2004 SR5 V6 Catalytic Converters
Discussion in '4th Gen 4Runners (2003-2009)' started by chrissyrenaee, Mar 11, 2023.
  1. Mar 11, 2023 at 11:04 PM
    chrissyrenaee
    chrissyrenaee [OP] New Member
    Silver 4Runner SR5 Premium
    2.5 inch lift, 285/70 K02s, Pro-Comp wheels, TRD Air filtering system, TRD skid plate, Predator side steps
    When did you change out your catalytic converters?
    I got a 0420 code at 191k so bank 1. best suggestion for this issue anyone?
  2. Mar 12, 2023 at 12:51 AM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    I'd start with seeing if replacing just the O2 sensor resolves the problem before spending the $$ on a replacement manifold cat.
  3. Mar 12, 2023 at 12:56 AM
    xtremewlr
    Todd
    Tucson, AZ
    chrissyrenaee[OP] likes this.
  4. Mar 21, 2023 at 11:31 PM
    chrissyrenaee
    i got a new gas cap and it turned off my CEL and I passed my smog test today so maybe it was my gas cap...
    xtremewlr[QUOTED] likes this.
  5. Mar 22, 2023 at 7:29 AM
    xtremewlr
    Todd
    Tucson, AZ
    Glad that worked for you. When I was recently dealing with a P0420 on my V8, replacing the O2 sensor took care of it initially but then it started coming back. I did some exhaust work and found the gaskets from the cat to the y-pipe were completely shot. Since replacing those, no more P0420. So it can be difficult to tell where the actual issue lies sometimes with these codes.
  6. Apr 1, 2023 at 9:49 PM
    chrissyrenaee
    i found these posters, maybe it can help someone!
