18k Miles '22 ORP - Transfer Case & Front/Rear Diff Fluid Change
Discussion in '5th Gen 4Runners (2010-2024)' started by S8ULATR, Jan 10, 2026 at 8:53 PM.
  1. Jan 10, 2026 at 8:53 PM
    S8ULATR
    S8ULATR [OP] New Member
    2 Germans, a Beast, a Jeep, lotsa dogs
    Hi All,
    Hope you all are having a good weekend. Decided to change the fluids on my front & rear diffs as well as my transfer case today. '22 ORP with 18k miles, most all of which have been stacked up from off roading/camping which is pretty much all my 4R sees. Here's my notes:
    *Fun! Not a mechanic by any stretch, but was happy to save the $ vs dealer prices. It was super simple thanks to the tips here and Youtube.
    *Rear diff fluid was surprislingly dark, virtually black. Magnet/drain plug had a good amount of sludge on it. See pics
    *Transfer case fluid was clear and clean.
    *Front diff fluid was pretty darn clear (but green from factory which was interesting, seems the factory used a different fluid than the t-case or rear diff (possibly)). I do use 4wd quite a bit so was kinda surprised it was in such good shape, but pleased.
    So, what I'm taking from this is the rear diff does see some distress, perhaps more than the transfer case or front diff (makes sense given it is always working and the others aren't). If you think you should change the fluid, might not be a terrible idea ?
    Below are some random pics. I will say, gear oil does not smell amazing. Also, the Valvoline squeeze bag thingys are a game changer. Ordered an oil paint marker off Amazon (where I got the crush washers and gear oil too) and marked date/mileage.
    IMG_0690.jpg IMG_0689.jpg IMG_0688.jpg IMG_0686.jpg IMG_0685.jpg IMG_0684.jpg
  2. Jan 10, 2026 at 10:21 PM
    No issues with the hex head front diff plugs?
  3. Jan 10, 2026 at 11:23 PM
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    These hybrid units are great -- 18 kilomiles.
  4. Jan 10, 2026 at 11:41 PM
    S8ULATR
    No issues, but they were less fun than the 24mm standards on the rear diff. Just have to make sure the hex is fully in there/seated before removing/torqing. Believe I read some folks order the Lexus GX plugs (which are a standard / non hex) to replace, which I can see as a reasonable thing to do.
  5. Jan 11, 2026 at 1:49 AM
    Congrats on your first? gear oil change. I use the same Valvoline gear oil bags and your right, those bags are a game changer! :)
    S8ULATR[OP] and Thacrow like this.
  6. Jan 11, 2026 at 2:32 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Good job doing it yourself!
    S8ULATR[OP] and ChessGuy like this.
  7. Jan 11, 2026 at 3:46 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Good job on doing your own work! I always recommend doing the rear diff early. Every one I've worked on, the fluid has been black, even at 10K. Good time to lube your driveshafts, too!
    ualfltdispatch and S8ULATR[OP] like this.
  8. Jan 11, 2026 at 6:17 AM
    2020 Venture / 2017 Tacoma
    ^Indeed. Great job for doing it yourself. Good pics too.
    Thacrow[QUOTED] and S8ULATR[OP] like this.
  9. Jan 11, 2026 at 9:03 AM
    S8ULATR
    Yes I remembered seeing a video on that and need to do that next! You're right, would have been the perfect time while I had that front diff shield already off.
  10. Jan 11, 2026 at 9:08 AM
    S8ULATR
    Yup, it was my first on the 4R and won't be my last given the quotes I got from the local dealers, yikes. Will definitely do at least the rear diff every 10-15k / 2-3 years. It really was kinda fun working on it, only one bruised thumb :)
  11. Jan 11, 2026 at 9:39 AM
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    4Runners are exponentially more fun to work on when they're 17 years old!
    S8ULATR[OP] likes this.
  12. Jan 11, 2026 at 10:12 AM
    java
    java phoRunner
    2023 ORP ice cap
    too poor for mods
    Thanks for sharing! I did mine at around the same mileage and I found the front plug had more sludge than the rear one.
    S8ULATR[QUOTED][OP] likes this.
  13. Jan 11, 2026 at 12:40 PM
    :laughing: OP is constantly subjected to cancer and reproductive harm, but rust is generally not a concern.
    Nick B and S8ULATR[OP] like this.
  14. Jan 11, 2026 at 5:26 PM
    S8ULATR
    Haha we have to take our wins where we can get 'em :)
    3JOH22A[QUOTED] likes this.
  15. Jan 12, 2026 at 9:26 AM
    so there is no issue going with 75-90? Toyota calls for 75-85. I have redline 75-85 going in today.
  16. Jan 13, 2026 at 5:08 AM
    Guppy1301
    Silver 2019 TRD ORP
    None at all. I've used 75w-90 for all my Toyotas going back to 1986.
  17. Jan 13, 2026 at 6:59 AM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    My understanding is GL-5 for the diffs and GL-4 for transfer case, and there is a Toyota spec for approved formulas. Something about TC synchros not liking some GL-5 ingredients?
  18. Jan 13, 2026 at 8:41 AM
    Grug556
    Grug556 New Member
    Kings, Crestone Rack, Baja S8, Baja Fogs, Baja XL80s, Baja mini cubes, SPOD, ARB compressor, RCI full skids, ROAM box and stuff. ST Pros. Shrockworks sliders... GOAT armour
    I did TC Redline 75-85 and front/rear diff 75/90 Redline. Been in 2 years. Seems ok
  19. Jan 13, 2026 at 8:48 AM
    yeah, i will probably just stay with redline 75-85. I got one of those "pump" fillers for the fluid. Game changer. Pour the gallon of redline into it, pump it up, insert the nozzle into the dif and turn on the valve.
  20. Jan 13, 2026 at 9:01 AM
    Hungryhawk
    Southern CA
    2017 SR5
    Redline makes a Toyota TC formula.
  21. Jan 13, 2026 at 12:53 PM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    That's what I used for my transfer case on my old '21 4Runner. And 75W85 in the front and rear diffs
