Quick Links: Starter came with lifetime warantee Water pumps in 4th Generation 4runners - durability SOLVED: V6 code P0301 caused by rodent eaten injector wires 03 sr5 fuse block needs to be replace, moisture corrosion... New owner- things to check or must do mods? Stuck CV axle shaft, need some help
2004 climate control lighting
Discussion in '4th Gen 4Runners (2003-2009)' started by Omer, Jul 17, 2021.
