2006 with code P0430
Discussion in '4th Gen 4Runners (2003-2009)' started by 2020 4Runner, Jan 24, 2022.
  1. Jan 24, 2022 at 9:50 AM
    2020 4Runner
    2020 4Runner [OP] New Member
    Fl
    Hello all. I have a question about the kids 2006. It's an SR5 4.0 with 161,000 miles. It has a check engine light with code P0430. With these miles, is it most likely an 02 sensor or the cats? I can get the freeze frame data from my OBD scanner if that will help. Thanks.
  2. Jan 24, 2022 at 10:40 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    Gonna go out on a limb and say its probably not the cats themselves, despite the age. New O2 sensors can be had from Amazon, eBay, or RockAuto for $40 or less. Try that and see if it clears?
  3. Jan 24, 2022 at 11:12 AM
    2020 4Runner
    Fl
    Thanks. Yes I wouldn't think it would be the cats either.
  4. Jan 24, 2022 at 8:46 PM
    While I would also agree, as TOYOTA cats are usually top notch, $40 O2 sensors are not a good idea. They will cause you a world of headache since they fail often and you will always suspect them.
  5. Jan 24, 2022 at 8:53 PM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    +1. Don’t cheap on parts. Toyotas got you this far just go to the dealership or order authentic parts so it can last you another 160k miles. Granted if the oem parts are expensive I would buy the $40 part to verify if that is the issue and then go get the oem part.
  6. Jan 24, 2022 at 8:57 PM
    Cheaper yet...have you cleared the code?
    I got a cat sensor code and cleared it. It came back after a bit and I cleared it again and it's staying away for now. I've done this and had the code stay away for 6 months at a time.
    GrantA likes this.
  7. Jan 25, 2022 at 4:21 AM
    2020 4Runner
    Fl
    Yes i have cleared it a couple of times but it comes back shortly after.
  8. Jan 25, 2022 at 4:25 AM
    2020 4Runner
    Fl
    Sparks has the sensor for around $100 or so. That isnt too bad at all. It actually drives fine thats why I didn't think it would be the cat itself.
    GrantA[QUOTED] likes this.
  9. Jan 25, 2022 at 6:49 AM
    iamincrediboy
    South FL
    Not sure why Im getting dinged on this. Denso or NGK is what Toyota OEM is... https://www.rockauto.com/en/moreinfo.php?pk=1606676&cc=1432828&pt=5132
    In case others chime in here though for reference there are two versions of sensors. The sensor upstream of the cat is definitely not $40 and is the A/F sensor. The downstream sensor is the O2 sensor, the $40 one.
  10. Jan 25, 2022 at 8:20 AM
    2020 4Runner
    Fl
    True...Toyota has alot of Denso sensors.
  11. Jan 25, 2022 at 11:12 AM
    Correct. My apologies then if that is a true Denso part. I've paid far far more just to be safe and assumed $40 was a knock off price.
  12. Jan 25, 2022 at 11:31 AM
    iamincrediboy
    South FL
    Normally Id agree with you too, which is why I included the roackauto link :cheers:
  13. Jan 25, 2022 at 11:49 AM
    2020 4Runner
    Fl
    I ordered both downstream sensors.
    iamincrediboy[QUOTED] likes this.
  14. Jan 25, 2022 at 12:05 PM
    iamincrediboy
    South FL
    Let us know how it goes. If it isnt that there are other things to check that could trip that code: A/F sensor, exhaust leak, faulty spark plug, etc...
  15. Jan 25, 2022 at 1:18 PM
    2020 4Runner
    Fl
    Will do....thanks. My scanner said Bank 2 catalyst efficiency so we will see what happens.
  16. Jan 25, 2022 at 3:27 PM
    iamincrediboy
    South FL
    I agree. Just mean that the P0430 code means "catalyst efficiency is awry", but its really just saying the ECU sees something is off between the measured values and expected values. But that can come from various sources right - either of the sensors themselves, exhaust leak, intake leak, faulty spark plug/injector/ignition coil, improper engine timing, and more. Unfortunately it may well be a number of things, but first for sure to check are those sensors.
  17. Feb 1, 2022 at 5:55 PM
    2020 4Runner
    Fl
    Replaced both downstream sensors with Densos. So far no CEL. I tapped all 4 cats with a ball peen hammer and no rattling or anything.
    iamincrediboy likes this.
