2005 V8 4Runner with check engine light
Discussion in '4th Gen 4Runners (2003-2009)' started by Micorama, Sep 2, 2019.
  1. Sep 2, 2019 at 2:37 PM
    Micorama
    Micorama [OP] New Member
    2005 4Runner
    Hello all,
    I’m pretty certain that this has been covered before but I’m new here. I have a check engine light on and with it comes the VSP set of lights as well. I’ve changed out the gas cap and I’ve reset the fuses as described to me by a technician. It’s not all the time just periodically. The runner runs well but frustrating to see the lights. Any other ideas? Thanks in advance!!!
    captsolo likes this.
  2. Sep 3, 2019 at 5:45 AM
    TN_FunRunner
    TN_FunRunner Custom Title
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    Have you checked to see what code it is?
  3. Sep 3, 2019 at 11:34 AM
    MattAK
    MattAK Headin' for the hills
    Matt
    Utah
    2019 Tundra SR5 dbl cab white
    Yep, need the actual code to know what's going on.
  4. Sep 3, 2019 at 10:41 PM
    Micorama
    2005 4Runner
    I tried 3 times. Each time I drive to AutoZone to plug there code finder in the lights go off. Their finder doesn’t display any issues. I’ll keep trying to see if I can plan it better. Thanks!!!
  5. Sep 16, 2019 at 8:07 PM
    Libagui
    Libagui New Member
    Librado
    2006 Silver 4runner limited.
    Buy a cheap scanner and check it yourself
  6. Sep 22, 2019 at 6:34 AM
    drgnbalm
    drgnbalm New Member
    Mikey
    2005 Black 4Runner V6 SR5
    2015 SR5 Wheels LED’s All Around
    I have the similar issue CEL turns on then shortly after the VSC/ABS turns on with DTC code P0717 for the transmission input speed sensor. Can someone post a pic for me for the location? Please and thank you.
  7. Sep 23, 2019 at 3:44 AM
    captsolo
    captsolo New Member
    Tom
    nassau bahamas
    2005 SR5
    Scotty Kilmer says if the car runs fine and you get CEL just keep driving the vehicle.
