0W-20 and 5W-30
Discussion in '5th Gen 4Runners (2010-2024)' started by morfdq, Dec 8, 2025.
  1. Jan 6, 2026 at 5:25 PM
    #241
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Every dealer and oil change shop I’ve ever visited. Never been recommend 8/16. The dealer when it was new told me 10k and then down to 5k, just like USA shops say ….but that’s not like USA!!
    3JOH22A[QUOTED] likes this.
  2. Jan 6, 2026 at 5:33 PM
    #242
    I'm the only one with professional accreditation:
    tk421, Grug556 and 1SilverRunner like this.
  3. Jan 6, 2026 at 5:48 PM
    #243
  4. Jan 6, 2026 at 5:56 PM
    #244
    Hah
    Labatts may have been popular before my time, statistically zero dudes drink them, but I can still buy Labatt Blue for ya bud
    :canada:
    *edit: that’s the best price you’ll find in bc
  5. Jan 6, 2026 at 7:10 PM
    #245
    BC Hunter and djwantke[QUOTED] like this.
  6. Jan 6, 2026 at 7:12 PM
    #246
    tk421 and BC Hunter like this.
  7. Jan 6, 2026 at 7:20 PM
    #247
  8. Jan 6, 2026 at 9:43 PM
    #248
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Mods? Don’t ask… Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS extended travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics XPR reverse bulbs LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I’m a self proclaimed resident asshole.
    @djwantke I didn’t make the cut? Tf dude.
  9. Jan 6, 2026 at 11:13 PM
    #249
    haha
    well I haven’t noticed you quite as ruthless heartless and antagonistic in good nature as others :p maybe I missed it.
    and my resident asshole comment was compliment to the other two gentlemen, they’re experienced and just aren’t what I call warm n fuzzy ass kissing members. I enjoy their commentary
  10. Jan 7, 2026 at 12:11 PM
    #250
    It looks like it's 8,000km for the first three oil changes and then switches to a 16,000km interval after that.
    Unless I'm reading that wrong?
    kouack likes this.
  11. Jan 7, 2026 at 5:12 PM
    #251
    As shown in the booklet, the "maintenance service" includes oil & filter plus a bunch of other items like inspecting brake pads/shoes. So first three 8000km visits are oil & filter, thereafter the 8000km visits alternate between the costlier "maintenance service" and oil & filter service:
    Typical dealer for example may charge $150 for oil & filter with 0W20, and $300 for "maintenance service".
    BC Hunter likes this.
  12. Jan 8, 2026 at 2:39 AM
    #252
    java
    java phoRunner
    2023 ORP ice cap
    too poor for mods
    Extra virgin olive oil, also handy when I am overlanding and need to toss a salad.
    icebear and Thatbassguy[QUOTED] like this.
  13. Jan 8, 2026 at 6:57 AM
    #253
    UncleShorty
    UncleShorty New Member
    I use a German brand of oil made by Veinner-Schlider for all my lubrication needs. It has never failed me whether mall crawling, overlanding, or idling at a stop light...
    java[QUOTED] likes this.
  14. Jan 8, 2026 at 6:57 PM
    #254
    auspilot
    auspilot DustRunner
    2020 TRD OR
    Dobs IMS, lots of small stuff
    Aaaand... that kills the thread
    2Toys likes this.
  15. Jan 9, 2026 at 8:20 AM
    #255
    1SilverRunner
    Tejas
    JK. I think at this point we should go for the record. It's already longer than 90% of oil debate threads.
    2Toys, icebear and Thatbassguy like this.
  16. Jan 9, 2026 at 1:27 PM
    #256
    Grug556
    Grug556 New Member
    Kings, Crestone Rack, Baja S8, Baja Fogs, Baja XL80s, Baja mini cubes, SPOD, ARB compressor, RCI full skids, ROAM box and stuff. ST Pros. Shrockworks sliders... GOAT armour
    isnt it best to use Grape jelly when tossing a salad? :rofl:
  17. Jan 9, 2026 at 3:58 PM
    #257
    Powerstroke
    Powerstroke New Member
    Joe
    Spring Hill, SC
    2023 TRD Off Road Premium
    How about 3 quarts 0W-20 and top off with 5W-30?
    Turd Ferguson and icebear like this.
  18. Jan 9, 2026 at 4:02 PM
    #258
    2.5W-25? :p
    UncleShorty, icebear and 5thToy like this.
  19. Jan 9, 2026 at 5:52 PM
    #259
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    :hattip:
    glwood54[QUOTED] and icebear like this.
  20. Jan 9, 2026 at 9:21 PM
    #260
    1SilverRunner
    Tejas
    Gonna bulk buy some 5w-30, print some 2.5w-25 stickers, and make a killing.
  21. Jan 9, 2026 at 9:53 PM
    #261
    RSG sliders, Yakima Megawarrior basket, Black Rhino wheels, SOS Streamline bumper and skids, Warn VR EVO10S winch, OME MT64, Bilstein rear lift coils, Rigid Dually SS ditch lights, SR light bar, and Diode Dynamics SS3 fogs.
    I prefer syrup
    Grug556[QUOTED] likes this.
  22. Jan 9, 2026 at 11:25 PM
    #262
    Greg D
    Greg D TJ312
    TJ312
    2013 4runner
    {2.5wx15w}2
  23. Jan 11, 2026 at 4:22 AM
    #263
    Greg D
    Greg D TJ312
    TJ312
    2013 4runner
    I knew Toyota didn't manufacture their own lubricants, so I Groogled and found the answer.
  24. Jan 11, 2026 at 4:57 AM
    #264
    Sin4R
    2024 4Runner Limited
    Mall crawling kit.
    No, you asked AI to hallucinate you a response that highly correlated in the training data to some keywords in your request.
    Don't confuse that with a factual answer.
  25. Jan 13, 2026 at 5:00 PM
    #265
    NABeast
    NABeast New Member
    Paul
    2016 QS Pro
    I’m switching to 5w20 next oil change. 2016 80k miles, I don’t like the sound of the engine at start up and the first few minutes of running, i’ll see if that changes anything.
    BillF6531 likes this.
  26. Feb 11, 2026 at 10:56 AM
    #266
  27. Feb 11, 2026 at 12:12 PM
    #267
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
  28. Feb 11, 2026 at 12:13 PM
    #268
    engineer90
    engineer90 New Member
    NJ
    2023 TRD Off-Road Premium
    Finally something I disagree with him on.
    I do understand where he's coming from though. He just thinks we should stick to 0W-20 since that's what the manual says so you don't void the warranty if any issues arise.
  29. Feb 11, 2026 at 1:56 PM
    #269
    He also said that the engine was designed and tested with that oil.
  30. Feb 11, 2026 at 3:01 PM
    #270
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    To be clear - the engine was designed and tested with which oil? 5W-30 would be my guess.
