2012 SR5 rear camera wiring factory
Discussion in '5th Gen 4Runners (2010-2024)' started by Ty Thorne, Jul 2, 2025.
  1. Jul 2, 2025 at 9:53 AM
    Ty Thorne
    Ty Thorne [OP] New Member
    2012 SR5 4runner Black
    Bone Stock 96k miles
    In 2012 rear camera was an option. Is the wire back there in the tailgate? The radio I am replacing because it fails in the on position screen dark knobs don't function. I was able to get it to function again by knocking on the screen.
    I bought a Lasertail aftermarket radio has all the bells and whistles. The direction on the youtube vid shows plugging in to the yellow RCA in the stock wiring loom. Thank you.
    This is the vid it says 19 for the year I have a 12. https://www.youtube.com/watch?v=pjplWU1OKTc
  2. Jul 2, 2025 at 10:00 AM
    The yellow RCA pigtail would only be for an aftermarket rear camera with RCA outputs
    The OEM is wired thru a multi-pin plug.
    The 2012 with JBL and Entune did have backup camera, but if yours didnt have either of those stock you may have to wire in an aftermarket.
    Ty Thorne[OP] likes this.
  3. Jul 2, 2025 at 10:10 AM
    I see in the video, they include a wiring harness adaptor with RCA outputs.
    Do you have a backup camera mounted above the license plate? If yes, just install and go. If no, you get to buy a rear view camera kit and install.
  4. Jul 2, 2025 at 11:10 AM
    Ty Thorne
    No I don't . I'm trying to avoid taking the panel off the tailgate. They send you a camera and a wire long enough to reach the tailgate. I will not remove the headliner. If the wire is back there I would fish the camera wire thru the license plate light and mount a different license plate mounted camera. I ran into this same issue with my 96 FZJ 80 Land Cruiser but there is no wire back there so I had to run the wire under it and mount the camera to the trailer hitch. It's looking like I will have to do the same here. Thank you
  5. Jul 2, 2025 at 4:12 PM
