$2.25 tire deflator
Discussion in 'General 4Runner Talk' started by VaRunner, Jul 30, 2021.
  1. Jul 30, 2021 at 1:56 PM
    VaRunner
    VaRunner [OP] New Member
    2008 4 Dog
    None yet.
    Extended valve stem, valve cap, bead. Use a nail or punch to press the plunger out as far as it will go, hold it out with vice grips. Two opposing cuts with a small Dremel cut-off wheel. Release the vice grips, drop a bead in the cap and tighten.
    55 seconds gets my tires from 32# to 20#
    Moon Landing likes this.
  2. Aug 1, 2021 at 4:37 AM
    SendInTheCavalry
    SendInTheCavalry New Member
    M
    Ohio
    Trd Pro
    pretty smart!
    Ive always wondered how those "pre set" ones work?
    I bet when your done every dog intown is sitting behind you.
  3. Aug 1, 2021 at 8:13 PM
    VaRunner
    2008 4 Dog
    None yet.
    Just a spring pushing pressure opposite the escaping air. Tweak it a little until it closes at the PSI you want. Can’t see spending the $$$. I was pretty surprised as how consistent they are.
