2009 4Runner Tailgate Water
Discussion in '4th Gen 4Runners (2003-2009)' started by Shaji, Jul 25, 2024.
  1. Jul 25, 2024 at 5:58 PM
    Shaji
    Shaji [OP] New Member
    Hi all,
    New-Used 4Runner owner. Have always been a Subaru guy (Impreza WRX owner) but recently purchased a 2009 4Runner. It's in good shape with no rust on the frame and minimal rust spots on the body but taking time to go through and fix and replace things the previous owner never got around to.
    I'm not as familiar with SUVs/Trucks so was wondering about the tailgate. My tailgate collects water whenever it rains and water drips out of the bottom left corner of the tailgate (similar to this (https://www.reddit.com/r/MechanicAd...n_lift_gate_of_2006_toyota_4runner/?rdt=34392).
    I looked into the issue online and it seemed to be a weather stripping issue. So I took out the drain plugs to drain the tailgate and replaced the rear window lower weather strip thinking that would fix the issue. I also took apart the interior trim of the tailgate and inspected for debris behind the vapour barrier and there was nothing.
    We had a storm recently so I thought it would be a good test to check if the tailgate collected water. Unfortunately it did, despite the new weather strip. I took out the drains and water streamed out from the two drain holes.
    I'm wondering if this is normal or if it's worth replacing the rest of the weather stripping around the glass to see if that stops the issue. I'm not seeing any other holes in the tailgate where water could come in but I definitely have to take a closer look.
    Lastly, the plugs I have are just regular plugs. I looked on forums online and others have plugs that actually allows the water to pass through (https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcRiYXr04OCgzTBvi6lHBJbCr-q6rn_zeQMPhQ&s). Mine are just simple rubber plugs that seem to block anything.
    Any advice is helpful.
    Thanks!
  2. Jul 25, 2024 at 6:17 PM
    RSG sliders, Yakima Megawarrior basket, Black Rhino wheels, SOS Streamline bumper and skids, Warn VR EVO10S winch, OME MT64, Bilstein rear lift coils, Rigid Dually SS ditch lights, SR light bar, and Diode Dynamics SS3 fogs.
    I'm not sure about the 4th gens, but the 5th gen tailgate seems to be designed for water to pass through. If those are not OEM plugs, I'd leave them out.
  3. Jul 27, 2024 at 6:46 AM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Silver ‘07 Sport V6 4WD w/ 280K miles
    Lost Trails grille & winch bumper | X-REAS delete / Eibach | BlueSea Systems console USB power ports | Pioneer AVH-2550NEX HU + Audiovox backup camera | Rockville lo-pro subwoofer | Kenwood speakers & KAC-M1804 amp | Wolfbox G850 Pro dash/rear cam
    I don’t think those plugs are for drainage. These slot openings are the drains to my knowledge, one at each corner and one in the middle. My OEM plugs are identical to the one you’re holding in the pic.
  4. Jul 29, 2024 at 11:32 AM
    Staticline
    Staticline New Member
    2004 4Runner Limited V8 with extras
    Victory front and rear bumpers, Dobinson's MRR suspension, winch, lights, 285 70R17 BFG KO3's
    gkomo likes this.
  5. Aug 2, 2024 at 7:57 AM
    Shaji
    I did replace that exact part and pretty sure I did it right but I’m still getting some water in. Going to take a closer look to see if there’s any other spots where water can get in.
  6. Aug 2, 2024 at 1:58 PM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    I am pretty sure water is going to get in your rear hatch unless you seal it off completely. If it’s holding water inside the hatch then your weep holes need to be cleaned out. Same for your doors.
  7. Aug 2, 2024 at 2:14 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    That weather stripping is not designed to keep all water out, just some of it, it is designed to keep debris out that will clog the drain holes, there no way to design a weather strip for a moving window that will keep all water out, that's why all the doors and hatch have drain holes.
    It's normal to have some water in the doors and hatch immediately after a hard rain, but it should drain out quickly unless the drain holes are block/clogged.
  8. Aug 6, 2024 at 10:52 AM
    Shaji
    Swapping out the bottom weather stripping did nothing to stop the water from getting in. Wondering if there's anything else I should try (i.e. swapping out the rest of the stripping around the rear window).
    For those saying it's normal, is there any reason why some 4Runners come with plugs that don't allow the water to drain out? Should I be swapping these out to plugs that can drain out? The smaller weep holes on the side and in the middle are clear as well.
    We just had a big storm the other day and I just drained out a ton of water immediately after by taking out the plugs so I'm lost on what to do.
  9. Aug 6, 2024 at 11:25 AM
    gkomo
    gkomo New Member
    San Diego, CA
    How did you know you had water in your lift gate prior to taking the plugs out? I'm just curious for my own sake... i would have no idea if i had stuck water in my lift gate, lol.
  10. Aug 6, 2024 at 11:27 AM
    Shaji
    I mentioned it in my original post. I noticed water dripping out of one of the weep holes.
    gkomo likes this.
  11. Aug 6, 2024 at 11:30 AM
    gkomo
    gkomo New Member
    San Diego, CA
    Do you have those other holes @Bluesky 07 showed pictures of? The more squared off ones? Are those clogged?
    Bluesky 07 likes this.
  12. Aug 6, 2024 at 11:31 AM
    Shaji
    I have those and they're clear too.
  13. Aug 6, 2024 at 3:17 PM
    Just leave the plugs out then :)
    But yes, all moving glass on the vehicle are "controlled leak paths", doors, tailgate, moonroof, etc., so they all have drainage provisions.
