2020 4Runner losing power while driving
Discussion in '5th Gen 4Runners (2010-2024)' started by Skorp, May 23, 2022.
  1. May 23, 2022 at 10:32 AM
    Skorp
    Skorp [OP] New Member
    Bryan
    2020 4Runner TRD Pro
    Hello everyone. Hope this is the right place. So I am having an issue right now with my 2020 4Runner TRD Pro. Randomly sometimes while driving it will suddenly lose power with all the lights go on the dash and then turn off. I am able to still break and once I come to a complete stop, the engine will turn off. Thought it was the battery, but the battery is the right charge and secured tight with the terminal cables. What else could be wrong here? It's pretty scary now driving it so just gonna keep it at home. Dealer says could be fuel pump or an electrical issue with the computer, but that is hard to believe for only 36k miles. Have to wait a week for an appointment. Anyone had a similar issue?
  2. May 23, 2022 at 10:39 AM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    did you check for recalls or TSBs?
  3. May 23, 2022 at 10:54 AM
    Did you get the fuel pump replaced per the safety recall?
    Not sure if you’re model year was included.
  4. May 23, 2022 at 10:54 AM
    There was a fuel pump recall on some years.
    So, once you stop, and it shuts down, will it restart and act normal again?
  5. May 23, 2022 at 10:57 AM
    Skorp
    Bryan
    Thanks for the replies. No, I did not get it replaced. Didn't know there was a recall. If I looked it up now it looks to be affected for 2018 - 2019 and not 2020 unless I am mistaken? Guess I'll dig more into my VIN right now.
    Yes, once the engine shut up, I just push the start button and it goes back to normal.
  6. May 23, 2022 at 11:00 AM
    TrailGuy2016
    TrailGuy2016 New Member
    2016 Trail Premium, Silver
    I would show up to the dealer without an appointment, and tell them to figure it out if it still qualifies for the warranty. You may not due to mileage.....
    ChessGuy, ESCT4R and Thatbassguy like this.
  7. May 23, 2022 at 11:18 AM
    That's weird. Hopefully something simple. I might do what @TrailGuy2016 said and just take it to a dealer. I would hope it would be covered under the powertrain warranty. They should have to give you a loaner.
    After I got my fuel pump recall performed, I lost power on the freeway. I limped it to a gas station, but it would not restart. They had improperly installed an outing.
  8. May 23, 2022 at 11:34 AM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    The pump recall did end before '20.
    It would be odd if the pump were going out to not throw one or more codes - a/f, fuel pressure, pump duty cycle or something. Maybe an electrical gremlin with an easy fix, I hope.
  9. May 24, 2022 at 6:19 AM
    Cardork
    Cardork New Member
    Redwood Curtain
    2021 Venture
    That sounds downright spooky. If you all of a sudden you lose power, the results could be catastrophic.
    Please keep us posted and wish you the speediest of resolutions.
    Moon Landing and Thatbassguy like this.
  10. May 24, 2022 at 6:36 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Sounds electrical.... Happened to me once on freeway (old van). The battery cable was intermittently loose. In another salvage title vehicle that i drove... it loses power when auto headlight comes on. Weird.
  11. May 24, 2022 at 6:38 AM
    Just throwing this out there - do you have rodents (mice, rats, squirrels) where you live? Symptoms sound like chewed wires in the engine bay...
  12. Jul 4, 2023 at 6:50 AM
    Joefrasco
    Joefrasco New Member
    2019 limited
    Hello all, I was wondering how this turned out? What was the fix?
    I am having the same issue on a 2019 limited. About 48k miles. It will randomly lose all electrical power while driving. The engine will die and restart at higher speeds. A few times it died and rolled to a stop then had to restart. The whole car goes black with everything off. It’s completely random and doesn’t really have a pattern of any kind. no other issues, no error codes.
    One dealership suggested a full electrical diagnostic service that was going to cost a couple hundred $$. I’m worried they can’t recreate the problem because it’s so random. I have tried most of the cleaning, tightening, jiggling, inspecting that was mentioned above except for the voltage testing.
  13. Jul 4, 2023 at 7:11 AM
    mattandkelly
    mattandkelly New Member
    Avon Lake, Ohio
    Well this sucks to read and sounds way more like a crappy Jeep Commander issue or some other crap product!
    Sucks!
  14. Jul 4, 2023 at 10:21 AM
    BgBmBoo
    BgBmBoo New Member
    Kansas
    I’d check under the hood for rodent damage to the wiring. Aftermarket mods and rodents chewing up wiring seem to be the top two when it comes to electrical issues on newer 4Runners.
  15. Jul 4, 2023 at 11:02 AM
    I know this added cost but I would invest in a scangauge tool so that you can run all the diagnostics and see what codes or errors you are getting. The dealer will do the same but might not tell you exactly what the issue is and send you home.
  16. Jul 4, 2023 at 11:27 AM
    TrailGuy2016
    Do this. My friend's 2016 got eaten alive. New wiring harness fixed everything. Not free........
  17. Jul 5, 2023 at 7:17 PM
    Glenn Goodlett
    Glenn Goodlett New Member
    Glenn
    2020 TRD Pro
    Paid for
    FYI- The Toyota app shows recalls for you're vehicle if you have any.
