23’ ORP stock height
Discussion in '5th Gen 4Runners (2010-2024)' started by WRunner, Feb 4, 2026 at 1:34 PM.
  1. Feb 4, 2026 at 1:34 PM
    WRunner
    WRunner [OP] New Member
    Tuesday
    Jason
    23’ 4Runner
    No Idea.
    What is it? We have some Dobson equipment under there and an adjuster wrench in the glove box. Gauging how much lift we already have and where it needs to go from here. Already running 33” tires so it has some lift just not sure how much. Plan is to eventually go up to 35” tires but there may be a full rebuild before that. Not even sure the stock equipment can handle 35” tires.
  2. Feb 4, 2026 at 1:35 PM
    When you say "Stock height", I'm assuming you mean ground clearance, correct? If that's what you mean, it's 9.6 inches.
  3. Feb 4, 2026 at 1:45 PM
    JSP127
    JSP127 New Member
    Stock hub to fender measurements average out to 20" front and 22" rear.
  4. Feb 4, 2026 at 8:32 PM
    WRunner
    Tuesday
    Jason
    23’ 4Runner
    No Idea.
    Thanks guys. I’ll measure it when I get a chance. If anyone has a ground to bottom of fender measurement I’ll take it. Not sure where the accurate unit of measure is taken on these. lol
  5. Feb 4, 2026 at 8:38 PM
    Pentangler
    Pentangler Happy Member
    Most commonly, ride height measurements are taken from center of hub straight up to the bottom of fender.
  6. Feb 4, 2026 at 9:03 PM
    ^^^ Suspension changes affect center of hub to fender measurements regardless of tire size. Tires can affect ground to fender measurements.
  7. Feb 5, 2026 at 12:48 AM
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    Toyota usually measures ride height at suspension mounting points to the ground (stock tire diameters). I think it's the front lower control arm bolt centres and the rear lower trailing arm bolt centers.
    Edit: I was sorta right. It's the difference in height from the hub centre to the suspension mount bolt centre (from the 2006 manual):
  8. Feb 5, 2026 at 12:55 AM
    Im sure there's a search function somewhere on these forums but I won't be bothered to look for it
    WRunner[OP] and Borracho Loco like this.
