2008 v6 going into limp mode on acceleration
Discussion in '4th Gen 4Runners (2003-2009)' started by cp5555, Jan 27, 2026.
  1. Jan 30, 2026 at 2:56 PM
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    If you still have the OEM coils put them in and see what happens.
    ToyotaDude99 likes this.
  2. Jan 30, 2026 at 3:06 PM
    cp5555
    cp5555 [OP] New Member
    CJ
    Ive got them. ill give them a try.
    Its worth noting its -10 where i live and this is my first winter in the vehicle. Trying to figure out what issues are common to arise when it gets this cold for this long. the root cause is still whatever it was, but wondering if the cold is making the problem even worse
    ToyotaDude99 and NB4x4[QUOTED] like this.
  3. Jan 30, 2026 at 3:08 PM
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    Limp mode should never be common and I hope it's your coils as it's a easy fix. Hopefully just putting the old coils back on fixes it but I'd still do new ngk or denso plugs either way.
    Best of luck!
  4. Jan 30, 2026 at 3:20 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    -10° is tuff on any vehicle, when it's that cold any electric connection can lose contact if it's a tiny bit loose at higher temperatures, makes sure all connections are tight.
    ToyotaDude99 and NB4x4 like this.
  5. Jan 30, 2026 at 4:13 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    You seem convinced it is the engine-have you eliminated tranny & torque converter? Was this "limp" driving in "D"? Did you try S3, S4? Did you try VSC off? Cold gear oil produces lots of drag/friction.
    NB4x4 likes this.
  6. Jan 30, 2026 at 5:29 PM
    cp5555
    CJ
    Ill definitely give this another look, but im getting misfire codes on multiple cylinders, and the cylinders change every time i run the codes
    NB4x4 likes this.
  7. Jan 31, 2026 at 9:47 AM
    cp5555
    CJ
    I think i have found a new method for diagnosing, but id love to know if anyone has tried this.
    Ill drive around the block, and purposely trip the car into limp mode. Which is causing a rough idle, and not allowing me to accelerate (there is no rough idle when the vehicle is not in limp mode)
    I will then go through and unplug each ignition coil individually while the vehicle is running, and I would hope/imagine that one of the cylinders being completely disconnected would stop the rough idle, and i can diagnose which cylinder is the issue, if i check every one and the engine is idling rough regardless, that would tell me that the misfires are not localized to one single cylinder and this would more than likely still be some king of airflow, or fuel system issue. not perfect but wondering if anyone has tried this
    NB4x4 likes this.
  8. Jan 31, 2026 at 10:08 AM
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    That's how we used to do it in the old OBDI days. Unplug a cylinder and see if nothing happens. Have you pressure tested the cooling system? Any white smoke from the exhaust?
  9. Jan 31, 2026 at 10:21 AM
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    I have used that method to find bad coils and on older diesels to find bad injectors. The only problem you might run into is if it's the cold messing up your aftermarket coils you more than likely have more than one that's acting up.
  10. Jan 31, 2026 at 11:39 AM
    Ralph Blake
    Ralph Blake New Member
    2008 sr5 4runner
    Here is a really useful web site with a a lot of help with auto or truck problems, also a great part covering all found codes. greatautohelp.com
  11. Jan 31, 2026 at 3:55 PM
    cp5555
    CJ
    This didn’t work. The engine was misfiring and regardless of which coil i unplugged the rough idle went away
    NB4x4 likes this.
  12. Jan 31, 2026 at 4:02 PM
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    So unplugging any of them made it to from a rough idle to smoothing out but a dead miss?
  13. Jan 31, 2026 at 4:56 PM
    cp5555
    CJ
    Yes it smoothed out and no more rough idke regardless of which one i unplugged
    NB4x4[QUOTED] likes this.
  14. Jan 31, 2026 at 6:04 PM
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    Did you try driving it with one unplugged? I'd try your old coils packs and see if that fixes it.
    AuSeeker likes this.
  15. Feb 1, 2026 at 7:11 AM
    cp5555
    CJ
    OK i am going to buy all new coils and spark plugs. does anyone know, are EBAY OEM parts fools gold? https://ebay.us/m/2mPazv
    this seems way too cheap to be real
    NB4x4 likes this.
  16. Feb 1, 2026 at 7:14 AM
    AuSeeker
    Skip
    South Carolina
    2004 Limited
    Many fakes on eBay, unless they're from a known Toyota dealer.
  17. Feb 1, 2026 at 7:17 AM
    Ralph Blake
    2008 sr5 4runner
    If you really wish to solve your problem only buy OEM Toyota parts, yes they cost a lot but there is a good well known reason they do as they are quality parts and they work as Designed, any other part is a not a OEM part are a crap shoot some are good many are not good.
    Hungryhawk and NB4x4 like this.
  18. Feb 1, 2026 at 7:32 AM
    cp5555
    CJ
    I plan to do this. They are indeed expensive. I am assuming ebay ones are fake but was curious if anyone had ever used EBAY ones
  19. Feb 1, 2026 at 7:43 AM
    #49
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    If you have your old coils that worked when you took them out I'd put those back in. If you're set on new coils Toyota or denso only and I wouldn't buy off eBay. Another note is get the Toyota plugs. I've tried ngk iridium in one of these engines and it didn't work well.
    #49
    Cwilliams563 and Ralph Blake like this.
  20. Feb 1, 2026 at 9:21 AM
    #50
    Cwilliams563
    Cwilliams563 New Member
    C
    Platinum 4th Gen 4x4
    Why not put the original coils back in to try and see if that solves the problem first?
    NB4x4 likes this.
  21. Feb 1, 2026 at 9:34 AM
    #51
    Cwilliams563
    C
    I’ve had good luck with the following Toyota dealers. Depending on item and time frame, the prices vary some and shipping can also vary.
    I recently had to buy 8 bolts that were like $1.80ea. and some of the dealers shipping was around $15-20$ lol. One of them came in at shipping that made the total half of what the other dealers were.
    I don’t see a reason to take a chance of fakes now, after what you’ve been through. I wouldn’t roll the dice, but that’s just me. Sounds like time isn’t in your side to wait for a holiday for sales at this point.
    You may even call them tomorrow and talk to the parts dept. to explain your situation. Maybe they have a coupon or could help you out?
    One the of dealers I had the bolts in the cart, last week sent me an email for a 20% off coupon to get my business, but I had already ordered them. Good luck and I hope you resolve your situation.
    https://www.elmhursttoyota.com/
    https://www.toyotapartsdeal.com/
    https://www.conicellitoyotaofconshohocken.com/
    https://www.olathetoyota.com/
  22. Feb 1, 2026 at 9:44 AM
    #52
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    Also, good ol' Rock Auto for Denso and NGK stuff -- decent price to quality ratio. Fewer and fewer genuine Toyota parts I buy from my local Toyota parts counter say "Made in Japan" yet still have Made in Japan prices. Worth restating is that these old 1GRs use old-school copper spark plugs. Many have used platinum or iridium and report no problems but sticking with Denso or NGK copper plugs eliminates that variable.
    NB4x4 likes this.
  23. Feb 1, 2026 at 9:57 AM
    #53
    cp5555
    CJ
    I can’t find them. I am 99% sure i threw them away
    NB4x4 likes this.
  24. Feb 1, 2026 at 9:59 AM
    #54
    cp5555
    CJ
    Autozone website had 20% of up to $50 discount, i did two separate orders to maximize. They had denso for $84 and then 20% off. Not too horrible. Ill have them in a few days
    NB4x4 and 4onto[QUOTED] like this.
  25. Feb 1, 2026 at 10:08 AM
    #55
    Cwilliams563
    C
    deleted….
  26. Feb 1, 2026 at 10:10 AM
    #56
    cp5555
    CJ
    Scratch that! NGK $33 on rock auto. Thats worth a chance in my opinion
    NB4x4 likes this.
  27. Feb 1, 2026 at 10:16 AM
    #57
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    ^^^Don't forget the Rock Auto 5% discount code.
    NB4x4 likes this.
  28. Feb 1, 2026 at 10:20 AM
    #58
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    Mind sharing?
  29. Feb 1, 2026 at 10:44 AM
    #59
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    ^^^Google. Usually, a few active ones are floating around out there on coupon sites.
    NB4x4 likes this.
  30. Feb 2, 2026 at 8:08 AM
    #60
    gkomo
    gkomo New Member
    San Diego, CA
    2004 4Runner Limited V8
    I just used the RockAuto code last week. Google RockAuto discount code, those 'shady' looking coupon websites will pop up but they actually work. Just try any of the 5% off codes until one works.
    Unfortunately i don't remember the exact code i used, but i did get it off Googling.
    NB4x4 likes this.
