285/70/17 inflation advice
Discussion in '5th Gen 4Runners (2010-2024)' started by morfdq, Mar 24, 2023.
  1. Mar 24, 2023 at 4:56 PM
    morfdq [OP] New Member
    Just had the Eibach Pro Stage 2 installed. Tomorrow I get the Toyo AT3s 285/70/17 6 ply installed. Looking for some inflation advice. 90% highway 10% off road. What PSI would you recommend. Thank you in advance.
    brownersd and 5six like this.
  2. Mar 24, 2023 at 5:37 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I'd start at 36psi and go from there.
    Thatbassguy, SlvrSlug and kmeeg like this.
  3. Mar 24, 2023 at 6:29 PM
    Appreciate that.
  4. Mar 25, 2023 at 10:23 PM
    brownersd
    Sean
    Humble, Texas
    I have the exact same setup, except for 10 ply, and I run mine at 38 psi cold.
    Cheers,
    Sean
  5. Mar 26, 2023 at 8:42 AM
    Awesome. Thank you. Just got them installed yesterday and had no clue what to inflate them to. One poster said 36. Like he said. I’ll start at 36 and adjust accordingly between 36 and 38. I absolutely love the Eibachs. The toyos are also performing well. Granted I have like 20 miles on them. I got to shave the wheel well a tad. Not a big deal. I love the setup
  6. Mar 26, 2023 at 5:29 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    @morfdq what tire did you have before?
    I’m looking to get the same Toyo AT3 eventually. How’s road noise compared to your previous set up? I currently have the stock Nitto terra and I like that they’re not too loud. My 4R is not primarily for commuting but I do some long driving on camping/ski/overland trips so I don’t want a tire that’s too loud. But I also want a decent off-roader as I do a good amount of dirt roads/off roading
  7. Mar 27, 2023 at 5:10 AM
    It makes no noticeable noise. Love them
  8. Mar 27, 2023 at 5:24 AM
    perfect. Just ran it and it is 38. Thank you
  9. Mar 27, 2023 at 9:33 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Looks great! 36psi is where I start at, then chalk test after if needed. I even set my sl 285s at 36psi.
  10. Mar 27, 2023 at 11:27 AM
    So do you run the same psi. in all four tires? I have used the chalk test method for 50+yrs and it has always worked well for me. Not just in my drivway, and contact patch is a plus.
    Nano909 and Thatbassguy[QUOTED] like this.
  11. Mar 27, 2023 at 11:28 AM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    You're not gonna get him to admit he is wrong, all he does is throw the same argument at you over and over again without providing any information to back up his claims... and occasionally he adds insults.
  12. Mar 27, 2023 at 11:49 AM
    I do. But, only because that's what the door recommends.
    I 100% agree that contact patch is important. I've never said it isn't.
    I've never even said that the chalk test is completely invalid. I'm just providing a different way to find the appropriate tire pressure, which is based on load range, tire size, and GVWR.
    Remember, the person I'm debating against is claiming that the chalk test is the only option, when it really isn't.
    brownersd, kmeeg and Captain Spalding like this.
  13. Mar 27, 2023 at 1:54 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -K&N Engine Air Filter *NOW FRAM EXTRA GUARD CA10835 -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    You come at everybody bro, that's you. I'm actually a nice guy who posts a lot about my truck and tries to help ppl out. I'm outta here
  14. Mar 27, 2023 at 2:31 PM
    I look forward to your impressions.
  15. Mar 27, 2023 at 4:18 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    Ideal pressure based on door labels, manufacturers, and calculators offer a good place to start given all things are equal. People tend to be a little neurotic about shit they read on the internet and lose sight of the realities of real world things of which the chalk test helps offer. Can't balance what your eyes and your ass feels with just straight forward calculations.
    Nano and bassguy provided valid points in between the insults but their debate turned out well in the end. It could have been left alone then.
  16. Mar 27, 2023 at 6:00 PM
    brownersd
    Sean
    Humble, Texas
    Looks great, man!
    Cheers,
    Sean
    djwantke likes this.
  17. Mar 28, 2023 at 9:35 AM
    Sejin
    Sejin New Member
    2017 Super White SR5
    33psi has been comfortable for me with even wear
    you could always do the chalk test as well
