2.5-3" Lift for front
Discussion in '4th Gen 4Runners (2003-2009)' started by CaBurghfan, Feb 26, 2024.
  1. Feb 26, 2024 at 8:53 AM
    CaBurghfan
    CaBurghfan [OP] New Member
    2007 4runner V8 SR5
    Good morning, first time are, hoping for quick fix advice. Purchased my son a 2007 V8 SR5, 2wd. He wanted 33 inch tires, so he bought some Icon rear springs and some front Bilstein 5100's (used) with coils already on. Thought he could do it with a friend, and the backs came out great, but the fronts didn't achieve any lift at all, and tires are rubbing, and alignment is out of whack.
    So he agreed with me we should just grab a decent, not necessarily top end, just a decent pair of struts/springs for now. Don't know if I should just buy the new coils and utilize the used 5100s, or buy new both. It's all new to me, as I had a 2004 4runner that I loved and got to 375k, but left it all stock.
    Anyway, looking for suggestions to solve the lift in the front. Appreciate any replies!
  2. Feb 26, 2024 at 1:40 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Hey OP,
    Welcome here.
    Glad to help,
    I have 5100's on all 4 corners. I also have ICON rear coils. In the front I would keep the used Bilsteins until it's confirmed if they have any problems.
    Sounds like maybe there's OE springs, no lift springs? And the front Bilsteins are ride height adjustable.
    You need to either add front lift springs (longer than stock), and leave the spring perch on the lowest groove.
    That's what I did, I have Old Man Emu 2884 stock load weight springs. Only slightly higher spring rate.
    Or
    Adjust the spring perch to higher up ring grooves, this will give you lift but also compresses the spring more and more stiff (from what I gather)
    CaBurghfan[OP] likes this.
  3. Feb 28, 2024 at 6:36 AM
    CaBurghfan
    2007 4runner V8 SR5
    Thanks, now I have a dumb follow up question. As I said, I left mine stock, so I have zero to little knowledge of lifting components. He put on the 5100 at the highest setting, yet the springs didn't look as beefy as the ones we took off, and the result was no lift. First, how do we know it's not an issue with the 5100s, and second, assuming they're fine, I would like to simply grab a new set of springs that are for sure beefy enough to hold the V8 at abiut 2.5". The shop where I am going to have them installed said OME 2885 is what their computer shows. Would hate to pay to install them and have them be insufficient, so wanting to make sure before slapping them on.
  4. Feb 28, 2024 at 7:05 AM
    CaBurghfan
    2007 4runner V8 SR5
    So this is what came off, Monroe quikstrut with these springs. They seem really beefy, 9 coils and measure 14" long. Then these are the bilsteins we put on the car, looks like only 6 coils, but you can see the setting is at 2.5 lift, yet no lift.
    I am wondering what the old springs are. The only markings are tags that say 152t and 153t which I think are left and right designator. I wonder if the old springs on the 5100s would work. Have to make a decision soon for my appt, to see if I 20240228_065811.jpg 20240226_125132.jpg should order new springs.
  5. Feb 28, 2024 at 1:25 PM
    @CaBurghfan appreciate the information and photos, this helps.
    So ya it looks likes the springs that came with the struts are a combination of a few things, all leading to no lift:
    Could be under a lot of preload on the highest settings (from what I gather),
    Springs compressing under 4R weight due to sprint rate lower than stock 590lbs,
    and also perhaps aftermarket / insufficient strength/length. They look very short, where they sit, yes.
    By all means yes, install the OE springs with the Bilstein’s, that’s what the majority of folks do with 5100’s. I’ve found there’s lot many people who add lift springs and run lowest perch setting like I do.
    2885’s are amazing and will hold your lift and some armour, prolly a winch. I wish I did them.
    I plan to raise my front 5100’s to .85” and add center winch bumper, finished with a 1” body lift.
  6. Feb 28, 2024 at 1:34 PM
    These are my ome coil spec notes:
    *check out 2885 free height and bar diameter
    Coil specifications:
    OME 2881: 96-02 4runner - Heavy load: 1.25"
    OME 2883: 96-02 4Runner - Heavy load: 2.5"-3"
    OME 2884: 10-23 4runner - Stock load: 3" / 03-09 4Runner - Stock load: 1"
    OME 2885: 05-15 Tacoma - Stock load (0-110lbs): 2" / 10-23 4runner - Medium load (70-180lbs): 3" / 03-09 4Runner - Medium load (70-180lbs): 2"
    OME 2886: 05-23 Tacoma - Heavy load (110-220lbs or with bumper and winch): 2" / 03-09 4Runner - Heavy load (230lbs+): 2.5"
    OME 2887: 10-23 4runner - Heavy load (230lbs+), 3", 16-23 Tacoma - Stock load: 2"
    OME 2888: 16-23 Tacoma - Medium load (with bumper): 2"
    2884 Technical Specs
    Free Height: 390mm
    Bar Diameter: 16.5mm
    Spring Rate: 590Lbs
    Lift Height
    4RUNNER 2003+:
    2003-2009 4Runner 4WD (stock with no bull-bar or winch) - Approximately 1.5"-1.7" Lift
    2010+ 4Runner 4WD (stock with no bull-bar or winch) - Approximately
    2885 Technical Specs
    Free Height: 395mm
    Bar Diameter: 17mm
    Spring Rate: 590Lbs
    Lift Height
    4RUNNER 2003+:
    2003-2009 4Runner 4WD (stock with 70-180lbs bull-bar and winch) - Approximately 2" Lift
    2010+ 4Runner 4WD (stock with 70-180lbs bull-bar and winch) - Approximately 3" Lift
    2887 Technical Specs
    Free Height: 400mm
    Bar Diameter: 17mm
    Spring Rate: 590Lbs
    Lift Height
    4RUNNER 2003+:
    2003-2009 4Runner (with bull bar or winch) - Approximately 2"-2.25" Lift
    2010+ 4Runner (with 230Lbs+ of bull bar and winch ) - Approximately 2.5"-3" Lifts
  7. Feb 28, 2024 at 7:16 PM
    CaBurghfan
    2007 4runner V8 SR5
    Ok, thanks. So I just measured the coils in the first photo, they are 14". The coils currently on the bilsteins are 12". I'm going to switch out springs and see what haplens.
  8. Feb 29, 2024 at 8:47 AM
    Are we talking about springs being 12" length under vehicle sprung weight tho?
    Or, are they two inches shorter when removed from vehicle?
    fyi the OME springs I recommended are 15-1/2" length
