255/75-17
Discussion in 'Wheels & Tires' started by afret, Dec 28, 2021.
  1. Dec 28, 2021 at 2:07 PM
    afret
    afret [OP] 2022 ORP, KDSS, Toyo AT3
    North Idaho
    Will these rub using factory ORP wheels with no lift? Most seem to be around 0.4" taller in diameter and the tread width about 3/4" skinnier than 265/70-17s.
  2. Dec 31, 2021 at 2:27 PM
    beankozi
    beankozi New Member
    Jarrett
    Vancouver Island
    2021 Venture
    quite a few
    almost certainly will not rub.
    7385 likes this.
  3. Dec 31, 2021 at 4:35 PM
    Gstick
    Gstick New Member
    19' TRD OFF ROAD
    I am running Goodyear Duratracs in the 255/75/17 size, but on OEM SR5 wheels. (only 7" wide) No rubbing whatsoever. All stock suspension.
  4. Dec 31, 2021 at 6:11 PM
    afret
    North Idaho
    Thanks guys! I think I'll get Coopers in that size on factory wheels because of the light weight.
    Trail Runnah likes this.
  5. Dec 31, 2021 at 8:31 PM
    afret
    North Idaho
    Yeah, I looked up the recall and they were all 275s in 18 and 20 inch. Maybe I should just get the heavy 265/70 Wildpeaks.
  6. Feb 11, 2022 at 2:47 AM
    Deuxdiesel
    Deuxdiesel New Member
    SE MI
    '18 SR5P
    My DuraTracs in that size on OEM steelies don't rub at all, but the KO2's on Motegi's rub a bit because they are greater in diameter by a noticeable amount.
  7. May 19, 2022 at 10:01 AM
    TNCave
    TNCave New Member
    Are you stating that the KO2 is larger in actual diameter compared to Duratracs in the 255/75-17? If so, that would be great information to have. I always wonder about actual specs compared to listed specs like height, weight, etc.
  8. May 24, 2022 at 8:50 AM
    Deuxdiesel
    SE MI
    '18 SR5P
    Yes. When I swap over the tires and stand one of each next to one another, the KO's are a good 3/4" taller than the DuraTrac's. The shoulder tread on the KO's is a bit chunkier as well, giving them a slightly larger appearance.
    TNCave likes this.
  9. May 24, 2022 at 6:50 PM
    T4R13
    T4R13 New Member
    Clarksburg wv
    19 sr5p
    Cooper st Maxx are decent. Had them on a Tacoma and currently on my dually, wear decent and good on wet roads and snow. Pack up quick in mud tho
  10. May 24, 2022 at 7:48 PM
    TNCave
    TNCave New Member
    Thanks. This is super helpful and points me toward the KO2’s.
