2019 Limited shocks bad?
Discussion in '5th Gen 4Runners (2010-2024)' started by Steve40th, Jun 29, 2022.
  1. Jun 29, 2022 at 9:34 AM
    Steve40th
    Steve40th [OP] New Member
    sTEVE
    I just was under my vehicle, and noticed the drivers side shock was pretty wet. The others look okay. Looks like the banjo nut leaked, which would be fluid. 55000 miles.
    Thoughts?
    Is there any test to see if they are "bad" or low on fluid?
    Thnx in advance.
  2. Jun 29, 2022 at 10:17 AM
    kmeeg LionRunner
    Per the pic 1 your XREAS are khaboom if that resedue is from shocks.
    Show it to a good 4x4 shop to confirm. You could replace all 4 with regular shocks. If you want to replace I think Toyota would ask you to buy 2 that are cross linked. XREAS are only available at Toyota as far as I know.
    Edit-
    If you haven't remove these shocks for a spacer lift or something you could try to convince Toyota to give some discount for XREAS failing at low miles.
  3. Jun 29, 2022 at 10:31 AM
    Steve40th
    sTEVE
    I will be going to Toyota soon. I doubt anything can be lowered in cost nowadays. But, I will probably go with Eibach system all the way around.. Looks good for my truck, price point etc.
  4. Jun 29, 2022 at 10:40 AM
    Sea Salt
    Sea Salt New Member
    Cecil
    Memphis TN
    2016 4Runner Limited 4x4
    2” Lift (removed XREAS) Bridgestone Dueler A/T 275/55/20 LED low/high beam / all interior Replaced outside mirrors
    My XREAS went out on my 2016 Limited 4WD @ 46K.
    I replaced with good set of shocks and even added a leveling kit. I have not noticed any issues with ride quality.
    Check out “The Car Nut” on YouTube. Very knowledgeable about X-REAS.
    N6WRV and Steve40th[OP] like this.
  5. Jun 29, 2022 at 2:33 PM
    N6WRV
    N6WRV New Member
    Paso Robles, CA
    2015 4Runner Limited 4WD with X-REAS
    37qt ARB fridge wired directly to battery with ARB Wiring Kit.
    Looks like normal road dirt. If your XREAS shocks were leaking, they would be wet.
  6. Jun 29, 2022 at 2:38 PM
    Steve40th
    sTEVE
    The banjo nut can leak, as it is the same as a brake banjo nut. I am thinking it is leaking a tad and the airflow into this area has been slowly moving it and dirt has been collecting. Its wet. Passenger side not so much or the rears.
    I am going to have the dealership and a 4x4 shop look at them, when I go to look at what shocks they carry on site.
  7. Jun 29, 2022 at 3:29 PM
    AGS92
    AGS92 New Member
    '19 SR5 Premium
    Do you know the brand and model of the shocks you installed after your XREAS went out? My wife's 2018 XREAS still looks good (only 38K miles). But just getting prepared for the inevitable.
  8. Jun 30, 2022 at 1:26 PM
    matoolie
    Michael
    2021 Lunar Pro
    XREAS is definitely shot as others have said. Best path is replacing within traditional shocks as you are doing. Did this on my 14 Limited. Went with Dobinson with 3/2 lift but now strongly considering TRD PRO Fox for more compliant ride. Dobinson too stiff compared to the ride my PRO has. I think I am just getting old.
  9. Jun 30, 2022 at 1:50 PM
    Steve40th
    sTEVE
    I like the idea of the leveling kit and Eibachs Stage 1?system. I will start analyzing systems.
    Eibach seems fitting for me.
    I want it to handle better, not nosedive when braking. Rake isnt a deal maker, but I really dont want to do upper control arms, if I dont have too. Leveling it is a bonus, but not needed. I wont be rock climbing with this Runner.. Its more of a traveler that will go off road mud , snow, lite trails to get to lakes, streams etc type vehicle.
    My Corvette went super stiff suspension. Wont do that again, as I am getting older physically, 54.
