2008 4x4 SR5 Tire Size
Discussion in '4th Gen 4Runners (2003-2009)' started by ezwind72, Apr 16, 2019.
  1. Apr 16, 2019 at 7:27 PM
    ezwind72
    ezwind72 [OP] New Member
    Eric
    2008 Blue 4Runner SR5 4X4
    Hello,
    I am new to this forum. I have a quick question. I have a 2008 4x4 SR5 that is need of new tires. The current size on there is 265/65/R17. I have 4 brand new 265/70/R17 tires. Does anyone know if these will work? I don't know a lot about tires and I don't want to put these on only to find out I screwed up my steering or transmission or whatever. I don't think there is a huge difference but I haven't been able to find a solid answer to this question. So I figured I'd ask other Toyota folks what they think. Thanks in advance....
  2. Apr 17, 2019 at 4:10 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    Might have very minor rubbing in reverse and full lock but not bad.
  3. Apr 17, 2019 at 5:54 AM
    MI-FL off roader
    Brett
    Merritt Island, FL
    03' SR5 Sport - 12' Limited
  4. Apr 17, 2019 at 6:23 AM
    ezwind72
    Eric
    Thank you, I appreciate the responses and information. I am curious as to why you feel it would only rub in reverse or when the 4 wheel is engaged?
  5. Apr 17, 2019 at 7:34 AM
    MI-FL off roader
    Brett
    Merritt Island, FL
    Reverse when turning out of a parking spot the wheel rotates at an odd angle and rubs sometimes. Hobo means when at full lock is when your steering is fully turned to the right or left. Not locked in 4x4.
  6. Apr 17, 2019 at 7:35 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    4 wheel because that usually means you are compressing the suspension and reverse because the front squats when in reverse the same way the rear squats when in forward gears.
  7. Apr 17, 2019 at 7:41 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    And yes this is what I meant not 4x4 but the above still applies.
  8. Apr 17, 2019 at 7:58 AM
    ezwind72
    Eric
    Ah, ok. I understand what you are saying now. Thank you all very much for your perspectives, that helped a lot.
    HoBoDanny likes this.
  9. Apr 17, 2019 at 9:32 AM
    Atch97
    Atch97 New Member
    2007 limited, running Daystar 2.5/1.5 with 265/70/R17 Falken A/T3W on stock 17in wheels,Love the tires. The only rub I have is on the UCA’s at full lock. Bugs the hell out of me knowing it rubs.
  10. Apr 17, 2019 at 9:58 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    How’s the tire rubbing the UCA at full lock? Pictures
  11. Apr 17, 2019 at 11:44 AM
    Atch97
    Atch97 New Member
    When full lock, it kinda goes under the front of the UCA and touches it slightly. If that makes sense. Trucks out now, I’ll take a pic later.
  12. Apr 17, 2019 at 1:02 PM
    Atch97
    Atch97 New Member
    So this is fill lock
  13. Apr 17, 2019 at 1:14 PM
    4runningMan
    4runningMan New Member
    New Mexico
    If it's rubbing with the 2.5/1.5 lift, then I think the rubbing would be even worse on the non-lifted 2008. But a hiway tire might not be as bad as an AT.
  14. Apr 17, 2019 at 1:38 PM
    ezwind72
    Eric
    My truck is not lifted and I will be using a highway tire. They are FIRESTONE TIRE TRANSFORCE HT LT265 /70 R17. I'll let you know how I make out next week when I have them installed.
  15. Apr 17, 2019 at 3:21 PM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    I e never seen that... maybe you need to adjust your alignment I have. 2” lift with 265/70r17 and have no rubbing on the control arm at all didn’t have any when I had no lift either. That’s very strange.
  16. Apr 17, 2019 at 3:43 PM
    Atch97
    Atch97 New Member
    What tire are you running? Got an alignment yesterday, gonna give them a call.
  17. Apr 17, 2019 at 3:49 PM
    ezwind72
    Eric
    They are They are FIRESTONE TIRE TRANSFORCE HT LT265 /70 R17. Thanks!
  18. Apr 17, 2019 at 4:26 PM
    Atch97
    Atch97 New Member
    ezwind72 Sorry to jack your thread. I saw your post earlier. I was trying to see what HoBoDanny was running.
  19. Apr 17, 2019 at 4:31 PM
    ezwind72
    Eric
    No worries! It's all good, hijack away....
  20. Apr 17, 2019 at 6:07 PM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    265/70r17 Hankook DynaPro AT
    Atch97[QUOTED] likes this.
