2022 JBL audio replacement
Discussion in '5th Gen 4Runners (2010-2024)' started by Oscar, May 15, 2025.
  1. May 15, 2025 at 12:07 PM
    Oscar
    Oscar [OP] New Member
    2022 Lime Rush TRD Pro
    interior LEDs
    influenced by this thread:
    https://www.4runners.com/threads/up...my-2022-trd-pro-full-build.41187/#post-648982
    I am looking for a possible DIY near plug n play solution.
    Take a look and see if I am forgetting a vital piece, here is my solution thus far:
    stock head unit stays
    to get the signal to RCA (depending which one I can find cheaper because tariff fun)
    PAC AP4-TY13(R.2)
    https://pac-audio.com/products/ap4-ty13
    PAC AP4-TY14
    https://pac-audio.com/products/ap4-ty14
    5 channel amplifier (not yet 100%, might get something with DSP) but:
    Kicker CX660.5
    https://www.kicker.com/CXA6605-4x90-Watt-4-Channel-Full-Range-Amp-with-300-watt-Class-D-Sub-Channel
    or buy once cry once:
    Audison AF MF
    https://audison.com/product/af-m5-11-bit/
    Kolossus 4 Gauge 4 Channel
    https://www.knukonceptz.com/product/kolossus-complete-4-gauge-4-channel-amplifier-installation-kit/
    or
    Stinger SK4241 4000 Series 4
    https://www.amazon.com/Stinger-SK4241-Amplifier-Installation-Wiring/dp/B005QEN8UO?th=1
    + RCA cables
    Karma v3 Twisted Coaxial RCA Cable
    https://www.knukonceptz.com/product...-twisted-coaxial-3-6-13-17-20-feet-rca-cable/
    this plug solution to connect to factory speaker bundle
    used near the factory amp
    PAC APH-TY04
    https://pac-audio.com/products/aph-ty04
    I know the factory amp will have to stay "alive" so the factory stereo doesn't freak.. but I think I can disconnect the speakers? Confirm?
    some speed wire (10ft?) sourced at a local stereo shop and crimps to get to amplifier under seat
    TacoTune bracket? (don't want to go through carpet) (any alternatives?) +
    Dash + front door solution
    Alpine S2-S69C
    https://www.alpine-usa.com/product/s-series-speakers-s2s69c
    If I use these do I simply wire the provided crossover near the amp?
    rear door / hatch
    Alpine S2-S65
    https://www.alpine-usa.com/product/s-series-speakers-s2s65
    some adapters for all the locations
    Metra 72-8110 dash speaker plug
    http://www.metraonline.com/part/72-8110
    Metra 72-8104 front door speaker plug
    http://www.metraonline.com/part/72-8104
    Metra 82-8146 front door bracket
    http://www.metraonline.com/part/82-8146
    Metra 82-TY1 rear door bracket and speaker plug
    http://www.metraonline.com/part/82-TY1
    Metra 82-TY1 rear hatch bracket and speaker plug
    [I need to do the math and see if this might be cheaper]
    https://trailgridpro.com/products/alpine-plug-play-8-speaker-bundle-upgrade-10-24-4runner
    + replacement sub (I found 32 different options)
    but I might get silly with:
    DD Audio Digital Designs SL608-D4
    https://ddaudio.com/series/sl600-series/?status=2&global=2
    https://www.woofersetc.com/c-23-sub...8-slim-shallow-600w-dual-4-ohm-subwoofer.html
    some sound deadener solution to do inner / outer skin of doors / sub enclosure
    https://www.amazon.com/AmazonBasics-Sound-Deadener-14-5″-10-Piece/dp/B07XMF2V77/
    debating on using something similar to:
    Install Bay IBSBF69
    https://theinstallbay.com/product/IBSBF69
    Install Bay IBSBF65
    https://theinstallbay.com/product/IBSBF65
    I have some basic tools like trim puller and some crappy crimpers/strippers.
    might add to this to the pile:
    https://www.amazon.com/Kuject-Connectors-Multipurpose-Waterproof-Electrical/dp/B09BF5P3P4
    What other supplies/solutions will I need or should look at?
  2. May 16, 2025 at 1:59 PM
    TroutMan
    TroutMan New Member
    I don't know but if you figure this out please document it here so we can all follow along and do the same thing.
    RumHamRunner73 likes this.
  3. Jul 2, 2025 at 1:42 PM
    Oscar
    interior LEDs
    well I didn't really document much because most has already been said / done
    this is the current setup:
    to get clean signal:
    PAC AP4-TY13(R.2)
    random install parts and the equipment:
    Kicker 51LX1200
    https://www.kicker.com/51LX12005
    DD Audio DC6x9a (front door / dash)
    https://ddaudio.com/d-class/component-sets/dc6x9a/
    + sound deadening
    DD Audio D-X6.5b (rear door & hatch)
    https://ddaudio.com/d-class/coaxials/d-x6-5b/
    DD Audio SL608 (in the factory JBL sub location)
    https://ddaudio.com/sl600-series/hi-def-tuned/sl608/
    Most likely over driving the DD Audio stuff in the doors, but they like the power. Time will tell.
    The next upgrade is most likely:
    Stereo Integrity SQL 12 Series 2
    https://stereointegrity.com/product/sql-12-series-2/
    and to keep the cargo area open; either a custom box on the driver side OR
    Skar 2010-2024 Toyota 4Runner Compatible Single
    https://www.skaraudio.com/products/...-subwoofer-enclosure-VS-1X10TOY4RUN-2010-2024
    but if I do this then I need more power for the sub, because the Stereo Integrity likes 1000 watts easy.
    ahhh the journey.
