2010 limted 2” lift
Discussion in '5th Gen 4Runners (2010-2024)' started by runner2010, Sep 21, 2020.
  1. Sep 21, 2020 at 7:47 PM
    runner2010
    runner2010 [OP] New Member
    I have a 2010 limted 4wd. My xreas suspension went out. I plan to delete this system. What have you guys installed that will give me the 2” lift in the front? I rarely go off road but do occasionally during hunting season. Purchased 275/55r20 tires so I need the clearance.
  2. Sep 21, 2020 at 8:38 PM
    Welcome to the forum.
  3. Sep 21, 2020 at 9:07 PM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Sounds like some Bilstein 5100's might be in your future.
    Daytonaviolet likes this.
  4. Sep 21, 2020 at 10:58 PM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    For my 2016 limited, I opted for 2018 trd pro take offs. Then I added the Cornfed leveling kit 2/1.5”. It rides firmer then my xreas with some added lift. I think it’s a economical option until I’m ready for a coil over setup.
    Han4Run likes this.
  5. Sep 22, 2020 at 5:21 AM
    runner2010
    It looks like I will be getting some bilstein suspension. I will let you know how it turns out. Thanks guys
  6. Sep 22, 2020 at 6:51 AM
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    Any squeaks out of your UCAs? What are you using to grease them?
    Daytonaviolet[QUOTED] likes this.
  7. Sep 22, 2020 at 8:28 AM
    Daytonaviolet
    Bay Area, CA
    No squeaks. Grease gun every time I change oil. The upper zerk fittings require loosening the bolt before greasing. The lower one can be greased without loosening.
    Oldtoyotaguy[QUOTED] likes this.
  8. Sep 22, 2020 at 10:40 AM
    Oldtoyotaguy
    I have JBAs on mine as well, and I’ve heard that some squeak, although mine don’t squeak yet, which is why I asked. I’ve greased mine once, and had no problem greasing the upper ones. Is the reason you loosen the bolt just to ensure that the grease gets in there? It doesn’t seem like it’s necessary, but it might be a good tip. Thanks.
  9. Sep 22, 2020 at 11:24 AM
    Daytonaviolet
    Bay Area, CA
    it allows for correct flow of grease in the bushing
    https://youtu.be/xvMdAX2uybs
  10. Sep 22, 2020 at 1:45 PM
    Oldtoyotaguy
  11. Sep 22, 2020 at 1:55 PM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    That might not be the case for JBA. I'm not sure if you've seen their bushings, but they are pretty clever with the relief cuts which create channels for the grease to flow.
  12. Sep 22, 2020 at 2:11 PM
    Daytonaviolet
    Bay Area, CA
    When I first got my jba’s installed, it started squeaking days after installation. I loosen the long bolt, applied the grease on both ends. It has not squeaked since. Now I apply grease the same way when i I change oil.
    Oldtoyotaguy likes this.
