17x8.5 wheel offset for a stock OR
Discussion in 'Wheels & Tires' started by afret, Nov 17, 2021.
  1. Nov 17, 2021 at 11:05 AM
    afret
    afret [OP] 2022 ORP, KDSS, Toyo AT3
    North Idaho
    Found a nice wheel on Discount Tire which shows it fits a 4R with 265/70 tires and gives two offsets. 0 and +18. Which one would give better clearance with the 265/70 tires? Haven't read about anyone using a +18 but lots with the 0 offset.
  2. Nov 17, 2021 at 11:19 AM
    dustinb14
    dustinb14 New Member
    2021 Magnetic Gray TRD Offroad Premium
    The +0 offset still sits slightly inside the fenderwell, but is 3/4" more aggressive offset than the +18. That's why it's so popular, gives it a more aggressive look than stock without sticking out past the fender and slinging stuff up the side of the truck. Either offset would work ok though! If you get too wide of a tire you'll have problems with rubbing the UCA with +18 but with 265 you don't have to worry about that. My opinion, go +0.
  3. Nov 17, 2021 at 11:49 AM
    afret
    North Idaho
    Thanks for the good advice. I'm leaning toward the 0 offset you recommend. The +18 is only 3mm more than the stock OR wheel and moves the tire only about 0.12" inboard but the one inch width increase of the new wheel would add another 0.2 inch for a total of 0.32" inboard. Seem like people have put 285/70 tires on the stock OR wheel which would add 0.20 inboard since the measuring rim for the 285 is an 8.5" wide wheel compared to the 7.5" OR wheel. So how much clearance does the stock OR have to the UCA? I had a deposit on a Limited but changed to an ORP. I liked the stuff that the Limited came with but didn't care for the looks.
  4. Nov 17, 2021 at 1:51 PM
    dustinb14
    Not sure about with the stock OR wheel, but I've got 17x8.5 +0 and 285's and have a good 1.25"-1.5" between the tire and UCA.
  5. Nov 17, 2021 at 2:55 PM
    afret
    North Idaho
    Thank you for taking the trouble of checking and getting a measurement!
  6. Nov 17, 2021 at 3:27 PM
    dustinb14
    No problem! If you have any questions I'll try to help you out. I've sold wheels and tires for a living for the past 20+ years lol.
    Spare Parts likes this.
  7. Nov 17, 2021 at 3:32 PM
    afret
    North Idaho
    OK so If I go with the 0 offset, would the 4R need an alignment vs the +18? Thanks!
  8. Nov 17, 2021 at 4:14 PM
    dustinb14
    No, the only thing that will change your alignment is suspension modification. Nothing to do with the tires or wheels.
  9. Nov 17, 2021 at 5:44 PM
    afret
    North Idaho
    OK, great! Thank you very much!!!
  10. Nov 22, 2021 at 3:53 AM
    FourRunnerFor4
    FourRunnerFor4 New Member
    ‘22 TRDOR, KDSS, Lunar Rock
    I hope this post is ok here, I’ve looked around and haven’t found much info. I am switching over from a Tacoma with 17x9 SEMA wheels with 0 offset with 265/70/17 Wildpeaks. The wheels and tires are basically brand new, and I would love to put them on the new 4R. Would this setup fit with no rubbing without a lift?
  11. Nov 22, 2021 at 8:05 AM
    afret
    North Idaho
    From what I've read, the Wildpeaks are on the wide side compared to other tires of the same size so the odds of rubbing goes up with those tires.
  12. Nov 22, 2021 at 9:39 AM
    dustinb14
    @afret is right. I have a 265/70r17 wildpeak at3w right here measuring 9" tread width compared to this Nitto ridge grappler measuring 8.5". I still wouldn't expect any issues. I don't remember having to trim any on new 4Runners running 265's and +0 offset. Worse case, a full turn could rub front inner fender slightly. Can take a dremel and shave a little off if need be. I had to do that do mine on 285's and 3" lift. Just holler at me if any rubbing and I can help you with what to do, but you should be fine.
    Other thing to consider is TPMS. The 2020+ 4Runner uses a different sensor than older models. Do you know what year Tacoma they're off of?
  13. Nov 22, 2021 at 10:30 AM
    afret
    North Idaho
    What are your thoughts on a slightly taller but skinnier tire and effects on chances of rubbing? The Cooper AT3 265/70 is 31.4" tall (seems like most are 31.7") and the tread is 8.6" wide. The AT3 255/75 is 32" tall but the tread is only 7.8" wide. I wonder if it decreases the odds of rubbing?
  14. Nov 22, 2021 at 10:52 AM
    dustinb14
    It would probably end up being a wash as far as clearance. IMO I'd stick with the 265/70r17. Much more common size and if you're not lifting it, the front fender is plenty full (as far as height) with the 265/70r17 already.
  15. Nov 22, 2021 at 1:42 PM
    FourRunnerFor4
    Thanks for your reply! They are off a ‘18 Tacoma and they just barely rubbed when slowly turning sharp on an uneven road or into my driveway. I was planning on just having the sensors swapped from the stock tires to the wild peaks if I go that route. That’s what the tire dealer did when I had them put on my Tacoma. I had the sensors swapped back into the old Tacoma wheels and tires so there’s not any on the wildpeaks at the moment.
  16. Sep 7, 2022 at 7:08 AM
    texmax13
    texmax13 New Member
    Tess
    2019 4Runner sr5 premium
    None
    Hey, I know this thread is old; but wondering if you had any advice for me. I have a stock 2019 sr5 premium; the wheels/tires that came stock have a +15mm offset and are 265’s. I’m considering getting new wheels that are 17x8.5 +7mm. Can I get 275’s without rubbing or any mods or should I stick with 265’s?
  17. Sep 7, 2022 at 9:11 AM
    DSRunner
    DSRunner New Member
    You may need to do front fender trim/mod with +7mm because the Pro, with +4mm offset & 265s is trimmed at port. It's an easy job so it should hold you back. Then you should be able to run the +7mm with 275s with no issue.
    texmax13[QUOTED] likes this.
