2008 Corolla CE - Daily Driver Revival
Discussion in 'General Automotive' started by 1SilverRunner, Feb 25, 2026.
  1. Apr 1, 2026 at 8:45 AM
    #91
    1SilverRunner
    1SilverRunner [OP] My boy, blue
    Tejas
    22 TRD Off Road Premium
    Mods? Don’t ask… Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Custom DOM) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS extended travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 35" Baja Boss MT BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Derale 13504 Transmission cooler and Magnefine filter Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Power Solution: SDHQ Terminals Auxbeam RA 80 with OE Panels inlay Victron Orion 12/24V Converter Ecoflow Delta 2 and Dometic cfx35 Upgraded Sky High oversized 0 Gauge grounds Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights Xprite explorer 6 Rock lights OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics XPR reverse bulbs LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Same here!
    Luckily I’ll know soon! Tracking info just updated. Magnaflow and summit are getting me the parts on Friday.
    I’ll likely spray the mid pipe to manifold bolts with pb blaster every day before each drive. If those come loose, it’ll just be one cut with the sawzaw and an 02 sensor. Really hoping for an easy win here!
    ToyotaDude99 and NB4x4 like this.
  2. Apr 2, 2026 at 2:11 PM
    #92
    Sin4R
    2024 4Runner Limited
    Mall crawling kit.
    I used to have an old BMW with platinum-based catalytic converters. They lasted many miles and many years, but eventually even they started to fail. Replacement OEM cats were excessively expensive. So to pass smog test I'd a) change engine oil b) wash the car c) put fresh premium and add ethanol to about 15% d) go for 1 hour highway drive right before tailpipe testing. It would pass most of the time, but it would be close every time. Now, if you didn't wash the car, forget it, she would never play nice.
  3. Apr 2, 2026 at 3:04 PM
    #93
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    A wash always helps. We have used Cataclean product on a few F150 trucks that had catalyst efficiency codes pop up-always just before a smog check is needed. It's work and the codes usually stay away for a year or so. Those cats are near $7k for OEM.
  4. Apr 3, 2026 at 5:49 AM
    #94
    1SilverRunner
    Tejas
    Haha this is gold!
    7k?! Wild stuff! I did actually try cataclean but it couldn’t resurrect the dead CAT. Many people swear by it though, I’m sure it has merit.
    I was driving along this morning and a CEL popped up. P0101 (MAF out of range) Honestly I find this kind of funny because I’ve been data-logging during my commute specifically watching MAF g/s, and LTFT. As I’m cruising on the road I thought to myself, man g/s is pretty low… before I could finish the thought the CEL popped on. lol
    P0420 (CAT) and P0101(MAF) have been intermittently popping up as pending but neither have actually confirmed for over 700 miles. First CEL in quite a while. Luckily my new CAT and mid pipe are coming in today.
    The magnaflow cats are good quality for the price and since I’m getting the oe replacement/ direct fit option it will correct the 02 position as well. (Current setup is not at all how Toyota designed it)
    Once installed I’ll confirm
    -post cat temp sensor now higher than pre cat sensor
    -monitor MAF g/s for changes
    -monitor LTFT for changes.
    Honestly if the cat is partially restricted all of this should correct. If not, it will be good to know the CAT is working and the sensor positions are back in the OE locations while I dig deeper for a vacuum leak, exhaust manifold leak, or a fuel pump issue.
    Sin4R[QUOTED], NB4x4 and ToyotaDude99 like this.
  5. Apr 5, 2026 at 7:58 PM
    #95
    1SilverRunner
    Tejas
    Final data log before the CAT swap.
    Downstream 02 pretty low. Kind of mirroring the upstream sensor as well. Classic failed cat.
    Out with the old:
    Used a little chain cutter from harbor freight. Worked like a charm to get a clean cut. (Much better than I could have with a sawzall)
    Old aftermarket cat on the left, magnaflow “oem” grade on the right
    (Note, swapped magnaflow’s hm grade to their oem grade since this car was originally sold in California so the onboard emissions monitors are extra sensitive)
    Hit a little snag on install. Magnaflow is true 2.25” OD but the Toyota pipe is closer to 2.125”. Had to run to the parts store and get a different pipe adapter. Took some scrap bits of pipe and found a 2.25” OD to 2.25” ID adapter fit perfectly.
    Used a ton of permatex copper exhaust sealant on the pipes just for extra insurance.
    Torqued everything up and set the car back down.
    Went to reconnect the battery and realized the “marine grade” terminals I had from oreillys were already starting to fail from tightening and loosening so much in the last few weeks… looked it up and I learned they use recycled led to make them… so I swapped those out for some zinc ones which are much stronger
    Gonna let the car sit overnight to give that permatex time to set.
    Ill do the same datalogging with the new magnaflow cat and report back with changes
  6. Apr 6, 2026 at 6:16 AM
    #96
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    I've been putting these on most everything lately.
    https://www.batterycablesusa.com/battery-adapter-top-post-ordnance-military-style
  7. Apr 6, 2026 at 6:41 AM
    #97
    1SilverRunner
    Tejas
    Man the car is running great today. Feels like it picked up 20 horsepower.
    Gonna keep doing some datalogging as I drive and see what else the car needs. I suspect a fuel pump will be next as @Rocko9999 previously hinted at. But for now I’ll let it ride. Gotta get the 4Runner prepped for Toyota Jamboree!
  8. Apr 6, 2026 at 7:04 AM
    #98
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    Not going to take the Corolla?
    ToyotaDude99 and AuSeeker like this.
  9. Apr 6, 2026 at 7:19 AM
    #99
    1SilverRunner
    Tejas
    Hahaha no sir! Old Silver needs to stretch her legs!
    ToyotaDude99 and NB4x4[QUOTED] like this.
  10. Apr 6, 2026 at 7:54 AM
    #100
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    Looks like a lot of fun!
  11. Apr 6, 2026 at 9:13 AM
    #101
    1SilverRunner
    Tejas
    Alright boys. Fuel pump next
    Works fine at cruise^
    Not so much under load:
    Downstream 02 (O2S2) reporting the cat is working extremely well. But those fuel trims did not correct. I was worried about that… The ecu can’t even ask much more than 33% (ecu limit is around +/- 34% LTFT) so driving it hard means I’ll be running lean.
    Anything over 15% throttle input could mean damaging the engine or the new cat. Simply put, the fuel pump can’t keep up with the airflow, and I see AFR creep up to 16-18 before my mechanical empathy forces me to back off the throttle…
    Thinking back on it, this is why the spark plugs looked like they’d seen lean conditions. This was also a likely contributor to that aftermarket CAT’s short lifespan (8 months)… The root cause was never fixed
    Fuel pump, lock ring and new seals on order. Gonna swap it once I get some downtime with the 4R prep
    I’ll check fuel pressure to verify… but the data is very telling
  12. Apr 7, 2026 at 6:44 AM
    #102
    1SilverRunner
    Tejas
    Drove the 4R today in response to yesterday’s findings. Really don’t want to burn up that brand new CAT.
    Fuel pressure gage coming in tomorrow to verify. But I’m fairly confident this thing needs a fuel pump, so I’ve moved forward with the order.
    I’ll post photos of the fuel pressure test results soon
  13. Apr 7, 2026 at 2:42 PM
    #103
    Sin4R
    Mall crawling kit.
    Is fuel filter separate or integrated? I think line/filter restriction is as likely as failing fuel pump.
  14. Apr 9, 2026 at 5:13 PM
    #104
    1SilverRunner
    Tejas
    Unfortunately it’s an in-tank filter, pump, and sending unit assembly.
    Clogged fuel injectors are a possibility as well. I’ll know more once my fuel pressure gauge comes in!
    (unfortunately it was delayed in shipping)
  15. Apr 10, 2026 at 10:14 AM
    #105
    Sin4R
    Mall crawling kit.
    I like how methodical you are. Also, clearly, you are more patient than I am. I have been known to just change parts when they are cheap enough. While I know that a guess is not a solid plan, it worked often enough for me.
  16. Apr 10, 2026 at 6:51 PM
    #106
    1SilverRunner
    Tejas
    Thanks man! But I can totally understand that perspective as well.
    I definitely felt like I was doing that at a certain point with the electrical system. Got really tired of testing the fuses on repeat and seeing different failures around the system. So I swapped every fuse. Then the ignition switch and starter relay was cheap from autozone so I swapped those out… I learned my lesson with that… since the duralast start relay shorted internally and fried the entire start circuit (and almost the new starter) New OEM is in now and works like a charm.
    In hindsight I could have likely changed the starter and the intermittently failing NSS and left the fuses and relays alone. Instead, I got impatient, failed to diagnose an intermittently failing part, and made a lot more work for myself by throwing some cheap parts at it.
    I won’t make that mistake with the fuel system. I figure the Denso/ Toyota parts lasted for 200,000+ miles so that’s what I should stick with. And I’ll verify the lack of fuel pressure before I install that pump assembly
    Sin4R[QUOTED], ToyotaDude99 and NB4x4 like this.
  17. Apr 10, 2026 at 9:07 PM
    #107
    ToyotaDude99
    ToyotaDude99 Obsessed with 4Runners... And anything Toyota
    The Moon
    1995 4Runner
    When I bought my 2nd gen, I vowed only to replace parts with OEM or high quality name brand parts (translation = expensive parts, lol). I've been doing that and while more pricy, its been worth it. I once had a car where every part on it was cheap Amazon sh*t. Some of the parts didn't exactly fit properly... But I made them fit, hehehe (don't try that at home). I won't buy another auto part off amazon again. RockAuto, YotaShop, or Toyota for me.
    1SilverRunner[OP] likes this.
  18. Apr 16, 2026 at 7:33 PM
    #108
    1SilverRunner
    Tejas
    Prepping the 4Runner for Toyota jamboree has been taking priority. But I finally got the fuel pump in (for a minute I thought it got lost in shipping!)
    I had told myself I would test fuel pressure and replace all the old fuel hose and evap hose while the tank was depressurized… Well, I had about an hour after work today so I did this job the simplest way possible.
    Pulled the efi fuses and cranked it a few times to kill fuel pressure
    Rear seat off, removed access panel, and disconnected lines. Lines felt decently soft so I removed the lock ring
    Pulled the old pump out and swapped the new one in
    New o ring and lock ring went on with it.
    Took 45 minutes
    Then went on a test drive.
    Idle and part throttle cruise:
    LTFT stays in that 10-20% range. AFR reading nearly 14.7 the whole time; meaning fuel corrections are doing what they need to do.
    And the real test, acceleration.
    LTFT goes up to 20 percent, well under the ecu’s cutoff of 35%. MOST IMPORTANTLY AFR is staying at 14.7. Exactly where it needs to be. Awesome.
    Idle is perfect. Starts are perfect. And the fuel pump can finally keep up with the new exhaust.
    Carrie’s back to commuting boys. I’ll put some miles on her and monitor the data. Eventually I’ll pull spark plugs and read them again. For now, she’s golden
    Sin4R, gkomo, NB4x4 and 2 others like this.
  19. Apr 22, 2026 at 7:02 PM
    #109
    Sin4R
    Mall crawling kit.
    Knowing when to stop fixing can be more important than knowing how to fix. Personally, I suffer from chronic "While I am there" and "Might as well" conditions.
  20. Apr 22, 2026 at 7:09 PM
    #110
    ToyotaDude99
    The Moon
    1995 4Runner
    Well, that's very true on my 2nd gen. If it looks good, doesn't look like its going to fall apart, and feels snug when I tug it, I don't replace it. Because as soon as you start messing with suspension parts, you find more problems! So as long as it drives good, its A - OK!
  21. Apr 22, 2026 at 10:37 PM
    #111
    1SilverRunner
    Tejas
    I’m there now with this Corolla. Are fuel trims perfect? No. But AFR is safe. No more bucking under acceleration, no more codes popping up, idles great, drives better than it has in years. And to top it off, it just passed inspection.
    Far cry from where it was… cat didn’t work. P0420 and p0101 popping every drive. Couldn’t accelerate worth a shit. Not to mention the no start saga. I’m happy this thing is working as well as it is. Timing was perfect too because I’ve been working everyday trying to get the 4Runner prepped for Jambo! Huge pressure off my shoulders to know I have the Corolla to drive to work. The 4Runner can sit in the garage safe disassembled if need be. (As it’s currently sitting in the garage with all the electrical accessories ripped out of it lol)
    ToyotaDude99, NB4x4 and Sin4R[QUOTED] like this.
