2008 v6 going into limp mode on acceleration
Discussion in '4th Gen 4Runners (2003-2009)' started by cp5555, Jan 27, 2026.
  1. Feb 2, 2026 at 9:09 AM
    #61
    NickW1
    NickW1 New Member
    2005 SR5 V8
    It's been going on for a while now but unfortunately counterfeit/junk parts has reached a ridiculous level. Even the dealerships are having problems getting parts that are certified. I know it's been said but make sure your parts are Denso/Toyota. Just last week my BMW needed a new MAF with snorkel, had to order it from my local BMW dealer, when the parts came in from the BMW distribution center the dealer discovered the MAF and the snorkel was counterfeit. Enough said.
    Now, assuming your MAF, Coils, Plugs/Wires and Sensors are all good... What's left? I would go with fuel.
  2. Feb 2, 2026 at 9:26 AM
    #62
    cp5555
    cp5555 [OP] New Member
    CJ
    I went with NGK due to price, and the ability to buy from Rock auto and confidence that they are ACTUALLY NGK. this car is only driven 25 miles a week. Im confident in them.
    Fuel would be next for sure. The codes are all over the place, its shown that every cylinder is misfiring at once, or just a geneic misfire or only Cyl 1. So fuel is possible. I got my money back on the junk equipment and upgraded to NGK, and it only set me back another $150 all said
    i didn’t even know what rock auto was so shout out whoever suggested it. I hope im not dealing with fuel injectors though. Fingers crossed
    AuSeeker, 4onto and NB4x4 like this.
  3. Feb 2, 2026 at 9:31 AM
    #63
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    Ngk should be fine and hopefully that's all you need. Did you get plugs too?
  4. Feb 2, 2026 at 9:33 AM
    #64
    cp5555
    CJ
    I did
    NB4x4[QUOTED] likes this.
  5. Feb 2, 2026 at 10:12 AM
    #65
    gkomo
    gkomo New Member
    San Diego, CA
    2004 4Runner Limited V8
    RockAuto is the best. I use it.... way too much.
  6. Feb 2, 2026 at 10:26 AM
    #66
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD, 1994 Pickup V6 4WD
    The plugs being out is a good opportunity for a compression test. Toyota fuel injectors are pretty durable.
    NickW1 and NB4x4 like this.
  7. Feb 4, 2026 at 2:07 PM
    #67
    cp5555
    CJ
    we are back up and running!
  8. Feb 4, 2026 at 2:16 PM
    #68
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    Sweet!
  9. Feb 4, 2026 at 2:18 PM
    #69
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    What was the issue, what cured it?
  10. Feb 4, 2026 at 5:22 PM
    #70
    cp5555
    CJ
    Junk ignition coils. I got bad advice from a friend, i needed new spark plugs and was advised i should change the coils while i was in there. I went cheap, but the item had good reviews, but they failed in 2 months. I got some NGKs and up and running now
  11. Feb 4, 2026 at 5:46 PM
    #71
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    I've learned the hard way that you never throw out working OEM parts.
    AuSeeker, Cwilliams563 and Pentangler like this.
  12. Feb 4, 2026 at 7:08 PM
    #72
    cp5555
    CJ
    Yep, luckily 1A auto did refund the old coils without even requiring a return. All in all it cost me +150-200 more for the NGK
    i was also talked into a new battery during all of this, but i was eventually going to be due anyways. It was 3.5 years old
    NickW1 and NB4x4[QUOTED] like this.
  13. Apr 7, 2026 at 10:05 AM
    #73
    cp5555
    CJ
    Update to this whole situation. NGK products are working great! Ive taken two road trips. One was 800 miles total in 2 days, in VERY cold temps. No issues. just got back from another down in TX, 1600 miles in 6 days.
    80 MPH for extended periods of time. No issues at all
  14. Apr 7, 2026 at 10:50 PM
    #74
    4onto
    4onto New Member
    Toronto
    My old Pickup's ignition coil split open after three decades and a Toyota genuine replacement was cost-ineffective. So I swapped in an NGK made-in-you-know-where coil for a fifth of the cost. I'd like to believe brands like NGK still fuss over QC in this global marketplace and not just stamp its name on parts willy-nilly.
    NB4x4 likes this.
