1” Lower difference at my rear suspension
Discussion in '5th Gen 4Runners (2010-2024)' started by Jefftitop, Jan 17, 2024.
  1. Jan 17, 2024 at 8:49 PM
    Jefftitop
    Jefftitop [OP] New Member
    Jefferson
    5gen
    Dobinsons lift 3”
    Hey ! I installed a 3”Dobinsons’s at my 2017,at the rear left side is 1” lower than right side , what can I do ?
  2. Jan 17, 2024 at 8:51 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    Is your right front corner higher than the left front corner?
  3. Jan 17, 2024 at 8:56 PM
    Jefftitop
    Jefferson
    5gen
    Dobinsons lift 3”
    The rear side ! The left is lower 2cm comparing to right side , DOBINSONS said ,install the RR at RL ,I hope works fine
  4. Jan 17, 2024 at 9:19 PM
    Return the springs?
  5. Jan 17, 2024 at 9:27 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    I asked about the front because that could effect the rear. Good luck resolving your problem!
  6. Jan 17, 2024 at 9:42 PM
    steelevo
    Utah
    Welcome. A little advice below.
    @Rob41 was asking a question to help you out. Rudely correcting with an “!” isn’t going to get you much help on any forum.
    Jefftitop[OP], catbrown357 and Rob41 like this.
  7. Jan 18, 2024 at 8:15 AM
    Jefftitop
    Jefferson
    5gen
    Dobinsons lift 3”
    Thx so much!
  8. Jan 18, 2024 at 5:34 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    KDSS?
  9. Jan 19, 2024 at 7:09 AM
    Jefftitop
    Jefferson
    5gen
    Dobinsons lift 3”
    Doesn’t have Kdss ,yesterday I switch the rear coils ,I’ll see if works
