2021 Blinding Headlights - what to do?
Discussion in '5th Gen 4Runners (2010-2024)' started by CoAz2k, Jul 11, 2021.
  1. Jul 11, 2021 at 4:33 PM
    CoAz2k
    CoAz2k [OP] New Member
    2021 4R SR5
    In short, the headlights on my '21 4runner are too bright. They are annoying to me and others.
    This weekend, I was towing about 2,500 lbs. At night.
    I had several vehicles flash their high beams at me. I noticed that highway signs were impossible to read until I got close enough that the signs were out of the main beam of my headlights.
    What good options do I have to safely operate at night?
    Yes, the headlights were on low. DRLs are not bright enough for night use.
    My '13 Tundra had the ability to steer the headlights up/down from an adjustment wheel in the cab.
    Thanks in advance.
  2. Jul 11, 2021 at 4:39 PM
    POWERPLANTHOMER
    POWERPLANTHOMER New Member
    JAMES
    2020 TRD OR PREMIUM, 2021 TRD OR PREMIUM KDSS
    I love the headlights on my ‘21, there is an adjustment screw to adjust for hauling. I didn’t like the height stock on my ‘21, it was low a bit, I adjusted it up.
    A&P likes this.
  3. Jul 11, 2021 at 5:07 PM
    Ebadai98
    Ebadai98 New Member
    18 TRD Off Road
    I’ll trade your LED headlights for my OEM halogens with H9 lol
    POWERPLANTHOMER and Singleminded like this.
  4. Jul 11, 2021 at 5:07 PM
    CoAz2k
    2021 4R SR5
    Yep. I considered that.
    Any other ideas?
    Ebadai98 likes this.
  5. Jul 11, 2021 at 5:18 PM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    You could put a resistor in the circuit to limit the current and dim the lights. You would have to do a little research into which resistor is the correct rating, but it wouldn't be difficult. Don't know what it does to warranty though.
    Using DRLs as headlights is illegal in most states because the tail lights aren't on, not a good solution.
    POWERPLANTHOMER likes this.
  6. Jul 11, 2021 at 5:25 PM
    Beachguy
    2021 SR5 Premium
    Just have them adjusted down a little. It’s no big deal.
    grizzlypath, POWERPLANTHOMER and A&P like this.
  7. Jul 11, 2021 at 6:21 PM
    POWERPLANTHOMER
    JAMES
    You cannot dim leds like that.
  8. Jul 11, 2021 at 6:24 PM
    GrayGhost
    GrayGhost New Member
    Dave
    2020 orp - sold
    Rear adjustable springs for towing.
    grizzlypath likes this.
  9. Jul 11, 2021 at 6:27 PM
    POWERPLANTHOMER
    JAMES
    I drove back from the Mt.Princeston/Hancock area late Friday night, 285 to 24 and I was so happy the leds are bright, and that I changed the brights to Leds (with drl driver) it’s night and day safer for seeing animals. The auto bright control sucks in town, but out in the dark it works great!
  10. Jul 11, 2021 at 6:39 PM
    CoAz2k
    2021 4R SR5
    I agree its not a big deal to adjust them. I'm curious if there are other or better ideas.
  11. Jul 11, 2021 at 6:42 PM
    CoAz2k
    2021 4R SR5
    I was on Hwy 160 between Walsenberg and South Fork, CO and then also I-25.
    The couple of hundred pounds of weight on the the tongue made enough the difference to shine the lights higher up. I haven't experienced this problem before towing this weekend.
  12. Jul 11, 2021 at 7:03 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    You can have the dealership aim your headlights per manufacturer specification to get you back to OEM specs. Then I would check into why you're sagging, adjust your trailer if possible, (weight distribution, hitch height, ect.)
    If none of that works look into heavier springs. They're not that expensive, and are relatively easy to install. If you're sagging while towing, you need them. The stock rear springs sag with the lightest amount of weight.
