2020 fuse box questions
Discussion in '5th Gen 4Runners (2010-2024)' started by Ianv18, Aug 4, 2020.
  1. Aug 4, 2020 at 7:39 PM
    Ianv18
    Ianv18 [OP] New Member
    2020 Trd orp
    Heritage grille blackout and led
    I have grille lights installed which I had to force the fuse box closed due to the add a fuse but if I wanted new headlights that also run in inj is there another location I can put the input to get them to turn on when the car turns on?
  2. Aug 4, 2020 at 9:05 PM
    Json323
    Json323 New Member
    Jason
    East Los Angeles
    2020 4Runner SR5 4x4 MGM
    Method Racing Wheels 702 w/BFG KO2, TRD Pro aftermarket grill w/Raptor lights, 55w HIDs 6000k,
    Which headlights are you referring to? It all depends if you want them to come on when you turn on the truck or when you turn on the headlights. Do they have a DRL that you are trying to wire?
  3. Aug 5, 2020 at 6:34 AM
    Ianv18
    2020 Trd orp
    The alpha rex luxx they have the drl option that would go in the inj slot so wondering if there is another inj I can use
  4. Nov 8, 2020 at 10:03 AM
    dcgarcia5
    dcgarcia5 New Member
    2020 4Runner OR
    Can I tap grill lights to DRL?
  5. Nov 8, 2020 at 11:20 AM
    dcgarcia5
    2020 4Runner OR
    Which fuse is it.
  6. Nov 8, 2020 at 1:44 PM
    dcgarcia5
    2020 4Runner OR
    How I find #11, is top-down left-right? Is it a separate fuse for DRL or one for all headlights ?
  7. Nov 8, 2020 at 3:06 PM
    dcgarcia5
    2020 4Runner OR
    Got it thanks!! I'll give it a try
  8. Nov 8, 2020 at 3:29 PM
    jmc22
    jmc22 New Member
    A&P likes this.
  9. Feb 25, 2021 at 11:38 AM
    itsmeomarj
    itsmeomarj New Member
    omar
    2021 Lunar Rock 4Runner TRD PRO
    None yet
    Hey guys. I have the raptor headlights from the video above. installed the headlights and pushed the wiring to the inside fuse box. The inside fust box is full and I was wondering if anyone can help me figureout which fuse slot I can use to connected my raptor headlights to turn on with they key. My fusebox used the same chart as the one above but the interior fuse box is full. Can anyone help me.
    stunner_4runner likes this.
  10. Feb 25, 2021 at 1:53 PM
    stunner_4runner
    stunner_4runner New Member
    Raymond
    2020 4Runner SR5 4WD
    Radflo Stage 3 Lift Kit- 2.5 Extended Front & Rear RR Adjustable Coilovers Total Chaos Upper Arms ARB rear medium springs 3” Aiden James Switchback Fog Bezel Lights 4Runner Lifestyle Amber Raptor Grill Lights Trail Standard Offroad Satin/Matte Black TSO Pro Grille with 4Runner Letters Baja Designs WC Amber Fog Lights Baja Designs XL Sport Amber Ditch Lights with Cali Raised Ditch Light Brackets 2 Baja Designs LP6 Amber Behind the grille lights 2 SNS Designs 5" Amber Behind the grille lights N-FAB behind the grill lighting mount Pedal commander Jet Performance Mass Flo Air Sensor 315/70/17 Cooper STT Pro Fuel Rims Custom Magnaflow exhaust with Series 50 Flowmaster Muffler Alpharex Nova Midnight Black Headlights AFE Momentum GT Dry Filter CAI BantamX Touchscreen for Universal with sPOD Alpharex PRO-Series LED Tail Lights Jet Black Mid-Atlantic Off-Roading Full Length Roof Rack Outgear Solutions Low Key Front Bumper 4WDKING 30’ LED Light Bar for the Bumper RSG Front Skid Plate
    Use the ACC slot in the inside cabin fuse box. Take out the fuse and put the grill lights fuse tap into that fuse slot. That’s what I did and works when the car is on.
  11. Jun 30, 2021 at 3:30 PM
    moodster
    moodster New Member
    I added a add a fuse to my INJ for alpha rex DLR and my runner won't start. Just cranks. I remove the add a fuse and put fuse back and it starts just fine. Whats going on?
  12. Jun 30, 2021 at 3:40 PM
    stunner_4runner
    Raymond
    @moodster Which AlphaRex headlights do you have?
  13. Jun 30, 2021 at 3:41 PM
    moodster
    moodster New Member
  14. Jun 30, 2021 at 3:47 PM
    stunner_4runner
    Raymond
    Do you have any other lights like Raptor grille lights or Fog Bezel lights? Just trying to pinpoint the issue. I have the AlphaRex Nova Headlights, Raptor Grille lights, and the Aiden James Switchback Fog Bezel lights. I had to t-tap the switchback fog bezel lights with my AlphaRex Nova DRLs. Have the fuse in the 10INJ in the fuse box under the hood and have the Raptor Lights connected to the ACC slot in the cabin fuse box.
  15. Jun 30, 2021 at 3:49 PM
    moodster
    moodster New Member
    No I don't have any other lights.
  16. Jun 30, 2021 at 3:50 PM
    moodster
    moodster New Member
    It worked for a day and a half then this happened?
  17. Jun 30, 2021 at 3:52 PM
    stunner_4runner
    Raymond
    Did you blow the fuse? Is there a short in the connection? Check those! Do the actual headlights turn on?
  18. Jun 30, 2021 at 3:57 PM
    moodster
    moodster New Member
    actual headlights work, fuses look ok. I don't think there's a short in connection..not seeing one. what other options for wiring DRL's?
  19. Jun 30, 2021 at 4:13 PM
    stunner_4runner
    Raymond
    Dang, not too sure on any other methods of wiring the DRLs. The only other thing I could suggest is using another fuse slot. Not too sure which slots you could use though. I want to say I saw some other posts on other slots you could use, but you would have to look for those on here.
  20. Jun 30, 2021 at 4:17 PM
    moodster
    moodster New Member
    Thanks I've been looking with not much luck. Id rather not go through the firewall but may. Read the STOP fuse in engine compartment but can't get the add a fuse to fit?
  21. Jun 30, 2021 at 4:52 PM
    moodster
    moodster New Member
    Well I ran inside to fuse acc and all is good. Not sure what was wrong w/INJ in engine compartment. But all seems good now..Thanks for input stunner.
  22. Jun 30, 2021 at 5:05 PM
    stunner_4runner
    Raymond
    Oh heck yea. That is great! Should work just fine in the ACC slot.
  23. Mar 21, 2022 at 6:51 PM
    Nevik8
    Nevik8 New Member
    2022 4Runner add a fuse too tall for engine fuse box cover, anyone have any suggestions
  24. Mar 21, 2022 at 9:22 PM
    BionicRandy
    BionicRandy New Member
    Randy
    TX Hill Country
    Lots of goodies
    Heat gun + pressure
    Nevik8[QUOTED] likes this.
  25. Aug 21, 2023 at 9:07 AM
    Robs Runner
    Robs Runner New Member
    2020 TRD Off Road
    New to this forum, and to mods. Got Raptor lights from 4Runner Lifestyle, install went easy. The fuse is my problem. I’ve gone through all of the in-cabin fuses and have either had no power to the lights, or I get power, but other functions fail. My latest attempt is in the ACC fuse, but my center screen/radio/nav went dark. Before I pull it back through the firewall and attempt the INJ fuse under the hood, is there any other option??
    I’ve seen some pics on here with two fuses attached to the fuse plug-in, whereas mine has the one 10a fuse the harness came with and the other slot on it is empty.
    suggestions? Thanks!
  26. Aug 21, 2023 at 1:58 PM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Don't use Fuse Tap from 4Runner Lifestyle (its too long, prevents closing Engine Fuse box)... Get a low Profile Mini Fuse from Advance Auto Parts 7.5.
    Tap into INJ
    Ground to Screw near Battery terminal.
    Note - am just a newbie
    SKUNKD likes this.
