2021 Limited - starting small....
Discussion in '5th Gen Builds (2010-2024)' started by Harringbr99, Jan 19, 2023.
  1. Jan 19, 2023 at 6:40 AM
    Harringbr99
    Harringbr99 [OP] New Member
    Brian
    Kentucky
    2021 Barcelona Red Limited
    This is my first thread and my diary of where things started and where they are now.
    Mods:
    • TRD Off Road - 17"x7.5" rims - EBAY
    • Falken Wildpeak AT3W - LT 275/70R17 load C
    • BudBuilt Sliders with Kickout Diamond Plate - Textured Powder Coat
    • Front Facia Trim - 8 inches
    • Rocker Panel - Straight Trim
    • BudBuilt Hidden Winch Mount (with recovery points)
    • Badland Apex 12,000 lbs Winch
    • Cornfed 2"/1" X-REAS lift
    • BudBuilt - Rock Armor 3/16” steel skids.
    • Custom Tube Bumper .120 wall DOM Steel. With hoops.
    BEFORE
    CURRENT
    ladebakk, Forever, erfer1 and 5 others like this.
  2. Jan 23, 2023 at 2:41 PM
    jstam316
    jstam316 New Guy
    Kansas City
    2014 Black Limited
    Incredible chop on the front & rockers, looks great. I'm hoping to get around to some aesthetic work on my Limited come better weather in March. Did you do the cutting yourself?
    ThatOneGuy and Harringbr99[OP] like this.
  3. Jan 23, 2023 at 3:42 PM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    Looks good. If you have a pic can you show a front shot too?
  4. Jan 23, 2023 at 7:52 PM
    Harringbr99
    Brian
    Kentucky
    Here is a front 3/4 shot. I'll try to get some other good angles.
  5. Jan 23, 2023 at 7:56 PM
    Harringbr99
    Brian
    Kentucky
    Other angles
    Well69 and jstam316 like this.
  6. Jan 23, 2023 at 8:06 PM
    Harringbr99
    Brian
    Kentucky
    I didn't do any of the cutting myself. I didn't have the angle grinder, the experience, or the bravery to do it myself.
    The fabricator/owner at 5eight Offroad and Fab here in Louisville did it as part of the rock slider install. We talked about what I was wanting with the straight across rocker panels cut and a front bumper chop that followed the lines of the plastic, kept the sensors intact and DIDNT ecpose the Aluminum crash bar. We had to drop the cut about 1 inch from my original spec because it would have exposed the crash bar.
    Also we hit the crash bar with some black enamel paint to make it fade into the background if viewed from side or below.
    ThatOneGuy, Icetenka and Keith E. like this.
  7. Jan 23, 2023 at 8:14 PM
    jstam316
    jstam316 New Guy
    Kansas City
    2014 Black Limited
    Well, it looks excellent. They did great work and you have good taste in going for this. I'm definitely taking a few tips. Black paint ready for the crash bar is a good one. Are you planning to install a proper skid there up front now? or will you keep it as is? I think I'm going to pull the trigger someday and do it myself because I lack the finances to do an SR5/TRD bumper swap or even to pay someone for the cutting haha. My main hesitation is that I only have highway tires yet so it could look a bit funny till I move toward ATs.
  8. Jan 23, 2023 at 8:28 PM
    Harringbr99
    Brian
    Kentucky
    tldr; yep skids are next.
    So the mods I've done are all based on usage.
    I cut the front facia because on the first trail ride I popped the the retaining screws at the wheel wells and bent the metal clips and scrarched the hell out of the bottom plastic.
    Next trip I put a half-bowling ball sized dent in the front skid. Honestly that doesn't scare me, but what does scare me is the 6 inch plastic cube that actuates the center diff lock and Tcase. So I'll probably go with skids next.
    A lift would be fun but xreas hasn't crapped out on me yet, and I can't justify ripping out a $3,500 system to put in a $2,500 minimum suspension lift when armor is so much more important IMO.
    So the lift will probably come after I add a hidden winch mount and winch. That way I know what springs and shock valving I need based on rhe specific weight I've added.
    Well69 and Singleminded like this.
  9. Jan 23, 2023 at 8:32 PM
    Harringbr99
    Brian
    Kentucky
    And Thanks for the kind words about the look. Since I bought it 2 years ago, I've been reading and reading trying to find the right way to accomplish it.
  10. Jan 23, 2023 at 8:45 PM
    Harringbr99
    Brian
    Kentucky
    New pics added to the thread.
  11. Jan 23, 2023 at 8:51 PM
    HazOpRed
    HazOpRed 22' TRDOR
    Cut looks great. Black it out and it would be awesome. I really like the look of a chopped limited
    Harringbr99[OP] likes this.
  12. Jan 24, 2023 at 2:31 AM
    2018 Limited
    BDR
    2018 Limited
    Thanks much for posting the pics. Looks great. Keep us updated on your work if you have the time. I’m interested as I too have a limited. Thanks again.
  13. Jan 25, 2023 at 11:07 PM
    mtnslyr
    mtnslyr New Member
    Very bold build from a Limited trim. Respect. Since you chopped off the front rocker, why not install a proper front recovery points. It'll not only look good, I've also read the tie down points are not very reliable for recovery.
  14. Jan 26, 2023 at 4:45 AM
    Harringbr99
    Brian
    Kentucky
    I thought somebody might "peek" those D-rings attached to the factory tie down points.
    The Apex Overland Recovery Points are on order.
    My only concern with adding them up to this point has been with making sure they will work with the Hidden Winch Mount I plan to add. I think they will all clear because it's not like full or hybrid bumper, but need to get all the parts in one place and make sure they play nicely together.
  15. Jan 26, 2023 at 5:30 AM
    Ironguy New Member
    Nice planning and pre-planning.
  16. Jan 26, 2023 at 9:05 AM
    2018 Limited
    BDR
    2018 Limited
    I’m interested in the recovery hooks as well but haven’t had a chance to look them up as well as crawl under my vehicle and see what is involved. I would appreciate any feedback you can provide once you get to it.
  17. Feb 20, 2023 at 5:52 PM
    Harringbr99
    Brian
    Kentucky
    Harbor Freight Presidents' Day sale...
    Couldn't pass it up. $500 out the door. Ordering the BudBuilt hidden winch plate, with recovery points.
  18. Mar 3, 2023 at 8:51 AM
    Harringbr99
    Brian
    Kentucky
    Winch and 2"/1" Lift installed.
    Loving the look so far. Got to work with the winch in the driveway for at least 1 test pull.
    Can't wait to see how it does on the trails!
  19. Nov 21, 2023 at 11:41 AM
    dsal6
    dsal6 New Member
    2020 nightshade blizzard pearl
    Love your build, the chop and hidden wench looks amazing. I was curious how the ride is with the cornfed 2/1 lift? I am about to install the same set on my 2020 nightshade.
    Harringbr99[OP] and Well69 like this.
  20. Nov 21, 2023 at 12:44 PM
    engineer90
    engineer90 New Member
    NJ
    Hate to be a hater, but why not just get a SR5 or OR instead?
    Cool build tho!
    2016Pro and Harringbr99[OP] like this.
  21. Nov 21, 2023 at 1:32 PM
    Well69
    Well69 New Member
    2022 Limited 4Runner
    Be sure to extend the synthetic rope all the way and tighten under a small load to break it in. Great choices
    How's the ride change with the cornfed lift?
    Budbuilt's hidden winch is awesome. I have it along with budbuilt sliders and armor from him and the xreas is rocking along.
  22. Nov 24, 2023 at 9:19 AM
    Harringbr99
    Brian
    Kentucky
    Great question, and I know there's no hate.
    I got the Limited because It was the only one available at the time I needed a vehicle. I would have preferred an ORP for the Rear Locker, but I've got a big family and needed the 3rd row. And the deal I got on the Limited, New at $45,900 was too good to pass up. I could justify it with the full-time 4wd and 3rd row as a "practical" "family vehicle".
    engineer90[QUOTED] likes this.
  23. Nov 24, 2023 at 9:23 AM
    Harringbr99
    Brian
    Kentucky
    I've not noticed any significant negatives to Off-Road or On-Road manners. Just a bit taller, way less rake, but enough not to squat. And that was my whole goal.
    It does amazing on the trails. Most of the front lift comes from the preload collar, so you will notice a bit of extra stiffness. I got it because of the additional 90 lbs I was putting on the front bumper with the winch and hidden winch mount, so the Pre-load doesn't really make my ride harsher.
  24. Nov 24, 2023 at 9:40 AM
    Harringbr99
    Brian
    Kentucky
    Skids arrived from BudBuilt 20 minutes ago. Can’t wait to get these painted and on the 4Runner. Last oil change we had to cut bolts on the OEM skids because a hard hit had broken the welds on the nut holding them. OEM skid is being held in place with zip ties.
  25. Nov 24, 2023 at 2:01 PM
    Harringbr99
    Brian
    Kentucky
    Good point on extending the synthetic rope and spooling under tension.
    Since you and I have the same front setup with the winch and winch plate, I think you'll find almost NO difference in ride quality after adding the lift. I've got about 12,000 miles on the lift since Feb and haven't been disappointed with it.
    How is your experience with the Bumper?
    Well69[QUOTED] likes this.
  26. Nov 24, 2023 at 2:50 PM
    Well69
    Well69 New Member
    The rear bumper, armor, sliders, and front hidden winch don't seem to affect the ride quality or anything.
    Thank you for letting me know about the ride quality. I'm going to join you in the cornfed lift soon. I need to do a write up of all the things I've done/modded and how to make use of annoying piles of extra money.
  27. Nov 24, 2023 at 3:01 PM
    Well69
    Well69 New Member
    The front hidden winch mount, as you know, is indispensable. I've gotten a lot more use out of it than anyone (including me) expected. I don't off-road much (ever), but it's taken down limbs, cleared a road, pulled up shrubs, and loaded a trailer.
    The rear bumper is just baller. No one cares or notices except for me and two other dads who have land cruisers. I smile inside every single time I see it. It's low key amazing, kinda like Bud himself.
  28. Feb 17, 2024 at 9:31 AM
    Harringbr99
    Brian
    Kentucky
    Big Red got a Brazilian Butt Lift!
    Custom fab tube rear bumper - 1.75” OD .120 wall DOM.
    • Receiver Hitch relocation.
    • 7” height increase on exit.
    • Center of receiver is 24” from the ground. (Before was 17”)
    • 7 welded attachment points with frame.
    • Weight gain only about 25 lbs.
    When wheeling the spare will be ratchet strapped to the floor. Exhaust is getting rerouted to side for high clearance.
    captrussia253 likes this.
  29. Feb 18, 2024 at 12:03 PM
    74Runner
    74Runner New Member
    2024 Underground 4Runner Limited
  30. Feb 18, 2024 at 9:46 PM
    Harringbr99
    Brian
    Kentucky
    Hitch mount was relocated 7” higher than original, but still exists. So your idea of a hitch mounted tire carrier would certainly be an option. I like that convertibility. I like to kinda run stealth. Something to consider for sure. Thanks!
