2020 4 runner SR5 Premium oil filter location
Discussion in '5th Gen 4Runners (2010-2024)' started by Sean, Nov 3, 2025 at 12:38 PM.
  1. Nov 3, 2025 at 12:38 PM
    Sean
    Sean [OP] New Member
    Sean
    Mass.
    Hey
    First I know it’s under the vehicle. I see a number of skid plates , a small on is where I’m thinking where the oil pan is.
    So my Camerys is located on the drivers side.
    1st will the filter i have for my 2016 camery work on this vehicle, s
    2nd how many of the skid plates do I have to remove?
    Thanks just trying to do my own oil change
  2. Nov 3, 2025 at 12:55 PM
    Levi9
    Levi9 New Member
    Portland, Oregon
    24 TRD Pro, Super White
  3. Nov 3, 2025 at 12:57 PM
    2019 TRDP w/Kangs brah!
  4. Nov 3, 2025 at 1:02 PM
    Sean
    Sean
    Mass.
    When I find the filter I can try it :annoyed:
    I’m trying not to have to take all the skid plates off
  5. Nov 3, 2025 at 1:07 PM
    It's 4 bolts unless you have the useless TRD skid too.
  6. Nov 3, 2025 at 1:09 PM
    Kudos for doing it yourself.
    Front skid and rear cover with 2 bolts has to come off.
    Not a Camry expert, but I would bet the farm it's a different filter.
    Post #3 by @whippersnapper02 nailed it.
    whippersnapper02 likes this.
  7. Nov 3, 2025 at 1:18 PM
    Sean
    Sean
    Mass.
    Google said same i just want to confirm
  8. Nov 3, 2025 at 1:22 PM
    BLKNBLU
    BLKNBLU New Member
    2019 Nautical Blue OR
    The oil filter does not cross reference to the Camry.
  9. Nov 3, 2025 at 1:50 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    The 4 runner filter element is a particular size and matches the metal standpipe in the plastic filter housing.
    A deep dive into these filters will satisfy any desire you have for understanding Toyota engineers.
    Los of posts on the two runner forums on this topic. Many have pics attached.
  10. Nov 5, 2025 at 10:08 AM
    Small 2-bolt access cover below the engine is for the drain plug.
    The oil filter is above the larger front skid (the bottom one in this picture):
    The Camry filter is the same diameter but 14mm shorter. It will mechanically drop into the 4Runner filter housing, but won't be doing any filtering, as all the oil would bypass through the 14mm gap.
    Camry: https://www.rockauto.com/en/moreinfo.php?pk=6391383&cc=3338325&pt=5340&jsn=517
    4Runner: https://www.rockauto.com/en/moreinfo.php?pk=6391380&cc=3353820&pt=5340&jsn=621
    08TXRunner likes this.
  11. Nov 5, 2025 at 10:49 AM
    Sean
    Sean
    Mass.
    I was referring to the oil wrench that I have for the Camrys oil filter housing
  12. Nov 5, 2025 at 11:01 AM
    ^The filter wrench size is the same.
    Sean[QUOTED][OP] likes this.
  13. Nov 5, 2025 at 2:43 PM
    you have to
  14. Nov 5, 2025 at 3:25 PM
    Taylor21554
    Taylor21554 New Member
    Naples Florida
    24 SR5 4x4
    I know this is a ridiculous question/favor to ask;
    Can anyone link me the correct oil pan access cover that goes on the stock sr5 skid plate?
    51457-60030 I think this is the part number, but does it come with the 2 fasteners? I appreciate it if someone comes to save the day. If not I’ll take a gamble. I put mine somewhere and can’t find it anymore.
  15. Nov 5, 2025 at 5:17 PM
    Taylor21554[QUOTED] and Sean[OP] like this.
  16. Nov 5, 2025 at 6:34 PM
    Taylor21554
    Naples Florida
    24 SR5 4x4
    3J thank you very much I appreciate it. You know sometimes it can be confusing ordering the simplest stuff from Toyotas dealer websites and stuff. thanks again
    Sean[OP] likes this.
