2024 Transfer Case Leak
Discussion in '5th Gen 4Runners (2010-2024)' started by senna, Sep 27, 2024.
  1. Sep 27, 2024 at 6:38 PM
    senna
    senna [OP] New Member
    2024 Toyota 4Runner
    Not the first post I wanted to make. Just sold my 2015 4Runner Trail edition which gave me zero issues for 9 years.
    Noticed oil on the garage floor with my new 2024 ORP (30 miles on it).
    Appears to be from the transfer case. Has anyone had to deal with this before?
    Pictures taken facing the front of the truck, so this is on the rear side.
  2. Sep 27, 2024 at 6:47 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Nope. But I'll bet the dealer has. Make them fix it. Don't let them give you some line of bullshit like "it's normal". It's not normal.
    Pentangler likes this.
  3. Sep 27, 2024 at 6:51 PM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    Take it back to the dealer and have them deal with it on their dime.
    Make sure that it is documented for any future issues that might arise. ^^
    Pentangler and TrailSpecial22 like this.
  4. Sep 27, 2024 at 10:51 PM
    Leave the drip and take it back to dealership.
  5. Sep 28, 2024 at 8:47 AM
    agreed. Get it back asap!
  6. Sep 28, 2024 at 10:04 AM
    salvojimmy
    salvojimmy New Member
    Glen Allen VA
    2022 SR5P
    No Mods Yet
    I would take a picture of the drip on the garage floor and a sample, even a paper towel wipe, with you to the dealer.
  7. Sep 28, 2024 at 10:07 AM
    Steve Berman
    Steve Berman New Member
    and a pistol
    brownersd likes this.
  8. Sep 30, 2024 at 10:19 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Take it back. Don't let them tell you it's a weep.
    TrailSpecial22 and icebear like this.
  9. Sep 30, 2024 at 10:38 AM
    dgtulsaguy
    dgtulsaguy Rocklanding Jedi Master equivalent
    22 MGM ORP long travel
    AFAIK I think that is a speed sensor or something like that on earlier models. Nothing in that spot for us, just a plug. Should be an easy fix, likely a gasket replacement. Dealer should have you covered.
  10. Sep 30, 2024 at 10:39 AM
    dgtulsaguy
    Might be that rear flange too tho. That would not be as easy a fix.
  11. Sep 30, 2024 at 11:21 AM
    No matter how hard I look at those photos, I'm not seeing the leak and/or drips being referred to. I wonder if the OP has made an appointment yet...
  12. Sep 30, 2024 at 11:48 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    In the photo on the left here's a drop in the mid- to lower left corner of the red square that has some light glistening on it. In the photo on the right, it's roughly in the vertical center, but still a bit to the left of the horizontal center.
  13. Sep 30, 2024 at 12:26 PM
    ID_Yeti
    ID_Yeti New Member
    2024 ORP
    Sorry OP, my 2024 is not doing the same. Mine was an early 2024 build as I bought in in Oct/Nov of 2023.
  14. Oct 19, 2024 at 1:19 PM
    senna
    2024 Toyota 4Runner
    Update: Dealer verified gear oil to be leaking from the transfer case. Found oil leaking from a deformed cover of the speedometer driven hole.
    Installed a new COVER SUB-ASSY, SPEEDOMETER DRIVEN HOLE 33403-35230 with o ring.
  15. Oct 19, 2024 at 4:48 PM
    ^Cool. It's a simple replacement with one bolt. My 2010 seeps from there, insufficient to form a drop.
    BTW, 2020+ 4Runners have the updated VF2CM transfer case with beefier components than the VF2BM in your 2014.
    senna[QUOTED][OP] and NV4Runner like this.
  16. Oct 21, 2024 at 10:45 AM
    Rocko9999
    2011 Limited
    That's on the transmission, not the transfer case no?
  17. Oct 21, 2024 at 11:53 AM
    Can you please site a source for that information? When I search vf2cm all I see is Tacoma Tacoma Tacoma.
    Rocko9999 likes this.
  18. Oct 21, 2024 at 12:22 PM
    senna
    2024 Toyota 4Runner
    Dealership wrote the paperwork up as gear oil leak coming from the transfer case.
    Rocko9999[QUOTED] likes this.
  19. Oct 21, 2024 at 12:45 PM
    Rocko9999
    2011 Limited
    VF2A - Lever actuated (you have the old school shifter knob) part time case (OffRoad's, ORP's, Pro's, Trail Edition's, etc)
    VF2BM - Dial (electric) actuated part time case ( TRD Sport, Anv Edition,SR5 )
    VF4BM - Dial (electric) actuated full time (torsion center dif) case ( Limited )
  20. Oct 21, 2024 at 4:48 PM
    It's mentioned in a couple of places:
    https://www.tacomaworld.com/posts/21891292/ (Jeff Lange runs a Toyota dealer and gives reliable parts information) upload_2024-10-21_19-49-31.png
    If you have access to a bootleg 2020-2024 (not 2016-2019!) factory service manual, it'll list the VF2CM transfer case in the section heading; that would be the definitive reference. The PartSouq.com part catalog also shows many different T-case component P/Ns for 08.2019 onwards - output shaft, extension housing, output flange, seals, etc. It's important if you own a 2020+ 4Runner and for example, need to replace a leaking output shaft seal. Reading a DIY guide intended for older-year 5th gens, whatever PVC pipe seal driver dimensions they recommend will be too small for the 2020+ T-case.
  21. Oct 21, 2024 at 7:04 PM
