1” lean on passenger side
Discussion in 'Suspension' started by Groceryrunner, Jul 14, 2021.
  1. Jul 14, 2021 at 8:07 AM
    Groceryrunner
    Groceryrunner [OP] New Member
    2016 4Runner Trail Premium (KDSS)
    Hi everyone! New member here, recently installed a used 2016 factory TRD pro suspension (Bilstein) on my 2016 trail and for some reason the whole passenger side is 1" lower than the driver side. Any idea what it could be? The front coil overs don’t appear to be adjustable. I read online that the driver side is slightly higher because of the gas tank, but 1” seems a bit excessive. Any ideas would be greatly appreciated!
  2. Jul 14, 2021 at 8:12 AM
    4Runner170V
    4Runner170V New Member
    Tony
    Los Angeles
    2014 4Runner Trail
    Do you have KDSS? Manufacture spec is up to .75" lean if you have kdss. You can re calibrate kdss or put Shim on pass side rear spring.
  3. Jul 14, 2021 at 8:14 AM
    Groceryrunner
    Yes. I do have KDSS and my KDSS light is on. How do I go about recalibrating it?
  4. Jul 14, 2021 at 8:19 AM
    Not sure if Toyota dealership near your would be able to take care of this.
    I know dealership near me take care of KDSS issues with one of the members in one of my FB groups. It was a KDSS leak on a 2018, so this should be piece of cake for them. In your case probably loosen the valves and re-calibrate.
  5. Jul 14, 2021 at 8:25 AM
    4Runner170V
    Tony
    Los Angeles
    2014 4Runner Trail
    When they installed new suspension system, they might let kdss stretch too far. First, need kdss check at the dealer. Then re check lean. Kdss need to be supported anytime suspension removed to limit stretch. No kdss, let it hang,
  6. Jul 14, 2021 at 8:42 AM
    Groceryrunner
    Awesome! Thanks guys! I will see if I can get this recalibrated and will give you an update!
