17x8.5 Wheels, will I need spacers?
Discussion in '5th Gen 4Runners (2010-2024)' started by Spamlish, Oct 9, 2020.
  1. Oct 9, 2020 at 1:15 PM
    Spamlish
    Spamlish [OP] New Member
    4runner TRD Offroad Premium
    I just acquired 17x8.5 wheels from a friend, 0 offset, will I need spacers? what tire would be good for All-terrain? Model is 2020 TRD Offroad Premium any help is good help. Thank You
  2. Oct 9, 2020 at 1:46 PM
    Dark Knight
    Dark Knight Get off my lawn
    All depends on the wheel design but likely not assuming you got 6on5.5 lug pattern wheels for a Toyota. 265/70/17 tires if you’re not lifted.
    Spamlish[OP] likes this.
  3. Oct 9, 2020 at 1:57 PM
    No. Spacers might cause your tires to rub.
    There are a lot of good AT's to choose from. Wildpeak AT3W, Toyo AT3, BFG KO2, and Nitto ridge grapples are probably the most popular here.
    Welcome to the forum!
    Toy4X4 and Spamlish[OP] like this.
  4. Oct 9, 2020 at 2:20 PM
    Spamlish
    Thank for the quick responses! And for the welcome, had a 2010 until this year traded in for the 2020, might as well put it to use!
  5. Oct 9, 2020 at 2:29 PM
    Welcome.
  6. Oct 9, 2020 at 5:03 PM
    Welcome to the forum Adam
  7. Oct 11, 2020 at 8:40 AM
    ATCRich
    ATCRich New Member
    Rich
    2020 Super White TRD ORP
    Welcome to the forum Adam! Let us know which setup you end up going with!
  8. Oct 15, 2020 at 9:09 PM
    BOLTRNR
    BOLTRNR New Member
    Pete
    2020 White 4Runner TRD Off-Road
    Cali Raised Rock Sliders 3” Old Man Emu Suspension Lift Method 701 Race Wheels in Matte Black Falken Wilpeak AT3W 285/75/17s Spidertrax 1.25” Wheel Spacers
    Adam - with my 2” OME lift I just put Wildpeak AT3W 285/75/17s on along with Spidertrax 1.25” wheel spacers... It’s the absolute perfect tire size but the spacers are too much. If I can find a 3/4” spacer I’ll switch to that. Anyone have suggestions?
  9. Oct 16, 2020 at 6:25 AM
    S4ndb4r
    S4ndb4r New Member
    Steve
    2018 LTD
    TBD
    What wheel are you running With that spacer? You will have get to a new wheel that has -.75” backspace of what you have now. There’s no .75 wheel adapter like spidertrax and you don’t want to run a real spacer.
  10. Oct 16, 2020 at 6:27 AM
    S4ndb4r
    S4ndb4r New Member
    Steve
    2018 LTD
    TBD
    How wide of a tire do you want? Are you staying stock with the suspension? If so go 265/70/17 or maybe 255/75/17. If you are going to add a lift you can get into some other sizes.
  11. Nov 6, 2020 at 11:00 AM
    Spamlish
    Here is the outcome! im very happy and thank you all!!!
    Black Rhino 17 in. Grange Wheels
    BFGoodrich tires KO2
    last set is black cover all lugs
    mrmike7189 likes this.
  12. Nov 6, 2020 at 5:02 PM
    mrmike7189
    mrmike7189 New Member
    mike
    2020 silver SR5 4x4
    Should be great wheels for the snow season!
    Like
  13. Nov 6, 2020 at 5:17 PM
    Rngr188
    Rngr188 New Member
    Chad
    Harrison, AR
    Silver 20 TRD ORP
    17x8.5 0 offset with factory size Toyo AT3 LT load range E, no spacers no rub.
  14. Nov 7, 2020 at 3:10 AM
    mikeymtbs
    mikeymtbs New Member
    19 TRD ORP
    Another... 17x8.5 0 offset Black Rhino Rumble on Toyo AT3 in 265/70-17. The wider wheel spreads the stock size tires out nicely. No rub. The Toyo tires are quiet and ride fantastic.
  15. Nov 7, 2020 at 7:57 AM
    joeman
    joeman New Member
    Scottsdale, AZ
    2020 4Runner Venture
    Love the wheels, looks fantastic! Quick question please, is this on the stock suspension? Thanks!
  16. Nov 7, 2020 at 8:11 AM
    Rngr188
    Rngr188 New Member
    Chad
    Harrison, AR
    Silver 20 TRD ORP
    Thanks! Yes stock suspension, the wheels make the tires look bigger. I'm currently weighing my options on lifting and have decided I might go 2" front 1" rear since I already have the tires which are stock size and don't want to look goofy.
    joeman[QUOTED] likes this.
  17. Apr 16, 2023 at 1:09 PM
    jjgandarillas
    jjgandarillas New Member
    2016 Grey 4runner
    Custom leather interior professionally installed, JBA high caster UCA, 3” lift unknown, 33” tires
    Can I see how much these poke out? I want to get a set but they only make them with a -10 offset and I’m worried they might be too wide
  18. Apr 16, 2023 at 1:28 PM
    Nwsd
    Nwsd New Member
    Oregon
    '23 TRD OR
    I have 17x8.5 0 offset. I had stock size toyo at3 that rubbed.... not bad. A quick fender adjustment would have fixed it. But I got rid of them for other reasons and now have Michelin at2. Same size but no rub.
