2021 First oil change question
Discussion in '5th Gen 4Runners (2010-2024)' started by mf7365, Dec 22, 2021.
  1. Dec 22, 2021 at 4:45 PM
    mf7365
    mf7365 [OP] New Member
    2006 4Runner V8
    I unscrewed the oil pan bolt and there is a blue circular gasket(?) around the hole still on the oil pan. I tried knocking it off with a wrench but it is not moving. Do I just need some more force or is this supposed to be there? I am planning on installing a Fumoto oil drain valve and it has a gasket already. I cant believe this gasket would go up against the one that seems stuck on my oil pan.
  2. Dec 22, 2021 at 5:06 PM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘22 ORP LR
    It needs to come off. Take a flat screw driver and give it a little pop. They can seize on there occasionally.
    GoSlow, acet7, Toy4X4 and 2 others like this.
  3. Dec 22, 2021 at 6:13 PM
    TRD8
    TRD8 New Member
    North Georgia
    I just changed my oil for the first time and experienced the same thing. I personally wouldn’t use anything metal that might gouge the oil pan. I used a plastic scraper, gave it a little tap, and it popped right off like Squeaky said.
    wgw, A&P and Toy4X4 like this.
  4. Dec 22, 2021 at 7:15 PM
    I use a pick to get the crush washer off.
  5. Dec 22, 2021 at 7:55 PM
    mf7365
    2006 4Runner V8
    Ok. I did exactly what everyone said. Took a hard plastic scraper and used a little more force. It popped right off. So my second question is this: I did this oil change today at 5,300 mi. which is obviously ahead of the Toyota maintenance schedule. Should I perform the scheduled maintenance reset procedure on the dash computer?
    Toy4X4 likes this.
  6. Dec 22, 2021 at 8:13 PM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    I would but up to you. I log every change I do on my 4Runner so the maintenance light is just an added bonus.
    Toy4X4 likes this.
  7. Dec 22, 2021 at 8:24 PM
    kmeeg LionRunner
    Sorry for the out of topic question.
    Ain't we suppose to do oil changes with dealership for 3yr/36K miles to keep the warranty? I don't know what is the process. Asked the question to learn.
    I think I paid around $85 for the oil change at around 1000miles.
  8. Dec 22, 2021 at 10:01 PM
    Nope. Just document it in case there just happens to be an engine issue.
    suaveflooder and kmeeg[QUOTED] like this.
  9. Dec 22, 2021 at 10:28 PM
    Double nope. That said if you screw up and forget to tighten the drain bolt and it all drains out, it’s on you.
    Also, isnt the drivetrain warranty 5yrs/60,000 miles?
    kmeeg[QUOTED] and Toy4X4 like this.
  10. Dec 22, 2021 at 10:32 PM
    I milked that stuck gasket for like 50,000 miles on my Sienna then I finally put a new one on. My 18 Highlander still has the factory washer, as does the 4runner. They dont leak if torqued correctly. Im so lazy lol
  11. Dec 22, 2021 at 11:46 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    '24 ORP
    I'm like 90% sure I'm not even running the gasket!
  12. Dec 23, 2021 at 2:42 AM
    5K oil interval is where we are, and the Fumoto went on right away, you'll like it for ease of draining oil.
    4R21 and kmeeg like this.
  13. Dec 23, 2021 at 7:05 AM
    wgw
    wgw New Member
    2022 runner
    so Just curious does anyone capture a sample and send it out for testing? I am a retired facilities manager and for 30+years always tested the oil on all rotating equipment as well as my truck..its great at the first oil change as you will have the history of ur engine, with many data points...wear metal , TAN,base numbers, fuel dilution etc.... It will also tell you based on real data when you really need to change oil/filter, rather then a number established by the manufacture .....
    4R21 and Toy4X4 like this.
  14. Dec 23, 2021 at 7:16 AM
    Yes.
    Many people use Blackstone for oil analyses.
    Toy4X4 and wgw[QUOTED] like this.
  15. Dec 24, 2021 at 5:46 AM
    peter2772000
    peter2772000 New Member
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Jesus LOL
  16. Dec 24, 2021 at 10:48 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Lots of people use Blackstone for an analysis ($30) at every oil change. They love tracking and discussing their results. But I’ve never heard anyone say that it’s a good thing they did it because they caught a problem in time before it caused damage. Maybe in some old domestic cars it’s useful, and of course industrial machinery and big diesels. But who’s ever had oil analysis find a problem in a 4Runner?
  17. Dec 24, 2021 at 12:05 PM
    sarmad
    sarmad New Member
    sarmad
    4 runner SR5 PREMUIM 2020
    Any suggestions for the oil type for the 4 runner . should be 0-20 and which brand is good . and how long time to change the oil . and any one can help with check list main maintenance for the 2020 .SR5
  18. Dec 24, 2021 at 12:49 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Singleminded and LandCruiser like this.
  19. Dec 26, 2021 at 6:08 AM
    wgw
    wgw New Member
    2022 runner
    , 1... its about the trend of many points in the engine.... 2.... the current condition of the oil and how much useful life remains that is as important....
  20. Dec 26, 2021 at 8:58 AM
    2016Pro
    I use supertech or anything I find on sale that is cheaper
  21. Dec 26, 2021 at 9:56 AM
    TrailGuy2016
    TrailGuy2016 New Member
    2016 Trail Premium, Silver
    Likewise. There isn't a better deal than the Havoline box of 0w20 6qt.
    2016Pro[QUOTED] likes this.
  22. Dec 26, 2021 at 11:47 AM
    icyhotahs
    icyhotahs NEw mEmBER
    Samuel
    Sacramento, CA
    2022 ORP Super White
    Method 703 - Nitto G2 - C4 Ladder - UpTop Rack - EIbach 2.0 Coilovers & Load Levling Kit (250) Victory Strike Sliders - Dometic 55 - EcoFlow Delta
    Bro over in Ohio inciting riots still
    LandCruiser and MeefZah[QUOTED] like this.
  23. Dec 26, 2021 at 2:29 PM
    kingrex
    kingrex New Member
    2016 Trail
    I’ve reused the gasket before, but have since bought a package of them for when I forget to order prior to changing the oil.
  24. Dec 26, 2021 at 4:34 PM
    Matt83
    Matt83 New Member
    Northeast
    Change your oil every 1000 miles with Toyota Genuine Filters and Toyota Genuine 0w/20.....can not be too safe with these finicky engines.
    suaveflooder and nimby like this.
  25. Dec 27, 2021 at 3:51 AM
    MeefZah
    Lexington, Ohio
    '24 ORP
    LOL this guy with the jokes
    acet7, Tmiesowicz, ElectroBoy and 2 others like this.
  26. Dec 27, 2021 at 4:12 AM
    peter2772000
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Seriously Matt, these engines are anything but "finicky". And while I'm in agreement that oil changes are important, 1k mile intervals is not only impractical but needlessly expensive as well. Hell, I'd be replacing my oil at every 3 tanks of gas.
    I installed a remote oil filter kit which includes a honking big (compared to OEM) old-style oil filter. I run synthetic Amsoil Signature Series 0W/20 in late fall/winter/early spring and 20W50 the rest of the time. Just me and definitely not the be-all-to-end-all formula, but it works for me.
    AND NO: The Fram filter was used for fitment only. I heard about how bad they really are.
  27. Dec 27, 2021 at 4:42 AM
    MeefZah
    Lexington, Ohio
    '24 ORP
    Pretty sure dude was joking
    Firefly21 likes this.
  28. Dec 27, 2021 at 5:11 AM
    2016Pro
    :laugh:
    Firefly21 and LandCruiser like this.
  29. Dec 27, 2021 at 5:12 AM
    2016Pro
    Lol
  30. Dec 27, 2021 at 2:22 PM
    peter2772000
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    *Hangs head in shame* LOL
