2016 TRD Pro lift? Is Wescott the only deal using stock Bilstein shocks?
Discussion in 'Suspension' started by ChitownPro, Sep 22, 2021.
  1. Sep 22, 2021 at 1:05 PM
    ChitownPro
    ChitownPro [OP] New Member
    2016 TRD Pro
    LFD Full-size roof rack, N-fab steps.
    Hello,
    I mistakenly thought Eibach was developing a spring lift for the older Pro’s with Bilstein shocks; similar to the spring kit they currently have for Fox shocked Pro’s. After a phone call with them yesterday, apparently, I am mistaken. I was told I could use their rear springs, but the front springs for the 2019 Fox shocks would not work on the Bilstein shocks. Dang, back to the drawing board.
    I’m not wanting to trash my Bilstein shocks at this point as I rarely “off-road”, I only have 32k miles on this 4 runner, and I’m trying to keep the cost as low as possible without using ride trashing spacers. My plan for tires are SL 285 Wildpeaks on the stock TRD Pro wheels.
    Anything else I should consider besides Wescott? How bad will the rear spacer trash my ride quality? Apparently, users of this kit like what it does to the ride. I would rather lift with a spring in the back, but most of the aftermarket lift springs for the rear require you to use an aftermarket shock instead of the stock shock, probably to match the extension abilities of the spring.
    Thanks!
  2. Sep 22, 2021 at 1:27 PM
    So you are trying to lift by just changing the spring but keep the same shocks?
  3. Sep 22, 2021 at 2:35 PM
    ChitownPro
    2016 TRD Pro
    That’s correct.
  4. Sep 22, 2021 at 2:49 PM
    I can't imagine the shock its self being too fat to fit inside the spring.
    Maybe it overextends the shock? You said you rarely offroad don't want to try slap them on since you got um?
  5. Sep 22, 2021 at 3:13 PM
    ChitownPro
    2016 TRD Pro
    Yes, could be an overextension thing. I’m not opposed to the Wescott spring perch up front, basically it’s just like an adjustable coil over, but not adjustable. Could always look at Bilstein B12 or Icon 52700 2” spring in the back instead of the Wescott spacer?
  6. Sep 23, 2021 at 1:02 PM
    ChitownPro
    2016 TRD Pro
  7. Sep 23, 2021 at 5:41 PM
    HarrisNC
    HarrisNC New Member
    2022 Limited
    Dobinsons had a replacement front spring for the bilstein pro shock for a while. I would email Mike and see if it’s still available. I think it gave a similar lift as the Eibach.
  8. Sep 24, 2021 at 6:59 AM
    ChitownPro
    2016 TRD Pro
    Thanks, Mike says they still have it. Unfortunately, it only gives it 1” additional height. I’m guessing people do it just to level their Pro’s without having a 1” spacer up front. It’s just not quite enough for 285’s though, they might fit, but might not. I would likely have to add a 1/2” spacer up front. I know, splitting hairs.
    My plan is to do a full Wescott kit and see how I like it. If I don’t like the spacer in the back, I’ll put Dobinsons 505 or 599 springs in. With the Wescott up front, a 599 spring in back would give me 1/2”-3/4” rake, the 505 spring would yield a 1” rake which I understand is the factory rake on ‘16 Pro’s. Of course, that’s if the lift heights listed for these springs are correct for my vehicle, I read a lot of posts about people getting more lift than listed at times.
    I shall see how the Wescott performs, I’ve yet to see a negative review from an end user.
  9. Sep 26, 2021 at 9:44 PM
    Sixgunz
    Sixgunz Gold Member
    Phoenix
    2022 ORP
    I just used them to lift my Tundra that my daughter drives with 5100s. No complaints here. If/When I get a '22 TRD ORP, I'm gonna spend some pretty big bucks with them on it. They seem to be really Toyota focused...much like SLEE is in Colorado. FWIW.
  10. Sep 27, 2021 at 6:10 AM
    ChitownPro
    2016 TRD Pro
    I just ordered the kit; should be here later this week. My installers are working a month out, so it’s going to be a while before I get it installed.
