20" LED light bar mounted behind upper grill on 2019 TRD PRO ?
Discussion in '5th Gen 4Runners (2010-2024)' started by oldtimer, Aug 20, 2019.
  1. Aug 20, 2019 at 9:45 PM
    oldtimer
    oldtimer [OP] New Member
    Robin
    Edmonton, Canada
    2020 TRD Pro 4Runner Army Green
    4 x 4 Innovations sliders Greenlane Rear hatch ladder
    Has anyone installed a 20" single row LED light bar behind the upper grill above the "TOYOTA" loga on a 2019 TRD Pro? If so, please comment and or show pictures of mounting brackets. Does grill need to be removed, or can it be mounted with the grill on? Thank you.
  2. Aug 20, 2019 at 11:53 PM
    tommy596302
    tommy596302 New Member
    tommy596302
    2015 4runner
  3. Aug 21, 2019 at 7:13 AM
    8S6RUNNER
    8S6RUNNER New Member
    eddie
    2014 nautical blue 4runner
    TRD Pro 17" matte black wheels Pirelli scorpion a/t 265/70/17
    TRDJON haves a vid of one he just mounted, look it up on youtube
  4. Aug 21, 2019 at 7:15 AM
    oldtimer
    Robin
    Edmonton, Canada
    That Warn bumper looks good too. Did you install a Warn winch with synthetic rope? Looks like an LED will install without having to remove front facia, just the top cover to provide access, and simply drill and mount brackets. Correct? Where did you buy, and what brand is the replacement upper grill? Thanks.
  5. Aug 21, 2019 at 8:33 AM
    tommy596302
    tommy596302
    2015 4runner
    Sorry, I have cleared the photo and will give you a photo tomorrow. The accessory is only $10 at Home Depot.
  6. Aug 21, 2019 at 10:30 AM
    oldtimer
    Robin
    Edmonton, Canada
    No worries. Do the light brackets fit existing bolt holes located behind the upper grill, or did you have to drill new bolt holes? I'm hoping the install is just that easy, other than wiring through fire wall to an empty switch receptacle. Thanks again.
  7. Aug 21, 2019 at 12:10 PM
    AVH128AVH128
    AVH128AVH128 New Member
  8. Aug 21, 2019 at 7:58 PM
    redneckj
    redneckj New Member
    2018 TRD Off Road 4Runner
    working on it
    I looked for the 20" bar video on youtube and couldnt find it. Please post the link, Thanks in advance!!
  9. Aug 22, 2019 at 1:00 AM
    tommy596302
    tommy596302
    2015 4runner
  10. Aug 22, 2019 at 3:07 PM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Found this: Post 201
  11. Aug 22, 2019 at 3:52 PM
    oldtimer
    Robin
    Edmonton, Canada
    Thanks and much appreciated.
  12. Aug 23, 2019 at 7:54 PM
    oldtimer
    Robin
    Edmonton, Canada
    RedRunner87 likes this.
  13. Aug 23, 2019 at 8:18 PM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Looks like a good plan! I am debating installing an 21" Extreme LED knock-off in the upper grill or getting a bigger ExtremeLED knock up in the lower grill.
  14. Aug 23, 2019 at 9:42 PM
    oldtimer
    Robin
    Edmonton, Canada
    The 4"? slot hole L brackets you mounted your light bar with are very difficult to find. If you have a link, please forward. Thanks. I have a 22" 280W 28000LM dual row light bar, harness and 4runner light bar switch on order.....
  15. Aug 23, 2019 at 9:48 PM
    oldtimer
    Robin
    Edmonton, Canada
    I ordered this wiring harness for the light bar i have on order from Amazon.
    Liteway One-To-Two Universal LED Light Bar Wiring Harness Kits 24V/40A Relay ON-OFF Blue Laser Rocker Switch Weatherproof(2 Lead 12ft)
    Also ordered a 4runner light bar switch.
  16. Aug 24, 2019 at 12:25 AM
    tommy596302
    tommy596302
    2015 4runner
  17. Aug 24, 2019 at 12:26 AM
    tommy596302
    tommy596302
    2015 4runner
  18. Aug 24, 2019 at 12:31 AM
    tommy596302
    tommy596302
    2015 4runner
  19. Aug 24, 2019 at 8:37 AM
    oldtimer
    Robin
    Edmonton, Canada
  20. Aug 24, 2019 at 11:39 AM
    tommy596302
    tommy596302
    2015 4runner
    Personal preferences can be different colors.
  21. Aug 24, 2019 at 12:53 PM
    oldtimer
    Robin
    Edmonton, Canada
    glad to hear the reason is personal preference and not a matter of necessity to replace factory grill panel. As you might have guessed, I don't like to make assumptions;-)
  22. Aug 24, 2019 at 6:54 PM
    oldtimer
    Robin
    Edmonton, Canada
