2000 Blowing 10amp Gauge Fuse
Discussion in '3rd Gen 4Runners (1996-2002)' started by rtzx9r, Aug 31, 2020.
  1. Aug 31, 2020 at 6:29 PM
    rtzx9r
    rtzx9r [OP] New Member
    Rob
    2000 4 Runner
    Hello,
    Newb here to the 4 runner forum (Have a taco). A friend has a 2000 4 runner with 140k miles, and it is a FL car in good overall condition. It recently started popping a 10 amp fuse labeled “gauge” anytime the AC and blower motor are running. It can do this often at times and other times not so much. The truck has been at a mechanic friends of the owner And they were thinking it is the AC compressor.
    Im thinking it maybe has something to do with a bad ground... either (-) connection at the battery, the chassis, or the cable itself as doesn’t seem to make sense the gauge fuse pops due to ventilation system. Any thoughts?
    Thanks!
  2. Aug 31, 2020 at 7:00 PM
    rtzx9r[OP] likes this.
  3. Aug 31, 2020 at 7:03 PM
  4. Aug 31, 2020 at 10:28 PM
    Clutchplate
    Clutchplate New Member
    96 4runner 3.4 Liter
    Check and see if fuse blows when truck is put into reverse, if so it's a bad reverse light switch.
  5. Sep 2, 2020 at 9:25 AM
    Fuses blow because too much power is trying to be pulled through them. A bad ground...would just limit the power draw and make a blowing fuse less likely.
    It's going to be a short. The short can be in the wiring or in a faulty component that when switched on draws way too much power.
    The AC compressor does have a switch in it to actuate the clutch. You could disconnect that wire and see if the problem disappears (you won't have AC). But if that clutch is not on the circuit with the fuse...it's not going to be it.
    Basically look at the circuit and see what all is attached.
