2022 4runner TRD-Off road with JBA UCA Std high caster
Discussion in '5th Gen 4Runners (2010-2024)' started by Leo77, Oct 4, 2022.
  1. Oct 4, 2022 at 8:17 AM
    Leo77
    Leo77 [OP] New Member
    Hi,
    A quick question you might have the answer too:
    I currently have the 2022 4runner TRD off-road with TRD OFF-road wheels (stock wheels) : 17in x 7,5 with +15mm offset with no spacers - stock.
    My future setup is:
    - Eiback truck pro lift stage 2 with 2,75in front and 1in rear lift
    - JBA std high caster UCA
    - going from 265/70/17 wheel to 285/70/17
    - to clear the JBA UCA I understand that I need to install spacers (spidertrax 1,25in wheel spacers) - with the spacers my trd off-road wheels offset will be around the -17mm offset.
    My questions: with that setup will I be able to install the 285/70/17 tires without doing the BMC (Body Monut chop); am really trying to avoid doing that since it is a new truck (2022). I understand that I might need to trim the front fender but I really dont want to cut metal doing the BMC :)
    Please advise and any recommendations will be appreciated since on the internet there are mixed reviews. Anyone running the same Setup?
  2. Oct 4, 2022 at 9:16 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Just get a bmc! If you get it done right you can't even really tell. Also with doing a bmc you don't need as much lift to clear the 285s.
    I had a similar setup. 2.5"/1.5" lift jba uca(4.2 caster) 285 70 17 on 17x8.5 -12, and I rubbed the body mount, chopped the mount and lowered my lift to 1.5"/0". No rubbing what so ever.
    Mtbpsych likes this.
  3. Oct 4, 2022 at 11:04 AM
    Mtbpsych
    Mtbpsych New Member
    Get a BMC or stick to smaller tires. It’s all a guessing game here until a tech actually works on your rig and pieces it together. I got a BMC right away on mine.
