2024 brake question.
Discussion in '5th Gen 4Runners (2010-2024)' started by WIld Wally, Jan 3, 2026.
  1. Jan 3, 2026 at 1:53 PM
    WIld Wally
    WIld Wally [OP] New Member
    2024 trd off road Silver
    LED inside lighting, Grill overlays,
    Hello all, I am a new 4 runner owner. I have had Tacoma's for many years and just got a used 2024 TRD off road (32,000 mi.). My question is about the brakes. Mine seem to have quite a bit of movement before much braking occurs. Seems like 90 % of stopping is at end of pedal travel. It doesn't grind or make any noise but you can really feel the brakes engaging. I never noticed this with any of my Tacoma's. Vehicle stops fine but seems different to me. Maybe they are all like this, I don't know. I don't know anyone who has one to ask. Any input is appreciated. ​
  2. Jan 3, 2026 at 2:01 PM
    Welcome. Might bleed the brakes with new fluid. Fluid level at the reservoir good?
  3. Jan 3, 2026 at 2:27 PM
    The 5th gen has more pedal travel than 2nd/3rd gen Tacomas. It's a consequence of Toyota putting larger front caliper pistons (and rear disc brakes) relative to the Tacoma without implementing a larger master cylinder.
  4. Jan 3, 2026 at 3:26 PM
    welcome
  5. Jan 3, 2026 at 4:14 PM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    I believe that part of the aggressive braking just before coming to a complete stop, is the computer (nanny) taking over the pedal assist functions.
    ChessGuy and TrailSpecial22 like this.
  6. Jan 3, 2026 at 11:33 PM
    StewBandit
    StewBandit New Member
    Sam
    2020 Army Green 4R TRD Pro
    My buddy's 3rd gen Tacoma feels like race car brakes compared to my 2020 4R.
    I replaced all 4 brakes and rotors with the Power Stop z36 Kit and it helped a bit. Still haven't flushed the fluid yet. Hopefully the fresh fluid will help even more.
  7. Jan 4, 2026 at 6:12 AM
    2020 Venture / 2017 Tacoma
    They are fundamentally different systems. I have both vehicles and of course driving style and manners have a big impact on performance. I prefer the brakes on the 4R over the Taco, but that's just me.
    werlyb23 likes this.
  8. Jan 4, 2026 at 6:15 AM
    Whammo
    Whammo New Member
    Southern New England
    24 Ice Cap TRDORP 4Runner
    Welcome! I traded my '21 Tacoma for a '24 T4R and yes, I did notice a different "feel" to the brakes. I don't know if that's because the taco had rear drums and the T4R has disks at all four corners, but like I said I did notice a different feel when braking. As suggested since you're the second owner, was there previous brake work done? if not doing a simple flush may be all it needs, if it even needs that. The pedal travel does seems a bit more on the 4R, but the brakes wok great so not a problem (for me) and after 10K mikes they are what I'm used to now...ENJOY
  9. Jan 4, 2026 at 2:48 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    brake pad age and even type makes a huge difference in braking behavior. as my original brakes aged they behaved as you described - the linear bite relative to pressure and travel applied to the brake pedal was reduced. almost like an on/off switch with not much in between.
    i did a standard brake job with nothing fancy or expensive and braking has become comfortable again.
  10. Jan 4, 2026 at 8:28 PM
    No. "Brake assist" only comes on during panic brake situations. You'll feel the pedal sink to the floor when the "nanny" comes on. All 2009 and newer Toyotas have this feature.
    On Tacoma World there's a widely known caveat for people looking to do rear disc brake conversions - the pedal travel gets noticeably worse because rear calipers demand a lot more flow than drum brake wheel cylinders. Seems 5th gen is basically that caveat in action.
  11. Jan 5, 2026 at 1:53 AM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    Have you checked the pad wear? I can't say I have any complaints with mine.
    If it is a 2024 with 32k miles, was it a rental in its prior life?
  12. Jan 5, 2026 at 10:12 AM
    WIld Wally
    Hello all and Thx for the replies. I think I have come to the conclusion that these brakes react differently than I'm used to. Had it in for front end alignment and had them check the brakes while there. Got rid of the shimmy and all brake pads are fine. Not close to worn out and rotors look good as well. Sounds like it's just a different feel with the brakes and I'm OK with that. Just wanted to make sure I wasn't imagining it. I'm looking forward to many adventures with my new toy. W.W.
  13. Jan 5, 2026 at 10:38 AM
    7Runner
    7Runner Forum Loiterer
    2018 Silver SR5P
    I too had the same experience with different 4Runners and Tacomas that I've had over the years. I was told by my Toyota service manager that a lot of the difference in braking characteristics has to do with the vehicle having either vacuum or hydraulic braking system. The vacuum would have quicker and more linear braking performance while the hydraulic would have more play in the pedal but have stronger braking performance. Take that for what its worth.
  14. Jan 5, 2026 at 11:04 AM
    4R4L_2023
    4R4L_2023 New Member
    24 XP UndGrnd 23 XP Mag Grey
    Staying Stock
    You need someone to assist and inspect the brake lines while you give the brake pedal some pressure. Make sure none of the lines swell up or form cracks.
  15. Jan 5, 2026 at 11:51 AM
    FourBelugas
    23 white ORP
    Two things to keep in mind
    1: 4wd 4runners weighs about 5k with a driver. That's significantly heavier than a Taco of similar year.
    2: Tacos had longer wheelbase and rear leaf springs. If you set up a much shorter and softer coil sprung 4runner with the same brake set up as a longer and more stable pickup, things can get interesting if the brakes bite as hard in the initial pedal travel at freeway speeds.
  16. Jan 5, 2026 at 12:11 PM
    Grug556
    Grug556 New Member
    Kings, Crestone Rack, Baja S8, Baja Fogs, Baja XL80s, Baja mini cubes, SPOD, ARB compressor, RCI full skids, ROAM box and stuff. ST Pros. Shrockworks sliders... GOAT armour
    I didnt like the brake mush either. Tried the following to firm it up
    Flushed and filled with new fluid. Made little difference
    Changed to Akebono pads, made some difference
    Changed discs to slotted-drilled, made additional minor improvement
    Installed new rear brake lines.
    Now truck stops on a dime. No travel. No mush nothing. Did this on my 16 limited. Compared it to my 21 Limited, no comparison. I have since put on akebonos on the 21, which helps alot. I think right pads, good new lines and discs will give you what you want. Some dont like drilled and slotted, I do for the rain and initial bite. You may have the same results with no pedal mush/creep with normal rotors, I cant say, but I can say when new with Japanese rotors both my Runners had pedal mush which I hate.
    4R4L_2023 likes this.
  17. Jan 6, 2026 at 7:58 AM
    sympley76
    sympley76 New Member
    2021 4Runner Limited
    I have a 2021 limited with slotted/drilled rotors, some aggressive pads and it definitely is improvement in the pedal feel. Downside is that rear pads wear out fast.
    Grug556 likes this.
