1999 4 Runner won’t start
Discussion in '3rd Gen 4Runners (1996-2002)' started by franzo111, Jun 17, 2022.
  1. Jun 17, 2022 at 8:22 PM
    franzo111
    franzo111 [OP] New Member
    Frans
    1999 Toyota 4Runner
    Hello,
    I’ve changed the starter and the battery has 12.5v. I’m suspecting the ignition switch? Is that a difficult replacement? When I turn the key nothing happens but everything electrically works fine.
    thoughts?
  2. Jun 17, 2022 at 10:07 PM
    Could be the starter relay.
    franzo111[OP] and mousemeat like this.
  3. Jun 18, 2022 at 3:04 PM
    franzo111
    Frans
    1999 Toyota 4Runner
    Let me try that
  4. Jun 18, 2022 at 4:15 PM
    wdsteven
    wdsteven New Member
    Keep it simple look for the simple issues such as fuse first next have someone turn the Key can you hear a relay click? (turn the key to first position then to start position because other relays click on first) then since you replaced starter now it does not work go back and Check your wire connections. Also more details like why did you replace the starter in the first place because it was failing or for the same issues you currently have ?
    franzo111[QUOTED][OP] likes this.
  5. Jun 19, 2022 at 2:25 AM
    mousemeat
    mousemeat New Member
    Memphis, TN.
    1997 4 runner limited
    relay ?
    franzo111[OP] likes this.
  6. Jun 19, 2022 at 4:27 AM
    wdsteven
    wdsteven New Member
    old term for Solenoid the Early Toy's had much larger Relays with Magnetic Coils that close / open Electrical contacts and you can hear a loud Click when they get power.
  7. Jun 19, 2022 at 7:12 AM
  8. Jun 19, 2022 at 5:47 PM
    franzo111
    Frans
    1999 Toyota 4Runner
    It only happens every now and again so I figure it was the solenoid when the starter is hot. That’s why I changed the starter. Even when it doesn’t start, I do not hear a click.
  9. Jul 11, 2022 at 8:09 PM
    franzo111
    Frans
    1999 Toyota 4Runner
    This did the trick! Nice work!
    Malinois38 likes this.
  10. Jul 12, 2022 at 4:09 PM
    Sweet! Thanks for letting us know.
