2021 TRD Pro Overhead console removal
Discussion in '5th Gen 4Runners (2010-2024)' started by Jennakins, Mar 17, 2024.
  1. Mar 17, 2024 at 10:19 AM
    Jennakins
    Jennakins [OP] New Member
    Jenna
    2021 $runner TRD Pro
    Hi all
    Jennakins here.
    I bought a 2021 TRD Pro last month and the overhead console started to drop down on the rear facing side. It looks like there is two pins that hold it up. I tried pushing it up and it wont stay up.
    Any idea on to correct this. The Serious radio antenna is not working either now and I am wondering if it is related. I am thinking this buy was a mistake all of a sudden. I like the truck but with 39000 miles it is a bit scary what else is around the issues area
  2. Mar 17, 2024 at 10:25 AM
    From a thread about replacing interior bulbs with LEDs:
    I started on the windshield side of the crawl control box, there are two openings to pry down on, it really did not take much force so don't over to it
    then the crawl control box will come down, disconnect it and set it aside for the moment
    there are two (I think 8mm bolts) to undo in the opening where the crawl control box was
    now pull down, there are two connectors that it will pop loose from, just don't go too crazy, this is attached by a cable you don't want to break
    you now have a panel that is loose and you can finally get to the lights and in my case a wife that came in and gently reminded me we have only made one payment so far and to knock my shit off
    on the back side there are two black connectors, turn them about a half turn and they along with the installed light will come out
    insert the LED's and for gods sake check to make sure they work so you don't have to do this again, if they do then reinstall the upper console the reverse of they way it came out
    https://www.4runners.com/threads/how-to-5th-gen-led-interior-conversion.2529/
    Good luck.
    semprenissart, steelevo and Saker like this.
  3. Mar 17, 2024 at 10:32 AM
    Jennakins
    Jenna
    The 4th picture down is the backside showing those white pins. Are they replaceable. That is where mine is hanging down from. Do not see them in a parts breakdown from Toyota
  4. Mar 17, 2024 at 11:22 AM
    TheColonelJLK
    TheColonelJLK New Member
  5. Mar 17, 2024 at 12:21 PM
    Do you have the 2 8mm bolts? It seems those would do more to secure that panel than the 2 white clips, which seem to be more for alignment than mounting...IMO, not having had that panel off personally.
    2Toys and Saker like this.
  6. Mar 17, 2024 at 12:29 PM
    Jennakins
    Jenna
    No way to get to them from the outside. Really poor design. They have a lip on them that pushes through. I would love to use screws or bolts. I will call dealer and see what they can come up with. Its a heavy piece with all the components in it.. Makes you scratch your head why o why pin clips. There is a circuit board behind the pins
  7. Mar 17, 2024 at 1:17 PM
    Please take photos and post them so we can help resolve the problem.
    I think @glwood54 is onto something!
    semprenissart and 2Toys like this.
  8. Mar 17, 2024 at 1:20 PM
    Jennakins
    Jenna
  9. Mar 17, 2024 at 1:22 PM
    Jennakins
    Jenna
    The front of the cosole is screwed in the back above the map lights is pinned. My console is now hanging down off the headliner
  10. Mar 17, 2024 at 1:23 PM
    Jennakins
    Jenna
  11. Mar 17, 2024 at 1:31 PM
    Do the pins looked damaged?
    Look at the hole where they snap in, does it look damaged or worn?
    Did you push the pins in by themselves and see if they fit snuggly?
    Come back with some answers and we will try to figure it out.
  12. Mar 17, 2024 at 1:35 PM
    Jennakins
    Jenna
    The pictures are not of my TRD The holes about are fine on mine. The pins are worn out. Someone must have pulled it down before I bought it. When I push the console up on the headliner you hear it snap in but as soon as you touch it, it falls down
  13. Mar 17, 2024 at 1:54 PM
    Suggestion since the pins are worn, if you have some heat shrink tubing that would fit over the end of the pin, you could see if that would fix your issue by heating the tubing over the end then trim off excess.
    I would try that if you can’t source the pins.
  14. Mar 17, 2024 at 2:00 PM
    Can you see any part numbers on any piece, especially the pin or control box?
  15. Mar 17, 2024 at 2:10 PM
    Jennakins
    Jenna
    i will look
    Saker likes this.
  16. Mar 17, 2024 at 3:49 PM
    Old Red
    Old Red New Member
    Washington
    It's a long list...
    As outlined in the other thread here, : https://www.4runners.com/threads/retainer-clip-for-overhead-console.15037/#post-563861, the correct part number is 63395-12150. The clip assembly comes with both male and female clip portions.
    In regards to your Sirius antenna radio, you likely have a loose connection on the back of the head unit. The radio receiver is located in the Sharkfin assembly, and is in a different location. There are two connections between the receiver and head unit. One back in the passenger D-pillar, and the other in the passenger A pillar. Both are likely intact, so check the head unit first.
    semprenissart and Saker like this.
  17. Mar 17, 2024 at 4:01 PM
    Thanks @Old Red
    That will be one of the least expensive fixes I’ve seen lately!
  18. Mar 17, 2024 at 4:01 PM
    Jennakins
    Jenna
    I ordered some. I will give it a try,, Thank you
    Saker likes this.
  19. Mar 17, 2024 at 4:04 PM
    Jennakins
    Jenna
    I will pull the radio out and check the connection. It came on and off a couple times so you are probably right
  20. Mar 17, 2024 at 4:20 PM
    Old Red
    Old Red New Member
    Washington
    It's a long list...
    Yep, that sounds like a bad connection.
    To pull the radio, remove the trim on either side of the HVAC panel by pulling them out straight towards you. They are held in by nylon clips and are reusable. Next remove the HVAC panel itself, by grabbing both ends where the dials are and pulling one side out, then the other. Again it is held in by the same clips. You want to do this gently as there is a single harness connector and clip on the back that will need to be undone. Once the panel is out, you just have 4x 10mm bolts for the radio brackets. Once those are out, pull from the bottom edge of the radio, and pop the clips, and it should slip right out. The HD radio connector will be a larger wire going into a single black plastic connector on the back of the head unit (should be located on the driver side of the back of the radio).
    Saker and Jennakins[QUOTED][OP] like this.
  21. Mar 17, 2024 at 4:23 PM
    Jennakins
    Jenna
    I traded my F150 in for the Trd Pro. I never had a thing break. This got my eyebrows raised quick. haha. My son has a SR5 I like the truck and I live in a rough back country road
  22. Mar 17, 2024 at 9:01 PM
    @Old Red to the rescue once again. Another view:
    What I didn't realize is those two clips are on the opposite side of that panel from the end with the two bolts...
    Old Red[QUOTED] and Saker like this.
  23. Mar 25, 2024 at 10:35 AM
    Jennakins
    Jenna
    Done thge clips worked great! Not the best design. The screws should have been all around.
    Now its warm day so time to take out the head unit and check the Serious antenna.
    I love this truck. Thank you all for the support. To admit I was nervouse about what else is going to go wrong next.
    The remote start takes some getting use to. The F150 was way simpler.
    Captain Spalding and Saker like this.
  24. Mar 12, 2026 at 2:38 PM
    Trees91
    Trees91 .
    Forrest
    South Dakota
    2023 MGM SR5p
    Sorry this is an old thread, but I'm having the same issue.
    When you replaced the white plastic pins did you also replace the back piece it clips in to. Thanks!
  25. Mar 12, 2026 at 3:10 PM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    Yes. Replace them both.
  26. Mar 13, 2026 at 8:44 AM
    If you end up doing the repair, I’m curious if the black piece is the thing that loosened, or if it was the white pin that was loose within the black pin. Please post back your observations, it will be useful to others in the future.
    glwood54 likes this.
  27. Mar 13, 2026 at 10:08 AM
    Since they come as a set, it makes sense to use them both.
    TrueTexas[QUOTED] likes this.
  28. Mar 13, 2026 at 11:11 AM
    TrueTexas
    The Woodlands, TX
    I ordered some of these to keep on hand a while ago. Haven't needed them but glad I have them.
    Looking at how they work (like a body clip) I would venture a guess that the insert is easier to damage than the pin itself.
  29. Mar 19, 2026 at 8:27 PM
    Trees91
    Trees91 .
    Forrest
    South Dakota
    2023 MGM SR5p
    Well I messed with my overhead console and pushed it up about as hard as I could. It's been staying up for the last few days. Will get some clips to have on hand when it inevitably flops down again.
  30. Apr 9, 2026 at 5:04 PM
    Trees91
    Trees91 .
    Forrest
    South Dakota
    2023 MGM SR5p
    Overhead console fell down again. Suprise suprise. Got parts ordered and just did the fix. Maybe 10 minute job.
    Open sunglasses holder and remove both 8mm screws.
    Console comes down, unplug so it's easy to work on.
    Slide out white plastic clips and replace with new. Part numbers if anyone needs.
    Hardest part of the job was getting the old black pieces out. I just used a needle nose and was careful not to mess up the metal piece they clip into.
    Push it into place and install 2 8mm screw and you're done. Hopfully it stays...
