1st Time T4R Owner - Initial Maintenance Recs
Discussion in '4th Gen 4Runners (2003-2009)' started by kicker13, May 29, 2020.
  1. May 29, 2020 at 5:04 PM
    kicker13
    kicker13 [OP] New Member
    Hey all! I just traded my 2007 Tacoma TRD for an 05 4Runner Sport 4WD. It's got 177k miles and overall it's in respectable shape. A little rust here and there, couple things that were just kinda neglected etc. I wanted to get some input on where to start making improvements after giving some context on my immediate steps.
    Always been a synthetic oil and K&N filter guy so that will happen this weekend.
    The gas cap cover pops open without pulling the lever so I'm assuming it's a cable issue?
    There's a shake on braking from speed, especially downhill. Mechanic said rotors hadn't been rotated maybe ever so I ordered a full set of rotors and pads from Powerstop. Any other input on that issue would be appreciated.
    There's a rumble/shake around 60-65mph that I'm assuming is because the tires need balanced. Will get them balanced next week before eventually upgrading.
    My main questions are:
    1. What main red flag issues do I need to look for?
    2. What should my next maintenance moves be?
    3. Leveling kit vs suspension lift pros/cons?
    4. Any other advice that I need to know about T4R ownership that I wouldn't have learned driving a Tacoma!
    Thanks everyone!
  2. May 30, 2020 at 1:20 PM
    FFloresjr775
    FFloresjr775 New Member
    2005 4Runner
    The main concern would be Head Gaskets, had a slight gasket leak heads were not warped so had them replaced over 2 years ago and runs like new. love the 5 speed transmission seems to have a better jump than the 04
    kicker13[OP] likes this.
  3. May 30, 2020 at 6:19 PM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    V6 or V8? Drive belts, fluid changes or at least drain and fill, hoses, Timing belt if V8.
  4. May 30, 2020 at 7:51 PM
    Welcome.
  5. May 31, 2020 at 6:05 AM
    kicker13
    V6. And thanks for the inputs and welcome!
  6. Jun 2, 2020 at 2:00 PM
    kicker13
    Anyone else?
  7. Jun 14, 2020 at 1:45 PM
    chassis
    chassis New Member
    Indiana
    Sold: 2005 4Runner SR5 V6 4WD
    It's a solid vehicle. I am not a fan of lifts, mods, etc. I keep cars bone stock. They work best that way.
    Some things to check or work to do:
    - transmission oil change
    - front axle oil change (search this site, the drain plug is a beast)
    - transfer case oil change
    - rear axle oil change
    - engine oil and filter change
    - engine air filter change
    - cabin air filter change (access via glovebox removal)
    - new tires and balanced
    - new rotors and pads all around
    - new shocks if needed
    - new hood gas struts
    - new rear liftgate gas struts if needed
    - verify all lights/bulbs work, including instrument panel. The small LEDS are cheap, available and easy to replace.
    - verify A/C blows cold. Evaporator leak is a common high mileage situation, replacement is expensive and time consuming. One can of refrigerant per year is the solution.
    - install bluetooth touchscreen stereo system
    - verify sunroof operation
    - replace headlamps with new Toyota OEM units if hazed
    - coolant top up or replacement if you wish
    - top and bottom coolant hose replacement
    - battery replacement
    - windshield and rear liftgate wiper replacement
    - shampoo and vacuum carpet twice
    - new Toyota OEM floor mats, you will thank yourself for eliminating all smells from the vehicle
