2000 4Runner Limited sitting in storage for 15 years what to do before driving it
Discussion in '3rd Gen 4Runners (1996-2002)' started by bran, May 19, 2021.
  1. May 19, 2021 at 5:49 PM
    bran
    bran [OP] New Member
    I just started driving a 2000 4Runner Limited. It has been sitting in storage for quite a while, 15 years. Regular oil changes throughout the times and it has been regularly started up. The battery has always been charged.
    Anything I need to keep in mind before driving it?
    werlyb23 likes this.
  2. May 19, 2021 at 7:14 PM
    Toyofan87
    Toyofan87 New Member
    Seth
    Blue & Grey Hwy Gburg
    1987 Toyota 4Runner SR5
    bran[OP] likes this.
  3. May 19, 2021 at 7:16 PM
    Welcome to the forum.
  4. May 19, 2021 at 7:18 PM
    mauspalls
    mauspalls New Member
    SW Washington
    2018 TRD Off Road - nautical blue
    Dobinsons 1" lift, 255/80/17 Falken Wildpeaks, Tundra battery mod, Extreme LED Pro Fogs, lots of good mojo
    Nice! How many miles on the odo? After 15 years, I would definitely throw some fresh tires on. I'd change all the fluids, too, especially the brake fluid.
    Toy4X4 and SlvrSlug like this.
  5. May 20, 2021 at 12:09 PM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    Brake fluid is critical. It absorbs water over time, slowly reducing it's effectiveness. Coolant (make sure you only use the Toyota Red coolant and distilled water!), and check the radiator and water pump for a corrosion build up, transmission and differential fluids, make sure it has the right weight oil in it, and a good, Toyota oil filter. Some of the nest oil filters out there.
    Double check ANYthing made of rubber. Coolant lines, brake lines, vacuum lines, ball joint covers, heck, ANYthing rubber. After 15 years, chances are anything rubber is getting rotted. Especially, ESPECIALLY, the timing belt. I'd be willing to wager it cracked all through it's length. The rest of the belts and hoses, too.
    Give her a good tune up. Plugs, wires, check the AF sensor and O2 sensor, knock sensors, and so forth.
    Sounds like a lot, but that's because if it had been driven consistently, this stuff would have been done slowly, over time. As it is, it's all been put off till now. Once you get it all done, you can get into a regular maintenance schedule for all this good stuff.
    AND be driving it around having the fun you should be in a 4Runner :D
    Pat☺
  6. May 20, 2021 at 12:11 PM
    PhantomTweak
    Patrick
    OREGON
    Pat☺
    LandCruiser and bran[OP] like this.
  7. May 21, 2021 at 11:32 AM
    bran
    Thanks! About 28k miles, hasn't been used a lot so I'm really lucky. I'm changing the tires but I will plan to change all the fluids.
  8. May 21, 2021 at 11:34 AM
    bran
    Thanks for the in depth help. There seems like a lot to do, but I can't wait to learn about the car. Thanks for all the help!
  9. May 21, 2021 at 12:36 PM
    doc4216
    doc4216 New Member
    Shannon
    The Land of Cle
    2015 SR5 Premium
    Dasaíta HU, Bilstein 5100s, AT Tires, Coveted grill lights
    Congratulations!! It’s not real until you give us a picture!!
    PorkRunner99 likes this.
  10. May 21, 2021 at 2:30 PM
    Ahdofu
    Ahdofu New Member
    Matt
    Tires also need to be looked into. Vehicles stored on their tires will eventually develop permanent flat spots on their tires.
    Toy4X4 likes this.
  11. May 21, 2021 at 3:08 PM
    mauspalls
    SW Washington
    Wow, that's a holy grail rig for a lot of folks - you scored big time. Pics for sure.
    PorkRunner99 and Toy4X4 like this.
  12. May 21, 2021 at 3:16 PM
    Put a new expansion valve in that bad boy. I just took a drive and almost caught pneumonia.....
    Toy4X4 likes this.
  13. May 23, 2021 at 8:18 PM
    mousemeat
    mousemeat New Member
    Memphis, TN.
    1997 4 runner limited
    welcome to the forum
  14. May 24, 2021 at 2:48 AM
    Welcome from Wisconsin! Don't forget the air filters; engine, cab. Breathers to the differentials. It will be a little work, but, what a vehicle!
  15. May 24, 2021 at 3:33 AM
    Daddykool
    I know the radiator can go once you get up around 125k-150k miles. I imagine time can also cause deterioration. Replacement with an OEM one may be a good idea.
    28k miles? Wow!
  16. May 24, 2021 at 8:07 AM
    mousemeat
    Memphis, TN.
    exactly. first thing I did after getting my 4 runner, was to flushed out the radiator...after viewing it, decided to replace with OEM..and I replace 02 sensors, and valve cover gaskets..it was money well spent..and peace of mind...
    mauspalls and Daddykool[QUOTED] like this.
  17. May 24, 2021 at 12:18 PM
    PhantomTweak
    Patrick
    OREGON
    Honestly, I'm a huge fan of OEM parts. Having said that, I replaced my 87 trucks' radiators with all metal, 3-core, radiators. That was nearly 30 years ago, and the one in the pickup is still working great. The 4Runner's blew it's top tank off a few years ago, but I really feel I got my money's worth out of it. It's got a regular, plastic tank radiator in it now, but when I get the money, I plan on another all metal, maybe 3-core. Depends on the price difference between 2 and 3 core prices.
    Other than the radiator, yeah, OEM all the way.
    Pat☺
    bran[OP] and negusm like this.
  18. May 25, 2021 at 7:17 AM
    Agreed. The TOYOTA radiator is fine for cars going 150k miles and 12 years.
    It is junk for our cars which go 30 years and 300k miles.
    Next T-Belt change, I'm going to get a full metal one.
    bran[OP] and PhantomTweak like this.
  19. May 25, 2021 at 11:47 AM
    mousemeat
    Memphis, TN.
    get the repairs and upgrades...etc.....it will be money well spent
  20. May 31, 2021 at 9:03 AM
    BABYTOYODA
    BABYTOYODA New Member
    2000 Limited
    if truely only 28k miles and if mint condition I'd clean it up and auction it might go for over $20k maybe even $30k
  21. May 31, 2021 at 9:11 AM
    Welcome from Arizona! Sounds like a great find.
  22. May 31, 2021 at 10:25 AM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    Dump all fluids.
    See if you can drain the gas tank.
  23. May 31, 2021 at 10:29 AM
    BABYTOYODA
    2000 Limited
    put seafoam in it .... dont spill any on your trim as will remove it
  24. Jun 4, 2021 at 5:25 PM
    mousemeat
    Memphis, TN.
    exactly....and that's why I ankled the Isuzu trooper group..after owning one for 28 yrs..I owned a first gen 2.8 v6 5sp...problem being, Isuzu has quit selling in the U.S. and no longer stocks parts...and unlike 4runner, Landcruisers, FJ cruisers, there's no third party vendors making decent OEM items...last time my Trooper broke down, I was down for 13 days, until I was able to locate a rare part....and it's only going to get worst for my Isuzu team mates...Always been a huge 4runner fan...and when the chance of getting a 3rd gen at a very reasonable price came up, I jumped at the chance...bought it..and sold off my Trooper and cache of extra parts within a day..
  25. Jun 4, 2021 at 6:25 PM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    We need more to that story. Is it a family member's car?
    I would run a Carfax on the vin. Sounds a little too good to be true. Pretty easy to roll back an odometer these days.
    A carfax ought to show some service history and at what miles.
  26. Jun 4, 2021 at 9:12 PM
    Try finding parts for a car that they only made 1500 of and maybe only 50 are left. I've tracked down some very hard to find parts over the years. Paid stupid money for some of them. Currently have a 90 year old car (probably 1 of a dozen left alive) and I need to get it started. She's complete but I pray I don't have to have something replaced. Luckily cars that old used parts across models AND makes. But I digress...
    Parts for 3rd Gen 4Runners are easy to find now. But they will probably go the way of the 1st/2nd gens soon enough. I'm already seeing parts disappearing from TOYOTA's catalog. The interior stuff is falling away but the mechanical stuff is probably going to be easy to get for a good while.
  27. Jun 5, 2021 at 7:59 AM
    diverdon
    diverdon New Member
    Don
    Florida
    21 t4r sr5 premium
    Welcome from northern NY. Post up a pic of your ride
  28. Jun 5, 2021 at 8:52 AM
    BABYTOYODA
    2000 Limited
    are you going to get any parts to hold onto? if so what?
  29. Jun 6, 2021 at 11:15 PM
    Me?
    For this car? I'm not. Not worth restoring. I don't think anyone will look to restore these cars.
    But if you wanted to die on the hill of restoration, go on a hunt for "soft" easily damaged fabric/plastic parts:
    Seat upholstery. It's almost all gone from TOYOTA. Maybe a search of dealerships across the US may net some. Alternatively, hunt for exceedingly low mileage seats.
    Dash Pad. Good luck on this one.
    Door panels.
    Interior plastic parts.
    Under hood fire pads. Been offered hundreds for one (not 4Runner).
    Exterior plastic (side flares).
    Weatherstripping.
    Then you can get into things like the retracting antenna mast, radio, carpet, headliner, evap system...the list is endless.
    Then after you've spent thousands, store it all in a climate controlled environment until you decide to do a proper resto.
    I did buy rear hatch shocks and a retracting antenna mast from TOYOTA since I know those won't last forever.
  30. Jun 14, 2021 at 7:00 PM
    BABYTOYODA
    2000 Limited
    the shocks on mine are out keep hitting my head and shocked I havent forgeten to put the antenna down for the car wash... I dont think it would survive lol
