2026 Limited Model Question (s)
Discussion in '6th Gen 4Runners (2025+)' started by jlf656, Apr 28, 2026.
  1. Apr 28, 2026 at 12:35 PM
    jlf656
    jlf656 [OP] New Member
    New to forum thanks for the add. Trying to help wife with selecting a new ride. We have a couple questions and hope the folks here can clear the way? She has had several 4runners over the years and currently wishes to go back to one this year. She waited for the new year model wanting the updated media and model changes. She has settled on a Limited, non hybrid, and it will be a daily driver, with no off pavement use. So here are the questions as of today. I have search numerous 4Runner sites but can't get a confirmed straight answer.
    1. Do the 4wd Limited v the 2wd (rwd) models appear the same as far as stance and wheel clearance? (based on Toyota site roof height etc.. are the same) but are they?
    2. I have searched far and wide and cannot find a 2wd Limited to see in person? There are other models out there but cant find a Limited. Toyota shows you can order one. Do they really exist??
    3. Are there other differences regarding the 4wd v 2wd other than the obvious 4v2 wheel operation?
    With the 2026 being a 4cyl we were thinking the absences of the 4wd weight it could be a plus when it comes to performance?
    Thanks for any info on this. I'm sure there will be more questions as she moves ahead.
  2. Apr 28, 2026 at 12:41 PM
    2019 TRDP w/Kangs brah!
    1) Same
    2) Yes
    3) No. Same.
    jlf656[OP], ToyotaDude99 and icebear like this.
  3. Apr 28, 2026 at 1:03 PM
    2. Probably allocation/regional variations. We got some new, 2WD, gas Limiteds here around DFW according to Autotrader.
    3. You might have an Auto LSD button somewhere but that's just a brake limited-slip option on 2WD trucks.
    There won't be much performance difference if any regardless of engine.
    Gas Limiteds might be the only models in the lineup with engine stop/start but don't quote me on that.
    jlf656[OP] and ToyotaDude99 like this.
  4. Apr 29, 2026 at 2:32 AM
    Welcome from Wisconsin!
  5. Apr 29, 2026 at 3:26 AM
    Brian
  6. Apr 29, 2026 at 6:27 AM
    Gumpus
    Gumpus New Member
    I used to work in truck engineering for an OEM. In general 2WD gives you a little better performance and fuel economy since they are lighter with less friction. Sometimes the difference in ride quality is clearly noticeable and usually favors the 2WD but with the 2WD 4Runner being so rare I doubt they spent as much time refining it as the 4WD.
    One consideration is resale value where you might have trouble finding people interested in a 2WD truck.
    NB4x4, ToyotaDude99 and Blufin like this.
  7. Apr 29, 2026 at 7:17 AM
    I cant say for certain about the 2026 in ride height but in the 4th gen and 3rd gen there were different front springs for a 2wd vs 4wd which caused the 4wd to sit about 3/4" higher. The rears were the same across both models though. This is why the roof height would be the same because the rear half of the vehicle is the same regardless of the model. The front had a few different spring options, based on 2wd, 4wd, SR5, OR, ect. I remember looking back into the Tundra front springs many years back and it was something like 20 different front spring part numbers. Kinda crazy but dont just blindly expect a 2wd and 4wd to have the same front springs or ride height, because in the past they have definitely been different. Its minimal but measurable.
    I own a 2wd and a 4wd Limited and there is practically no difference in how they physically drive, react, or turn. In the past like the 90s and 2000s a 2wd would turn tighter than a 4wd but today they do not, they are all the same spindles and steering racks. I daily drive the 2wd 4R and i have been absolutely anywhere and everywhere you can imagine going and have never had it stuck including freak snow, sleet, and ice storms. The 2wd is very capable and i have never really needed 4wd to get myself up crazy steep hills or things like that. If its going to be a road car and you are in the south, a 2wd will work fine.
    The difference between a 2wd and 4wd is going to be around 300-400 pounds with the driveline, transfer case, axles ect. This is minimal on a 5200lb vs 5500lb boat anchor. You are talking about 0.1 to 0.2 tenths of a second differnce in 0-60 times. Barely measurable. Probably not worth getting hung up on.
    jlf656[QUOTED][OP] likes this.
  8. Apr 29, 2026 at 7:20 AM
    This is something to think about. I live in the deep south so a 2wd is pretty common down here. My 2008 tacoma was a pre-runner (2wd) and i found a perfect replacement in 2017 up in Boulder Colorado and called the dealer about trading mine in and they wouldnt even take it. They said it would be practically impossible for them to sell a 2wd Tacoma in their locale, they didnt even want it to send to an auction, they didnt want the hassle of any of it. Depending on your location a 2wd resale value is a real thing. In Florida they sell perfectly fine, in Massachusetts you can probably forget about being able to trade it in. Good thing to think about.
    jlf656[OP] likes this.
  9. Apr 29, 2026 at 7:25 AM
  10. Apr 29, 2026 at 7:57 AM
    jlf656
    Thanks for responding. You mention you suspect they may not have spent the time on the 2wd refinement?? Interested in further thoughts if you have them?
  11. Apr 29, 2026 at 8:05 AM
    jlf656
    Thanks for all the first hand info. Its roughly 2k difference between 4wd/2wd. However she wants the traditional 4Runner stance and having a noticeable "rake" would be an issue. I was thinking if the vehicle did have such rake I could have the front shocks changed out to level the vehicle slightly and it would be far less than the $2k+ invoice of a 4wd. Now the resale? That may or may not be as much of an issue as we live in Southern Va so years can pass without needing 4wd. Plus she hates driving in snow and works from home. We have other 4wd options. Thanks again..
  12. Apr 29, 2026 at 9:21 AM
    They make lift kits already for those vehicles and its as easy as a spacer on top of the shock.
    In the 4th and 5th gens you needed about 3/4" higher in the front of a 2wd to make it level with a 4wd. If you got a 2wd and wanted it to sit level you are going to have to lift the front end anyway because practically all of them have some "rake" now. This is so that when you load the rear the front end is not in the air and the headlights blinding oncoming traffic. If you want to raise the front end up to level you can do it easily with lift spacers just remember to get the front end re-aligned and adjust your headlights. Just measure from the ground to the bottom of the front fender. Place a floor jack under the cross member and jack it up until you see the front end where you want it to be. Just jack it up slow and back away until you find the "sweet spot" where the front end sits where you want and then measure from the ground to the bottom of the fender again. Once you figure out how high you went then just order the height of lift to match where you want the front end to be.
    Here are a few options
    1" up front
    https://www.ebay.com/itm/335801060921
    1.5" up front
    https://www.ebay.com/itm/147282526705
    2" up front
    https://www.ebay.com/itm/136946254275
    2.5" up front
    https://www.ebay.com/itm/147091098172
    3" up front
    https://www.ebay.com/itm/168080561284
  13. Apr 29, 2026 at 10:46 AM
    The 4-cyl turbo has more torque than the V6 it replaced, so don't look for 2WD as if to "compensate" for a weaker engine.
    2WD 4Runner has no reason to exist aside from vanity (or you plan to do a crazy desert prerunner build). If the climate in your region doesn't require 4WD, a crossover SUV would be superior in every measurable aspect - better acceleration, better handling, better fuel economy, lower maintenance cost, more interior room...
    Turd Ferguson and OregonTrail like this.
  14. Apr 29, 2026 at 10:59 AM
    I’ll agree to this. A highlander is a superior vehicle for a female cruising around town on the roads to the grocery store. It’s lower and easier to get into, it has far superior interior room, it’s quieter and gets much better fuel economy and has some options the 4Runner still doesn’t offer like rear seat AC controls and rear seat map lights and reading lights which are ab amazing addition for rear seat passengers and kids who wanna look at books and such on the way home. The standard electric rear gate on the highlander has been a far better piece than the manual rear gate on the 4R for 10+ years now. Luckily the limited model and upper Trims can get the electric rear gate on 4R now.
    The 4R is for someone who wants a 4R and possibly wants less of a mommy mobile. Anyone who’s wanting a better mommy mobile should take a hard look at the highlander lines.
  15. Apr 29, 2026 at 8:35 PM
    You’re going to spend $60k on a 4Runner and want to save $2k by not getting 4WD? That seems like a bad financial decision.
    Blufin and FourBelugas like this.
  16. Apr 29, 2026 at 9:36 PM
    If it's expected to stick around and they want a 4Runner specifically, skipping 4WD is perfectly rational.
    Still capable in dry conditions too.
  17. Apr 30, 2026 at 10:17 AM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    Well the whole conversation centers around the purchase of a 60k 4runner that will not go offorad, so...it's what it is.
