on my 22'. No balancing issues, no steering wheel shakes, and they are great off-road!
    Do you have experience with power tools? I did the BMC myself with an angle grinder. Piece of cake.
  13. Jun 30, 2022 at 3:48 PM
    Altitude4x4
    Altitude4x4 New Member
    2019 Voodoo Blue TRD Pro
    I would advise against an MT unless you really want/need them, they're harder to fit and sometimes balance weird. In addition to the extra weight, cost and sometimes road noise and wandering.
    7385 and cereb6[OP] like this.
  14. Jun 30, 2022 at 3:51 PM
    cereb6
    Chris
    None.
    I can cut it myself with a grinder, but welding the plates on is a whole other story. LOL.
  15. Jun 30, 2022 at 3:52 PM
    cereb6
    Chris
    None.
    Good to know. I think I am going with Toyo Open Country AT 3's.
  16. Jun 30, 2022 at 3:55 PM
    Altitude4x4
    Both that and the Wildpeak are fantastic tires, with the Wildpeak being a tad more on the aggressive side. I personally would avoid BFG due to their degradation of quality over the the last 10 years.
  17. Jun 30, 2022 at 6:35 PM
    UofLCardfan77
    UofLCardfan77 Large Member
    Elizabethtown, Kentucky
    I just put 265 70 17 Pirelli Scorpion All Terrain Plus on my 2019 ORP. Only had them on for a few days but so far I'm really liking them. I have the stock TRD rim. They don't have a 275 but they do have a 285.
  18. Aug 19, 2022 at 7:57 AM
    TrailSpecial22 New Member
    PA
    Go with 285’s
  19. Aug 24, 2022 at 3:05 PM
    Zano77
    Zano77 Teflon Zan
    Zano
    2022 TRD ORP
    Dobinsons 1.5" front coils, stock height Dob's rear coils,.60" rear spacers, Dob's twin tube shocks
    I run 275/70/17 Nokian Rotiiva AT Plus on my 4Runner & Tacoma.. C load rating.. 60k mile, aggressive tread, great in wet weather, snow rated, great off road, 6 ply..
  20. Aug 24, 2022 at 8:00 PM
    Do you have UCAs?
    Do you happen to know what your caster is?
    You can absolutely run 285/70/17's with Pro wheels without a BMC.
    You need to be able to get your caster forward.......probably around the +3.5 mark. However, you might not be able to do that with a 2" lift and stock UCA's.
    But to run your caster this high, you'll need to do the fender liner mod (way easier than a BMC).
  21. Aug 24, 2022 at 10:28 PM
    T4RNR
    T4RNR New Member
    Anthony
    17 4Runner, 03 Tacoma
    This. I've lifted two 5th gens both with UCAs and TRD wheels. Had to trim the front bumper lip ever so slightly. But with caster pulled forward, no need for BMC.
  22. Aug 25, 2022 at 6:04 AM
    To follow up on what I said above.....
    There's still a chance you can get away with no BMC, 285's and your stock UCA's.
    What you'll want to do is:
    1) Fender liner mod
    2) Get an alignment and have them max out your caster (tell the alignment shop you're hoping to get it in the mid +3's if possible).
    3) Put your 285's on and see if you rub the body mount (or not)
    If you do rub:
    4) Decide wether to get UCA's or do the BMC.
    It's also possible that you just rub the mudflap, in which case you can remove, trim, or massage with a heat gun.
    7385, Thatbassguy and TrailSpecial22 like this.
  23. Aug 25, 2022 at 9:13 AM
    PA
    Now granted these are not TRD rims that I took off my 2011 SR5, however they are wildpeaks in 285/70/17 mouted on my 2022 Trail Special with 2” lift in front. They clear the rear Mudflap And body moint just fine and the front inner wheel well liner just fine locked to left and right. I also did not have to push the wheel well liner forward at all.
    SlvrSlug likes this.
  24. Aug 25, 2022 at 10:13 AM
    Those wheels are a different offset than the Pro wheels. The lower offset changes things.
  25. Aug 25, 2022 at 10:26 AM
    PA
    Correct, in the end it looks like a fender trim and liner push will be needed tonPro wheel owners.
    nimby[QUOTED] likes this.
  26. Aug 25, 2022 at 1:55 PM
    cereb6
    Chris
    None.
    Update..........I went with Falken Wildpeaks, 285/70's and have no rubbing at all. Thanks for all of you guys' input and advice.
  27. Aug 25, 2022 at 4:30 PM
    PA
  28. Aug 26, 2022 at 7:40 AM
    Kilo Papa
    Kilo Papa New Member
    TX & NM
    2021 TRD Pro
    cereb6:
    Good on you!
    Did you have the caster adjusted as was suggested or have to make any of the mods?
  29. Aug 26, 2022 at 2:31 PM
    cereb6
    Chris
    None.
    Not yet. I am going to buy new UCA's soon so I thought I could get away with it until then.
  30. Sep 1, 2022 at 7:26 AM
    Whiptastichandling
    Whiptastichandling NCrunner
    NC
    15 Trail Premium
    3in Ironman 4x4 nitro stage 2 suspension lift 285s
    Has anyone had a 4Runner with 3” suspension lift and tan 265s? I have that in now but am sitting at tire store now waiting on 285s to be put on. I was just wondering If there is a noticeable difference in height?
    idk if it’s because I look at it all day everyday but often times even with lift I feel I’m the same height as stock runners.
