2002 4runner jerks left upon hard braking
Discussion in '3rd Gen 4Runners (1996-2002)' started by Dsal96, Nov 29, 2020.
  1. Nov 29, 2020 at 2:11 PM
    Dsal96
    Dsal96 [OP] New Member
    Darren
    1996 limited 4runner 4x4
    2.5 lift Air bags in the rear Custom front bumper Winch Retrofit headlights Rear locker 33s on 16s Custom full roof rack Bilstein suspension
    I have a buddy with a 02 4x4 sr5 4runner that recently had a lower ball joint fail on the trail (passenger side) which led to a broken CV, busted brake line, and broke the upper ball joint as well and left the lca in the dirt and tire stuffed into the fender. We replaced all parts that were broken and also bled the brake system. Since then it pulls violently to the left upon hard braking, then will straighten out perfectly when you let off the brake. We did new broke rotors, pads, and calipers and re bled the system and it still does it just as bad. Also had 2 alignments. Suspension is in good shape only about 10 month old bilstein setup on 2.5 inch lift on 265s. steering components seem like they are tight and operating correctly. Lca bushings do seem worn but we don’t suspect that to be the cause of the pull. Any suggestions?
  2. Nov 29, 2020 at 3:34 PM
    Welcome.
  3. Nov 30, 2020 at 8:08 AM
    Brake issue.
    Did you replace the brake line?
  4. Dec 2, 2020 at 12:55 PM
    shake007
    shake007 New Member
    97’ Supercharged SR5
    I would think a pinched brake line
  5. Jun 14, 2021 at 10:07 AM
    Doubleduty
    3rd gen ltd and 5th gen SR5
    Maybe the brake fluid proportioning valve. My wife's 98 does the same thing sometimes, just not as bad.
    Have not had it looked at yet, but that's my hunch.
  6. Jun 21, 2021 at 7:19 PM
    SnowBunny56
    SnowBunny56 New Member
    North Texas
    1999 3rd Gen
    Toyo tires with Fuel wheels, Carhart seat covers, getting started with some suspension mods
    For whatever reason you have no braking on the right front, check the metal brake line from where it is attached to the rubber brake hose back to where it passes into the engine compartment, may be damaged at some point, Good Luck
  7. Jun 22, 2021 at 12:35 PM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    I dunno, a quick tube of tooth paste through the eye into the brain worked good for Bun-Bun, when he faced off with a Cavity Creep. Maybe a can of car wax, for 4Runner Jerks? :D Heck, just call Bun-Bun. Let him deal with them, in his own, incredibly violent, way.
    Apparently, hitting the brakes hard works, though, especially if they're chasing you. Put in a nice drop hitch, and watch them crack their shins on it. I know I always do. And it HURTS.
    Ok, I'll shut up now...
    Pat☺
    7385 likes this.
  8. Jun 22, 2021 at 12:57 PM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
  9. Jun 23, 2021 at 2:58 AM
    Welcome from Wisconsin! Never a dull moment
    7385 likes this.
