1999 4Runner P0409 code
Discussion in '3rd Gen 4Runners (1996-2002)' started by franzo111, Aug 2, 2022.
  1. Aug 2, 2022 at 2:24 PM
    franzo111
    franzo111 [OP] New Member
    Frans
    1999 Toyota 4Runner
    Hello,
    I’m having this issue with solving a P0409 code. I’ve changed the spark plugs, the EGR valve & the vapor canister purge solenoid. However this still persists. The code only comes on when I start driving when the engine is cold. It does feel a little sluggish at first. If I let the engine warm up, it won’t trip the fault code.
    Thoughts?
  2. Aug 2, 2022 at 6:49 PM
    What engine? What transmission?
  3. Aug 3, 2022 at 6:33 AM
    franzo111
    Frans
    1999 Toyota 4Runner
    4 cylinder, automatic transmission
  4. Aug 3, 2022 at 7:17 AM
    P0409 = Exhaust Gas Recirculation Sensor "A" Circuit
    https://www.obd-codes.com/p0409
    I don't know this engine but from a little research it seems that it's probably the sensor for the EGR is bad since you replaced the EGR. Have you replaced the EGR sensor?
  5. Aug 3, 2022 at 7:35 AM
  6. Aug 11, 2022 at 4:17 PM
    franzo111
    Frans
    1999 Toyota 4Runner
    Hello and thank you for this thorough reply. I must self disclose that I remembered the code number incorrectly, the correct fault code is P402 which also happens to be an EGR problem potentially.
    Since I’ve already replaced the EGR valve and solenoid, I’m suspecting the ignition system. The check engine will not illuminate when I warm up the car before driving it.
    thoughts?
    thank you in advance!
  7. Aug 11, 2022 at 4:51 PM
    P0402 = Exhaust Gas Recirculation “A” Flow Excessive Detected
    The ECU is detecting excessive exhaust flow through the EGR.
    Why would you think the ignition system is an issue? That makes no sense to me.
    A search for 4Runners with that code, it seems the most common fix seems to be replacing all your vacuum lines to and from the EGR. Some good info here... There is an EGR switching valve that also fails.
  8. Aug 12, 2022 at 8:09 AM
    franzo111
    Frans
    1999 Toyota 4Runner
    Hello, thank you for your prompt response.
    The reason I was suspecting the ignition system is because when I changed the spark plugs, the P402 code was not tripped as often and it started running better at idle than before. But maybe that was a separate non-related issue.
    I have already changed the EGR switching valve and that didn't help. Perhaps I need to start taking a closer look at the vacuum hoses.
    Thoughts?
    Thanks!
  9. Aug 12, 2022 at 8:50 PM
    Engines are air pumps. Running better means more air is moving through the engine, which means more circulating gases. I imagine that means more air through the EGR and this code trips faster because of it.
    The computer is literally telling you which system is the issue...so while it's good to look at everything as a whole, I'd stay focused on the EGR system.
  10. Oct 22, 2022 at 12:33 PM
    franzo111
    Frans
    1999 Toyota 4Runner
    I never did locate the vacuum leak but the head gasket blew last week. Made it home the last bit on 2 cylinders. I’m suspecting a leaky head may have had a hand in this issue. Taking it all apart as we speak.
